K I'll put up a list, as I did it with the Wolfdales BUT
1) I need more proof then just saying that you got 5ghz at 1.35 stable
2) What I propose :
Grab this LinX version from Zalbards thread ( as it almost correctly stresses all the cores and threads ) : linx(0.64)_10.3.0.003.zip Or use Prime95 eg with custom test 12K-12K selected.
3) In case of LinX : all ram has to be selected ( preferably over 2.8Gb, so only option is a 64Bit OS ) and it has to be at least 20 runs and still running when taking the screenshot. So select eg a 25 loops; start the test. Once you pass 20 loops, grab a screenie with everything running. For prime9 an hour of the custom test (12 -12K) is already a good indication if the CPU is stable
4) CPU-Z : CPU, Mobo and Memory tab open
5) TMonitor open ( to see all the cores loaded )
32 Bit : TMonitor_1031_32.exe
64 Bit : TMonitor_1031_64.exe
Or Task manager or sortlikes that show clearly 100% load on all the cores...
6) Realtemp open from the start of the test ( this to monitor actual running time as prime95 screenies can be easily faked ) or keep task manger open with the prime95 process time listed
7) List : CPU , Batch, Mobo & Bios version , cooling type. Additional info as CPU PLL voltage, Override enbled,... can be added
If more ideas pop up plz let me know, will start to collect from today
Eg here is a screenie of what is required :
THIS BY ALL MEANS IS NOT A THREAD WHERE PERFORMANCE, GFLOPS OR OTHER THINGS MATTER. THERE'S NO MINIMUM SPEED LIMIT EITHER. IT'S INTENDED TO FIND GOOD BATCHES MORE EASILY... Also no discussion on what's to be called stable or not. If it's stable for you then it's for me... if you want max stress test use Prime 96 26.4 version and LinX with Win7 and Service pack 1
If 4.5 is ya thing let's us know, this thread doesn't need to be 5ghz plus only...
Thx for the cooperation
Here's the current Excel sheet ( saved it to 2003 compatible ), click on it, choose save as and open it :
SANDY BRIDGE FPO BATCH LIST FROM XS FORUMS
- 2500K
Batch Stable speed Vcore used Motherboard bios Cooling Used
L036B120 4500 1,275 Asus P8P67 Pro 1053 watercooling HK 3.0 Kinglex
L036B120 4700 1,452 Gigabyte P67A-UD4 F6X Air Ayttacaksel
L036B120 4500 1,328 Asus P8P67 Pro 1053 Air Ripper18
L038A789 4200 1,3 Asus P8P67 Pro 1053 Xigmatek Air cooler Leeghoofd
L038A789 4400 1,288 Asus P8P67 Dlx 1003 Corsair H70 Leeghoofd
L038A789 4700 1,38 MSI P67A-GD65 1.8B6 Air Prolimatech Kuziu
L039B120 5000 1,392 Gigabyte P67A-UD4 F7f Air Scythe Ninja 3 Digg.de
L040B671 4800 1,385 Asus P8P67 Dlx 1204 Air VenomousX LagunaX
L040B671 5000 1,45 Asus P8P67 Pro watercooling Coolhandluke41
L041B517 5000 1,445 Gigabyte P67A-UD5 Air cooling C-N
L041B564 4600 1,42 Asrock P67 Pro3 Air Sonic Tower Chukundur
L041B789 5000 1,424 Asrock P67 Extreme 4 P1.50 Air Cyan1d3
L041C123 5000 1,336 Asrock P67 Pro P1.50 True Black PnP PolRoger
L041C124 5000 1,33 Asrock P67 Extreme 4 P1.20 Air Alex -Ro
L042B144 5000 1,38 Asrock P67 Extreme 6 Air 3dsag3
L045A951 4800 1,35 Asrock P67 Extreme 4 Air ClockZ
L046B582 5000 1,46 Asrock P67 Extreme 6 Watercooling Beast2000
L047B217 5000 1,45 Asrock P67 Pro3 P1.70 Watercooling Dnottis
L048A952 4500 1,24 Air R3sy4
L049A796 4600 1,272 MSI P67A-GD65 Roadie
L049A796 4800 1,32 Asus P8P67 Watercooling Jumper2high
L050A863 5300 1,52 Asus P8P67 WS Watercooling Ace.
L050A864 4600 1,272 Gigabyte P67A-UD4 Watercooling GeorgeVasil
- 2600K
Batch Stable speed Vcore used Motherboard bios Cooling Used User
L038A660 5000 1,4 P8P67 Dlx 1053 Thermalright Venomous X CrossG
L038A660 5088 1,428 Gigabyte P67A-UD7 Watercooling Skeyo
L039B214 4800 1,35 Asus P8P67 Dlx 1053 Thermalright TRUE 120 Orion123
L039B214 4700 1,395 Gigabyte UD4 F6X Air Zalman UgotD8
L039B470 4500 1,28 Asus P8P67 Dlx 1053 Corsair H70 Leeghoofd
L039B470 5000 1,456 MSI P67A-GD65 1.8B5 Watercooling EK HF block BulluS
L040B165 5254 1,512 Asus P8P67 Pro Watercooling SBB
L040B165 4500 1,27 Asus P8P67 Dlx 1204 Air Silver Arrow Sam Oslo
L040B208 5000 1,37 Gigabyte P67A-UD5 F6A watercooling Flesheatinvirus
L040B208 5000 1,44 Asus P8P67 Pro Watercooling Simpletech
L040B208 4800 1,335 Asus P8P67 Dlx 1053 Air Prolimatech Zoob
L040B307 5000 1,416 Asus M4E 675 Air Prolimatech Chrish
L040B307 5000 1,344 Gigabyte P67A-UD7 F6X Beatle
L040B307 5000 1,37 MSI P67A-GD65 V1.8B6 watercooling Swiftech Apogee XT Klaata
L040B671 5100 1,48 Asus P8P67 Pro Watercooling Coolhandluke41
L040B689 4500 1,305 Gigabyte P67A-UD7 F6X watercooling OC_Nub
L040B694 5100 1,488 Asus P8P67 Pro Chilled Water Donmarkoni
L040B698 4900 1,432 Asus P8P67 Pro Air Poke349
L040B705 4700 1,448 Asus P8P67 M Pro 414 Air VenomX DVS
L040B705 5100 1,48 Gigabyte P67A-UD3P F6A Air Jonesey
L041C106 5076 1,456 Asus P8P67 Evo Air Augidogie
L041C106 5000 1,336 Asrock P67 Pro Air PolRoger
L041C108 4900 1,36 Asus P8P67 Air VenomousX LagunaX
L041C108 5000 1,404 Gigabyte P67A-UD7 Air Cooling Nijel
L041B798 4851 1,44 Maximus IV extreme 951 Watercooling Csktl1
L041B213 5000 1,45 Gigabyte P67A-UD7 Watercooling Tnc99
L041B213 5000 1,448 Asus P8P67 Dlx Watercooling Famich
L041B200 4700 1,29 Asrock Extreme 6 P1,40 Air Scythe Ninja DjLeco
L041B202 4900 1,476 Gigabyte P67A-UD7 F6X watercooling Owikh84
L041B741 4888 1,4 Gigabyte P67A-UD7 F7e watercooling Swiftech Apogee XT Nostromo
L042A969 5151 1,596 Biostart P67XE Watercooling :banana::banana::banana::banana:43
L042B047 4800 1,288 MSI P67A-GD65 1.6 Air Blackoberst
L042B074 5100 1,464 Asrock Extreme6 Air Prolimatech Olivon
L042B074 5000 1,32 Asus P8P67 Pro 1053 Air Prolimatech Kuba_TM
L042B074 5000 1,365 MSI P67A-GD65 1.8B6 Air Noctua NH D14 Blackoberst
L042B076 5000 1,38 Asus Maximus 4 Extreme 88 Prolimatech Chrisch
L042B076 4600 1,28 Asus P8P67 Corsair H50 Dami3n
L042B076 5343 1,6 Gigabyte P67A-UD7 Watercooling Newhit
L042B076 5100 1,425 Asus Maximus 4 Extreme Stoned
L042B076 5302 1,51 Gigabyte P67A-UD4 Watercooling Yoshimura
L042B208 5100 1,5 Asus P8P67 Dlx Watercooling DaddyJaxx
L042B208 5000 1,488 Asus P8P67 Pro Air cooling Loud Silence
L042B243 5000 1,5 Asus P8P67 Dlx Watercooling Dragonhunter
L042B243 5000 1,52 Asus Maximus 4 Extreme Watercooling The Nemesis
L044B441 5000 1,424 Asus P8P67 Dlx Air Thermalright Venomous CrossG
L045A912 4800 1,408 Asrock P67 Pro 3 1,7 watercooling Dnottis
L045B005 5000 1,44 Gigabyte P67A-UD5 Single Stage Ikozarov
L045B021 4800 1,428 Gigabyte P67A-UD7 F7E Watercooling Andresergio
L046B509 4900 1,5 Gigabyte P67A-UD3P F6A Watercooling Marc Beier
L047B217 5300 1,568 Asus P8P67 WS Watercooling Ace
L048A937 5100 1,512 Asus Maximus 4 Extreme 951 Watercooling Owikh84
L050A854 4500 1,248 Gigabyte P67A-UD7 F7E Air Noctua NH D14 Vanjara
L050A864 5000 1,368 Gigabyte P67A-UD5 Watercooling C-N
L051B145 4500 1,264 Asus Maximus 4 Extreme 901 Air Prolimatech Rabor
Leegie
UPDATED ON THE 10th of March 18:55CET
Saaya yupp, I agree
