Results 1 to 17 of 17
Thread: Turbo CORE Blog
    Dec 2009
    Turbo CORE Blog
    http://bit.ly/geqna3
    For those of you that have been asking for details.
    While I work for AMD, my posts are my own opinions.
    http://blogs.amd.com/work/author/jfruehe/
    Jun 2008
    Is these relate to Server CPUs only or Desktop ones will feature TurboCore and CoolSpeed technologies too?
    An unfortunate person is one tries to fart but sh1ts instead...
    My Water Cooling Case Build (closed)
    Jul 2010
    Birmingham, United Kingdom
    Just read it and even though it doesnt really give away too much detail it seems like the turbo core and cool n quiet technologies seem like they have more range now more than ever.
    I wonder how long till we get to the stage of a fully variable CPU clock?
    Dec 2009
    This will be available in both client and server parts.
    I am Xtreme
    Dec 2007
    think this will offer a unique way to overclock, like i up the voltage by .05v and modify a setting to let the TDP max out 30% higher, and let the cpu handle the rest?
    i wouldnt expect it to know what is or isnt stable, but what is and isnt in the same TDP that i tell it i want
    2500k @ 4900mhz - Asus Maxiums IV Gene Z - Swiftech Apogee LP
    GTX 680 @ +170 (1267mhz) / +300 (3305mhz) - EK 680 FC EN/Acteal
    Swiftech MCR320 Drive @ 1300rpms - 3x GT 1850s @ 1150rpms
    XS Build Log for: My Latest Custom Case
    I am Xtreme
    Dec 2008
    France
    So, basically, if there is some load on the CPU, then depending on how many cores are used, we get different CPU frequency (assuming we stay within TDP)? And these are pre-set values (and not calculated on the fly based on TDP, or whatever)?
    Donate to XS forums
    Dec 2009
    There is a base frequency and a max frequency. The processor will move between those 2 based on the workload, trying to get as high as possible, with the limit being the TDP of the processor.
    Obviously, with different #'s of cores being used, you have a different range between how much power is being consumed at base - but max power remains the same.
    I am Xtreme
    Dec 2007
    will it jump only by multiples of 100mhz (.5x multi) or is it much more dynamic than that?
    I am Xtreme
    Dec 2008
    France
    Quote Originally Posted by JF-AMD View Post
    I see. Thanks for clearing this up.
    Donate to XS forums
    Dec 2009
    Quote Originally Posted by Manicdan View Post
    Can't cover that just yet, that is a launch detail.
    I am Xtreme FlanK3r's Avatar
    May 2008
    Czech republic
    I wrote you my question on your blog
    ROG Power PCs - Intel and AMD
    Xtreme Guru
    Jun 2010
    In the Land down -under-
    Thanks JF, So if im understanding this correct the new Turbo core you guys have with BD isnt like intel where its just a added multiplier, Its a boost of up to 500mhz on each core.. So it pretty much boosts the core frequency on each core until it reached the tdp ?? Am i on the same page as you guys?
    Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
    May 2008
    Czech republic
    read the his blog about it. Its "clear"
    Xtreme Cruncher
    Jun 2006
    It's boosting clock across all 16 cores in Interlagos while they are under full load AND below the maximum TDP level. Intel's xeons have 1 speed bin boost(~100Mhz) across all cores under full load load but for limited time period.
    Xtreme Guru
    Jun 2010
    Quote Originally Posted by FlanK3r View Post
    i did, was just making sure
    Dec 2009
    Quote Originally Posted by Johnny87au View Post
    correct
    May 2008
    Czech republic
    For Bulldozer launch day I will take holiday . Need time to readings all reviews etc :-D
