I received a 980X, and as always I decided to bench on LN2.
In the begining of the tests, I was very disappointed because I had never caught on with a CPU and a Coldboot and Coldbug so low.
VTT with louder he even reached 95 ºC and the lowest VTT was able to work around 84 ~ 94 ºC (little by little).
I tested several values of uncore, vtt, etc ... and at first I thought it is even more garbage.
Even so, I decided to continue and began to change my impressions.
With VTT of 1.45V (max), I managed to run the CPU test of the Vantage 6121 Mhz (always between 84 and 94 degrees).
dismantled the system, and rode again with another pot (SF3D and F1EE), but temperatures were correct.
I never thought that a CPU with as low a Coldbug could have results like that.
It is very difficult to control the temperature, but it was the best I ever had.
Any idea to fix this issue??? (did try dual channel and it keeps the same)
Then give an update on other tests so soon.
P.S. system without tweak ... only a heavy W7 64 "default"
