Hoping someone else has noticed the following two points in running Linx and or Prime95 when OCing these new chips:
1. Gone is the disparity in temps between Linx and Prime95.
I'm seeing the exact temps on 100% load no matter what I use, IBT, Linx or P95. A common quote among people regarding stability testing on the I7 45nm chips was "Linx stresses the CPU harder and that explains the sometimes 10-15C difference in temps". What explains the lack of disparity now ?
2. It's going to fail and BSOD in the first few minutes, or not at all.
Granted my longest P95 run so far is a mere 2 hours, but in every case when I didn't give it enough VCORE, I found out within the first couple of minutes.
