Results 1 to 19 of 19
Thread: new VGA Cooler from Alpenfoehn
Threaded View
    Jun 2010
    Thumbs up new VGA Cooler from Alpenfoehn
    Today we have new VGA Cooler from Alpenfoehn , this new Cooler come with new New Design (This is the first time I see design like this Cooler ) . this new VGA Cooler Called -Peter- .
    -Specifications-
    - Superior Cooling Performance with 6 high-end heat pipes.
    - Maximum surface through 91 aluminum fins soldered.
    - Interchangeable mounting rails for installation on future high-end cards.
    - Massive rail fastening system for two 140mm fans / four 120mm fans.
    - Perfect finish of all surfaces by SSNP (Shiny Silver nickel plating).
    -Features-
    Uploaded with ImageShack.us
    Minimum volume for maximum performance
    Alpenföhn Peter is the world's first VGA cooler the installation of 2 X 140mm fans supported. The installation of the fan is done via the included mounting rail system so that the best balance of performance and volume can be guaranteed.
    Construction in Perfection
    Extreme performance in a whisper quiet noise level. These were the cornerstones in the construction of Alpenföhn Peters. The combination of 6 high-end heatpipes, 91 aluminum fins and soldered the finest materials, this object could be successfully implemented.
    Please ensure that the mounting rails are that they are mounted in the same position as in the figure. For graphics cards in which a hole spacing of 80mm is required, contact the mounting rails by 180 ° so that the marking arrows are no longer visible.
    this Cooler Supports:
    Some pictures
    (Click on the numbers)
