A while ago I drained and refilled. Had some copper colored buildup on my res that I cleaned out, I'm thinking something went weird with the copper sulfate PT-Nuke I was using? Maybe I had too much in there, I don't know, it just turned the res copper inside that had to be cleaned out...
Well, when I refilled, I was planning on putting in a killcoil instead of PT nuke this time. Except the coil hadn't arrived yet, so I just filled with distilled without any sort of biocide whatsoever. Um, that was months ago, and the killcoil is still sitting on the shelf...
It got really dusty inside the computer over time so I decided to clean it. Noticed hmm the drain line looked a little funny...
Took the front panel off and....
Another shot
OK that's just gross. Fine, I'll tear down the loop and replace the fill and drain lines. But, my primochill LRT wasn't translucent anymore. Odd... Then I noticed that tubing was filled with junk too... couldn't get a pic of the inside of the tubing, but lets just say it was nasty in there. enough that you can't see any light through it at all anymore.
And a shot of where it was connected to a barb to give an idea of how it was supposed to look
Oddly enough the res was still perfectly clear all this time.
Oh FUN!
I just stuck it all back together and refilled. I'm not going to even try to clean the tubes, I'm just ordering new ones and will scrub the blocks and flush the radiator really well.
Oops! Don't forget biocide!
