Results 1 to 25 of 261
Thread: "V2" Koolance *Dual D-5* Bay Reservoir! (RP-452X2)
Threaded View
    I am Xtreme
    Sep 2007
    Auburn, WA, USA
    I'm pleased to announce our newest version of the dual 5.25", single/dual D5 pump reservoir: RP-452X2. We've incorporated much of the feedback given on our RP-450X2. (We'll also be releasing a model for single/dual DDC's later this month-- thread here.)
    The description is similar to RP-450X2, and I'll bullet-point the key differences after that:
    Easily combine Koolance's highest flow pumps into dual or serial/redundant loops! RP-452X2 is a dual 5.25" bay reservoir designed for one or two Koolance PMP-450 or PMP-450S pumps (not included). Using a convenient bottom plug, the front reservoirs can be separated or combined without disassembling the unit. Both front and top fill ports are available for each reservoir.
    Key differences vs. last model:
    • The two reservoirs in front can be left completely separated or combined into one tank. This allows either dual/parallel or serial REDUNDANT loops.
    • We've added a bottom plug that allows the reservoirs to be combined or separated without disassembling the unit.
    • Front (black) fill ports! There's still top fill ports for each reservoir as well.
    • We were able to add 2mm more to the distance between rear nozzle sockets. Hopefully, this will provide better support for 3rd-party nozzles.
    • To assist with loop-backs on the rear of the product, an optional 180º connecting pipe is available (included with Rev.2.0).
    • This was added into the RP-450X2 later in its production, but we've kept the front printing on the RP-452X2 smaller and less obtrusive.
    Materials are the same, solid acetal with acrylic/aluminum bezel, nickel-plated brass fittings and EPDM o-rings.
    Ok, on to the pictures (latest revision 2.0 shown):
    Tim
