Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Thread: Afterburner 2.1.0 Beta 6
    Xtreme Guru
    Jun 2010
    In the Land down -under-
    Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
    Xtreme Mentor
    Jan 2009
    Oslo - Norway
    Huh, no support for 560? What kind of new beta is this?
    I've just picked up a 560 and happily clicked on th link, but nope.
    ASUS P8P67 Deluxe (BIOS 1305)
    2600K @4.5GHz 1.27v , 1 hour Prime
    Silver Arrow , push/pull
    2x2GB Crucial 1066MHz CL7 ECC @1600MHz CL9 1.51v
    GTX560 GB OC @910/2400 0.987v
    Crucial C300 v006 64GB OS-disk + F3 1TB + 400MB RAMDisk
    CM Storm Scout + Corsair HX 1000W
    EVGA SR-2 , A50
    2 x Xeon X5650 @3.86GHz(203x19) 1.20v
    Megahalem + Silver Arrow , push/pull
    3x2GB Corsair XMS3 1600 CL7 + 3x4GB G.SKILL Trident 1600 CL7 = 18GB @1624 7-8-7-20 1.65v
    XFX GTX 295 @650/1200/1402
    Crucial C300 v006 64GB OS-disk + F3 1TB + 2GB RAMDisk
    SilverStone Fortress FT01 + Corsair AX 1200W
    Xtreme Guru
    Jun 2010
    Should be unless i linked the wrong one.. hold up..
    Xtreme Guru
    Jun 2010
    Sam this release isnt final, they're working on a final release which supports 560, hang in there mate.. Someone delete post ^
    Oct 2010
    香港 , Hong Kong
    msi AB is good
    But I like inspector
    If you live each day as if it was your last, someday you'll most certainly be right.
    Xtreme Mentor
    Feb 2008
    It works on my 560s and allows voltage control, but I had to download it with Internet Explorer to get it to install.
    Xtreme Mentor
    Jan 2009
    Oslo - Norway
    Inspector allows voltage control on my 560, but I can't change core-clock there.
    I've just downloaded the latest, but never used it before. Am I doing something wrong, or that means it is not supporting 560 yet?.
    EVGA SR-2 , A50
    Jun 2008
    just change shader clocks and core clock will change with it. There is a 2:1 ratio between shader and core clocks
    An unfortunate person is one tries to fart but sh1ts instead...
    My Water Cooling Case Build (closed)
    Xtreme Mentor
    Jan 2009
    Oslo - Norway
    Quote Originally Posted by SpuTnicK View Post
    I see, just got EVGA Precision 2.0.2 and it's working just fine with 560. It can Change the Core-clock and fan speed
    This is at @ stock volt, and if this turn to be unstable (I haven't tested it under load yet), then I may use the Inspector to add a little extra voltage.
    EVGA SR-2 , A50
    Oct 2006
    new jersey
    ab b6 and latest nvi both work 100% for 560 from what i'v tested so far.
    _________________
    Xtreme Mentor
    Jan 2009
    Oslo - Norway
    Afterburner 2.1.0 Beta 6 is working here too, but the voltage control is not working. But maybe my babe doesn't need it, LOL, it passed the Kombaser Benchmarking with stock volt @1GHz ; I don't know (and don't think) this is stable for gaming, still testing.
    I like that max load-temp 59'C with auto-fan tho
    EVGA SR-2 , A50
    Xtreme Mentor
    Jan 2009
    Oslo - Norway
    Inspector can't change the voltage for 560 either.
    You can move the slider and apply voltage, and Inspector remembers that too, but does it only for itself. It doesn't change it actually. Both GPUz and Aida64 reports the stock voltage. I guess we need upgrade soon.
    EVGA SR-2 , A50
    Xtreme Mentor dengyong's Avatar
    Nov 2006
    A great place again
    Quote Originally Posted by Sam_oslo View Post
    In afterburner you'll have to check "unlock voltage control" under settings.
    Feb 2010
    Wisconsin
    I could've sworn I posted here before... but I can't find any reason as to why it'd be deleted.
    Anyways, I saw Beta 7 links around Google, but when I click on the download link, it redirects to Beta 6...?
    Signatures make my posts look huge... but I'm not humble enough to completely remove my signature, so I kept this note explaining it.
    Xtreme Mentor
    Jan 2009
    Oslo - Norway
    Quote Originally Posted by dengyong View Post
    Thx, it worked
    Not easy to remember everything when I'm downloading, OCins, testing, etc .. all at the same time, like crazy LOL. Then It's always nice to get a good tips
    Voltage=1.1v added 6'C to the load-temp, but it's still only max 65'C under the Kombastor-run. That's a short run, I have to see how this works with real games, but that low-temp looks promising.
    EVGA SR-2 , A50
    Xtreme Guru
    Jun 2010
    Awesome results sam, I smell 1200
    Jun 2008
    try running FurMark. I think it loads more like a game, or even more. Be careful !
  18. #18
    I am Xtreme
    Dec 2008
    France
    It's pretty much the same thing...
    Donate to XS forums
  19. #19
    Oct 2006
    With the 580's furmark and Kombustor are no longer very good tools to determine card stability under load.
    The VRM's kick in instantly giving false results.
  20. #20
    Feb 2010
    Wisconsin
    Quote Originally Posted by ScottALot View Post
    I'd really like the answer to this because if I could get some more voltage, I'd easily be able to squeeze out 1GHz on my 460 Hawk... the original 1GHz run that hyped everyone says "Afterburner Beta 7" on the bottom right if I remember correctly... and it allowed the user 200mV extra voltage.
  21. #21
    I am Xtreme
    Dec 2008
    France
    There is not such thing as 2.1.0 Beta 7 available yet. There is 2.0.0 Beta 7, though...
    Donate to XS forums
  22. #22
    Xtreme Mentor
    Feb 2008
    My drivers stop responding if I set my card over 970 Mhz, but I have no artifacts or image problems
  23. #23
    Xtreme Guru
    Jun 2010
    Beta 7 will be out this week guys, Msi almost done!
  24. #24
    Jun 2007
    worked fine here. waiting for bata 7.
  25. #25
    Feb 2010
    Wisconsin
    ^Is my motherboard talking to me? I love you MSI Big Bang Xpower...
