Updated - 03/07/2011
We have new NV video drivers for the P67 WS board that along with the 1103 UEFI offers improved GPU/multi-GPU performance. You will not be able to roll back to an older UEFI after this update as it contains new firmware and B3 stepping compatibility. The next official UEFI update (13xx code) in the near future will feature additional user enhancements, USB drift fix and updated Marvell/Intel MEI controller firmware. I highly suggest a Clear CMOS event after loading the updated UEFI and then entering UEFI to reset your custom settings. JJ and I will have updated information on memory setups and SSD testing next week.
1. Reset your UEFI to Optimized Defaults, reboot, enter UEFI and then flash to the new UEFI build.
2. After flash and restart, enter Windows/Linux, then exit and shutdown.
3. Remover the power cord from the power supply, wait thirty seconds, press Power On button to clear any remaining charge, clear CMOS for five seconds, reattach the power cord, power on the system, enter UEFI, set to Optimized Defaults, save and exit.
4. Enter UEFI, set your system to customized settings based on your system configuration (RAID, OC, etc), save and exit.
Maximus IV Extreme -
1204 Change Log -
- Improved OC performance using Multipliers or Auto Overclocking
- Improved BCLK and DRAM OC capabilities when enabling the “Internal PLL Overvoltage” option in BIOS. Note - Sleep/Hibernate will not operate properly due to Intel Specs.
- Improved Memory Profiles and Performance (Elpida Hyper owners, please use Red Slots for best performance, CFG Lock to Disable should improve SuperPI times even better now)
- Improved USB compatibility, performance and UEFI fixes
- Minor Bug Fixes
- Enable SPDIF output support in UEFI
- Enhanced auto rules
- Fixed OC profile usage with vCore offset mode
- Enable CPU target frequency at POST
Official Release - UEFI 1204-
http://www.mediafire.com/?qvgxf3wa6wv115a It will be on our support site in a few days.
New ROG Connect - version 10410
ftp://ftp.asus.com.tw/pub/ASUS/mb/LG...pVistaWin7.zip
New ROG Connect Plus - version 10010
Please note - Enabling Memory Bandwidth Boost will tighten memory subtimings and can cause non-post conditions with certain memory kits. It is currently optimized for Elpida Hyper and High Speed PSC ICs. This setting will be optimized with additional memory profiles over time and we are working on "best" settings for mainstream kits now. I recommend unless you are trying to set SuperPI records with the above kits that most users leave this option disabled. It is meant for "on the edge" overclocking.
P8P67 WS - Official UEFI 1103 (Based on 1305 and up Code)
Change Log -
- Improved USB performance, Improved P67 XMP profile compatibility (please note, memory with X58/P55 XMP profiles will generally work but is not optimized for P67 and will usually cause problems when overclocking in several cases)
- Improved MultiGPU performance
- Per Core Save Fixed
- Minor Bug Fixes including new Auto Rules for C-States (C3/C6) when overclocking. If you are overclocking, C-States will be disabled for enhanced performance. If you want EIST to work properly while overclocking, please ensure that C1E is enabled, C3 and C6 are also recommended to be enabled for PM reasons unless you are benchmarking 3DMark, PCMark, or Super PI.
- Intel RAID will not support bootable volumes greater than 2.2TB yet, Intel plans a firmware update shortly to allow this operation. AHCI and IDE are not affected.
- Enhanced AI Suite II compatibility
- Updated ME Firmware to 1197
Official Release - UEFI 1103 -
ftp://ftp.asus.com.tw/pub/ASUS/mb/LG...-ASUS-1103.zip
For Best Graphics Performance on the WS board using NVIDIA cards, please use these drivers -
Vista/Win7 64-bit -
ftp://ftp.asus.com.tw/pub/ASUS/mb/LG...Win7_64bit.zip
Vista/Win7 32-bit -
ftp://ftp.asus.com.tw/pub/ASUS/mb/LG...Win7_32bit.zip
WinXP 64-bit SP3-
ftp://ftp.asus.com.tw/pub/ASUS/mb/LG...inXP_64bit.zip
WinXP 32-bit SP3-
ftp://ftp.asus.com.tw/pub/ASUS/mb/LG...inXP_32bit.zip
P8P67-M Pro, P8P67-M, P8H67-M Pro, P8H67-V, P8H67-M, P8H67 -
Change Log - (Based on 1305 code, not all items listed will be available depending on chipset and UEFI Options)
- Disable/Enable BT
- Minor Bug Fixes including new Auto Rules for C-States (C3/C6) when overclocking. If you are overclocking, C-States will be disabled for enhanced performance. If you want EIST to work properly while overclocking, please ensure that C1E is enabled, C3 and C6 are also recommended to be enabled unless you are benchmarking 3DMark, PCMark, or Super PI.
UEFI downloads will be at our FTP and Support Sites Shortly, otherwise you can download them here -
P8H67-M Pro 0806
http://www.mediafire.com/?9g66sbatz2883i8
P8H67-V 0704
http://www.mediafire.com/?hcv32rtnc6icj2z
P8H67 0803
http://www.mediafire.com/?vvxgam8bebfqxf4
P8H67-M 0602
http://www.mediafire.com/?wpz6talcd9u8izl
P8P67-M Pro 0703
http://www.mediafire.com/?d4vr319obv5ovbr
P8P67-M 0702
http://www.mediafire.com/?ro2ci6y043qub63
1101 Change Log -
- Improved Memory Profiles and Performance (Elpida Hyper owners, please use Red Slots for best performance, CFG Lock to Disable should improve SuperPI times)
- Minor Bug Fixes
- Auto Voltage Resume Fix
Official Release - UEFI 1101 -
ftp://ftp.asus.com.tw/pub/ASUS/mb/LG...-ASUS-1101.zip
P8P67 Deluxe / Pro / EVO / Standard / Sabertooth - 1305 / P8H67M-EVO - 1305 -
Change Log -
- Disable/Enable BT
UEFI 1305 - Pro
ftp://ftp.asus.com.tw/pub/ASUS/mb/LG...-ASUS-1305.zip
UEFI 1305 - Standard
UEFI 1305 - EVO
UEFI 1305 - Deluxe
UEFI 1305 - Sabertooth
UEFI 1305 - P8H67-M EVO
Other Official Releases-
P8P67 LE UEFI 1003
Change Log -
- Removes full reset at POST (double post) on cold boot or auto overclocking routine.
- Improved OC performance using Auto Overclocking
- Minor Bug Fixes including Auto Rule for C3, C6 being disabled when overclocking and improved USB compatibility.
- Enabling Internal PLL Voltage will still cause resume/hibernate issues (Intel related) but we are working with Intel on any potential workarounds.
UEFI 1003 - http://www.mediafire.com/file/zvx227...-ASUS-1003.rar
AI Suite II Updates - Please Download if you are still using the Support CD version as they are optimized for use with the new BIOS updates, now includes WS board
P8P67 WS Users -
ftp://ftp.asus.com.tw/pub/ASUS/mb/LG...e_II_10117.zip
P8P67 Basic / PRO / EVO / Deluxe Users -
ftp://ftp.asus.com.tw/pub/ASUS/misc/...ite_II_P8P.zip
Maximus IV Extreme Users -
ftp://ftp.asus.com.tw/pub/ASUS/misc/...ite_II_M4E.zip
P8H67M-EVO Users -
ftp://ftp.asus.com.tw/pub/ASUS/misc/...8H67_M_EVO.zip
P8P67 Sabertooth Users -
ftp://ftp.asus.com.tw/pub/ASUS/misc/...XP_Vista_7.zip
As always please ensure you have the latest Intel Chipset, LAN and Management Engine Interface drivers loaded.
Intel INF Update 1021 - (qualifying 1025 now, MIVE and WS users are clear to use)
http://downloadcenter.intel.com/conf...Series+Chipset
Intel Management Engine Interface Driver Update 1197 -
http://downloadcenter.intel.com/Deta...B65AL&lang=eng
Intel LAN Driver Update 16.0
Intel RST
(expecting updated driver set from Intel shortly)
New Marvell SATA Controller Driver Set - (1051, recommended for new Crucial C400, Corsair P3 and Intel 510 SSDs or other drives containing Marvell controller chipsets)
AI Charger Update - 10009
ftp://ftp.asus.com.tw/pub/ASUS/mb/LG...ger_V10009.zip
when doing any changes it will ignore them and simply boot ~100 bclk.
