Results 1 to 15 of 15
Thread: Upgrade from qx9650 to 2600k
    Jun 2010
    As the title suggests im looking at upgrading, and was wondering if it was worth it? Would i see much of an improvement for gaming going from qx9650 to 2600k?
    Current pc spec:
    qx9650 @ 3.6
    8gb ddr3
    180 total ssd (2 drives)
    2x 480gtx
    790i ultra mobo
    antec 1200 psu
    Aug 2006
    Quote Originally Posted by hywell View Post
    Current pc spec:
    qx9650 @ 3.6
    8gb ddr3
    2x 480gtx
    790i ultra mobo
    antec 1200 psu
    Hmmmm good question. I came from a Q9550 at 4.3 to the 2600K at 5.0 and in black ops I am seeing zero difference at all. I only picked up like 200 points in 3dmark11. But synthetic benchmarks show huge gains!!!
    Aug 2007
    Depends on what you do.. some games will benefit.. I went from a 3.8 q9550.. running a sandy @ 4.8 now.. it might be just crap, but it feels faster now..
    you're running 480 SLI? always good with the extra horsepower It can never get too fast.. hehe
    Gigabyte P67A-UD7 F6a
    i7 2600k @ 4.8 (1.35 bios vdroop lvl 2)
    Gtx 580 @ 900/4004
    Corsair HX 1000W PSU
    1 Corsair Force 120GB SSD boot
    2 Intel X25-m 160GB SSD(2. gen) for games
    1 TB WD Green, 1 750 WD
    Watercooled CPU
    I am Xtreme
    Sep 2006
    QX9650 at 4000Mhz ( 10 x 400 ) Rams at 1600mhz CL8-8-8-24 1T on REX X48, review up somewhere soon...
    Question : Why do some overclockers switch into d*ckmode when money is involved
    Remark : They call me Pro Asus Saaya yupp, I agree
    Jul 2009
    California
    It depend but a 9650 @ 3.6 and a Sandy at 4.6 for example well yeas a lot of differences... If you are running heavy CPU games or Simulations this will give you more FPS with the same video cards.. way smoother less stutters etc.. just stronger CPU.
    I do have also other machines Q6600, Q9550 @ 4 GHZ ( SLI ) and a Q9650 @ 4.2 GHZ( SLI )
    Jun 2010
    Wow thanks for all the replies. I know it'll be quite a bit faster but i'm also thinking ahead, aparently theres a even better chip coming sometime this year which is like the "enthusiast" version of sandy bridge. Would you guys recommend waiting for that?
    Jun 2007
    I have a QX9650 and a X3380 running at 4.1 GHz and I am definitely waiting for the newer CPU's (socket 2011) that hopefully won't come with an integrated GPU that I'll never use and limits bus clock overclocking.
    Your current system is certainly not low-end so I'd wait it out a bit longer if you can resist the urge to upgrade....
    Intel 6700K @ 4.3 GHz
    Gigabyte GA-Z170-HD3 DDR3
    4x4GB Corsair DDR3-2800
    GTX980Ti MSI Lightning
    Samsung 950 Pro 512GB
    4 x Intel 80GB x25-m SSD's RAID0
    Enermax Revolution 85+ 1250W
    Jun 2010
    Quote Originally Posted by chinobino View Post
    I think i can resist, good things come to those who wait!
    May 2006
    Philippines
    You may aswell bite the bullet sandy bridge is so so much better than QX9650! Its made everyday tasks so easy! Its just so advanced to the last intel cpu it unreal!
    Jul 2006
    With that setup I would strongly consider waiting for next version of Sandy Bridge in Q3(?).
    jarle
    Old Comp:
    Antec 182
    Asus Maximus Formula (Bios 1302)
    Q6600 G0 @3.2GHz @ 1.3V (can easily go higher but NB/SB heat is a problem sadly...)
    Ultra 120-Extreme w/Nexus 12cm realsilent fan
    Corsair Dominator TWIN2X PC8500 4GB DDR2 @ stock/400MHz strap, 1:1 with cpu
    XFX Radeon 6950
    1 x WD Raptor X 150GB
    1 x WD Caviar SE 16 750GB
    Corsair HX620
    Vista Ultimate 64bit
    Xtreme Mentor
    Feb 2009
    Bangkok,Thailand (DamHot)
    In term of overclocking you would be get more Ghz
    Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
    EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
    Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
    Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
    [history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
    Xtreme Guru
    Jun 2010
    In the Land down -under-
    Please read around the intel section, thousands of threads regarding this topic.. and yes you will see the biggest JUMP you have ever seen
    Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
    I am Xtreme
    Dec 2008
    France
    For gaming - don't bother, wait for socket 2011 and Bulldozer.
    Donate to XS forums
    Dec 2010
    Current pc spec:
    qx9650 @ 3.6
    8gb ddr3
    2x 480gtx
    790i ultra mobo
    antec 1200 psu
    I realize this is an old thread but I am running my qx9650 @4ghz (11.5 x 348) and the only thing slowing me down is my gtx460 768mb. I'm not even going to upgrade to socket 2011 when it debuts. What I am going to do is buy the highest end Kepler when it comes out and slap it in this pup. My theory is that all you need the cpu to do is be able to run the video card. I can personally give a crap about +/- 7or 8 fps to be honest. It's all about the gpu at this level of cpu's. When I do upgrade the cpu it will be the 22nm Haswell. That will have all of the usb3.0 and sata 3 bull S all worked out and I'm sure an air cooled 5ghz overclock will be standard through out all of the forums. This is just my opinion though. Good luck with whatever you do, or did.
    Administrator andressergio's Avatar
    Jul 2007
    Montevideo - Uruguay
    Current pc spec:
    qx9650 @ 3.6
    8gb ddr3
    2x 480gtx
    790i ultra mobo
    antec 1200 psu
    i would upgrade no doubt of it SB is so fast and pumps FPS up, u just need a mobo and the chip, u got all the rest
    cheers !
    Sergio
    Intel Core i9-7980XE@ 4.8GHz 18C/18TH (Direct Die Contact)
    ASRock X299 OC Formula
    ADATA XPG SPECTRIX D80 (4x8GB) DDR4-3800C17 B-Die
    1x Intel Optane SSD 905P 480GB
    4x HP EX950 NVMe 2TB on ASRock ULTRA M.2 CARD
    EVGA RTX 2080TI KINGPIN 2190/8000 Stock Cooling AIO 240
    SilverStone ST1500W-TI TITANIUM
    Alphacool Custom Water Cooling
