Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 125
Thread: ASRock P67 Extreme6, any thought's?
    Apr 2005
    Norway, approx. 1367Miles from the Northpole
    Looking to buy a new Sandy Bridge system I stumbled across the ASRock P67 Extreme6. I really liked the layout and the ability to use 775 coolers on it, this mean that I don't have to buy a new expensive waterblock
    The board also features a whopping 6 x SATA3 and 6 x USB3 ports. It also has an enormous heatpipe cooling system (just peel of those stupid metal plates on top ). It's reasonably priced here in Norway, a good 25$ cheaper than the Asus P67 Deluxe..
    But... I never had any ASRock boards before! How is the reputation of the brand and how is BIOS support? OC'freindly?
    http://www.asrock.com/mb/overview.as...P67%20Extreme6
    A massive 16+2phase digital PWM and Nichicon LF-series Japan Solid Caps
    ..more eyecandy here: http://hardwareblog.dk/2010/12/asrock-p67-extreme6/
    Live to Mod.. Mod to Live!
    Sep 2008
    ROMANIA
    Well i had an Asrock motheboard, P55 PRO, 115$ cheap motheboard but it was very good in overclocking. See in the signature i validated 5ghz and 239BCLK on air. The bios(now is a little diferent on P67) was quite good many overclock and voltage settings. And they do updates to bios, they offer support.
    Also the POWER/RESET and the CLEAR CMOS button located on the back on I.O. panel is avesome. You don't even need to open the case to do clear CMOS.
    And that was a cheap MB.
    P67 Extreme6 is a high end so it will be much better.
    Just they offer 2 years of waranty not 3 like Gigabyte/Asus.
    And bay the way from june 2010 there definitive separate from Asus, they aren't anymore low division of Asus.
    i5 2500K@ 4.5Ghz
    Asrock P67 PRO3
    P55 PRO & i5 750
    http://valid.canardpc.com/show_oc.php?id=966385
    239 BCKL validation on cold air
    http://valid.canardpc.com/show_oc.php?id=966536
    Almost 5hgz , air.
    Apr 2005
    Thank you very much for the input! Just read a review of the Extreme4 @ Anandtech, and it got positive feedback and I doubt the Extreme6 would OC any less
    I have had most other brands before, but ASRock is new to me. I'll give it a try and order this MB + a i5 2500K to go with the board. Got a stunning deal on that combo
    Dec 2006
    Kuwait
    I like the layout and color of the board , never try Astrock before , but its look promising , but i think if you are going to use SLI or CF your cards will run x8,x8
    and the golden color of the capacitors make them looks cheap .
    Gaming rig;
    ASUS RAMPAGE IV BLACK EDITION
    I7-4390K
    G.SKILL Trident X 16GB 2400
    Intel 530 240GB
    2x Asus GTX780
    Corsair AX1200
    HP ZR30w 30
    Win 8.1 pro
    Sound rig;
    Auzen X-Fi H.T. HD --> Yulong D100 MKII --> D-7100
    Apr 2005
    Quote Originally Posted by koc View Post
    Yes the Caps looks "cheezy", but they are produced by Nichicon, one of Japan's most respected brands
    Nichicon LF-series, Ultra Low ESR, High ripple current. Load life of 2000 hours at 105°C.
    http://www.nichicon.co.jp/english/products/pdf/e-lf.pdf
    Sep 2007
    This board has an amazing layout and 10 sata headers to boot, hopefully it'll be available this sunday. Only thing i don't like is the short 1 year warranty, asus and others have a 3 year warranty.
    Xtreme Guru
    Jun 2010
    In the Land down -under-
    The phase capacitors look sexy imo!
    Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
    Feb 2010
    Wisconsin
    AsRock is the secret Asus never wanted you to see. It's comparable to Asus's flagship line, but significantly cheaper. The performance hides behind the not-so-amazing looks of the board.
    Signatures make my posts look huge... but I'm not humble enough to completely remove my signature, so I kept this note explaining it.
    Jun 2008
    Italy
    2012? Time will tell
    MOA 2011 Italy #1 | MOA 2011 EU finals #7
    GOOC 2010 Italy #4
    Excuse me for my English...
    Apr 2005
    Quote Originally Posted by canna1988 View Post
    http://translate.google.no/translate...-di-tutti.html
    The P67 Extreme 6 showed no problems even at very high frequencies, as with a regular air cooling system, we managed to reach a stable frequency of 5200 MHz to 104 MHz with a BCLK
    Not bad for an aircooled 2600K
    They also had the BCLK as high as 107MHz
    Can't wait to get my ASRock in my watercooled rig
    Mar 2009
    to decide which motherboard you should get today, look at motherboards of the past and see which has the most frequent and latest bios updates. ask who likes their old board.
    I've used old asrock boards for years and they have unofficially updated the bios on a forum so it is completely up to date. I am very pleased with asrock in the past.
    if I'm considering extreme6 versus asus evo, I wonder if the asus owners would recommend it.
    Jun 2008
    Italy
    Quote Originally Posted by ArcticOC View Post
    They also had the BCLK as high as 107MHz, but this was not 24/7 stable
    Sorry for the link, i forgot google translate :S
    However my BCLK is 24/7 stable
    Vcore was higher only for safety, but at 4700 MHz CPU is stable with 1,31 / 1,33V
    GOOC 2010 Italy #4
    Sep 2008
    ROMANIA
    Nice, canna1988!
    5ghz is easy to reach?
    i5 2500K@ 4.5Ghz
    Asrock P67 PRO3
    P55 PRO & i5 750
    Almost 5hgz , air.
    Jun 2008
    Italy
    Quote Originally Posted by xdan View Post
    Nice, canna1988!
    thx mate
    yes 5ghz are really easy, but is normal you need also a CPU.
    PS Also AsRock' s Bios fix the Internal PLL Overvoltage for CPU with D2 Revision.. so don t worry about OC :-)
    GOOC 2010 Italy #4
    Apr 2005
    107MHz stable BCLK? Thats very nice.. and they said it was BCLK locked
    That should translate in to memoryspeeds of 107 x 21,33 = 2282MHz
    Jun 2008
    Italy
    ahahha yes was bclk locked :-)
    Next week i will have ripjawx... so i will test also memory
    GOOC 2010 Italy #4
    I am Xtreme
    Dec 2008
    France
    Asrock is getting decent these day. You could give it a try. The board looks good, who knows about the BIOS support in the long run, though...
    Donate to XS forums
  18. #18
    Xtreme Mentor
    Jun 2008
    France - Bx
    I really like this Extreme 6, one of the best quality/equipment/price P67 board.
    Hope I will give her a try
  19. #19
    Apr 2005
    Quote Originally Posted by ScottALot View Post
    After comparing the ASRock Extreme6 against the Asus P8P67 Deluxe I really see your point. The two boards are very similar.
    Both have: 16+2 phase with digital PWM, the same PCIe/PCI slot config, PLX PCIe bridge, UEFI, and the rest of the layout is also very close..
  20. #20
    Mar 2009
    Mine will be here soon.. hope it turns out ok, and BIOS support is good.
    Email/web browsing PC
    MM Ascension case, 24/7 settings
    Classified, 980x @ 4,525Mhz, HT on 1.39V
    (3) ATI 5870's@ 1062Mhz
    G skill perfect storm RAM s 6gb, 2,176 Mhz CAS 8
    (4) intel x25m RAID 0
    CPU loop, EK supreme HF, EK mobo block, 500MM bitspower res, 2 DDC 3.25's on XSPC top, 2 XSPC RX 360's, 1 XSPC RX 480, GPU loop, EK water blocks, with nickel backs, 2 swiftech mcr 320's, 500MM bitspower res, ddc 3.25, XSPC top all with 1850 RPM gentle typhoons
    plus many other rigs.
  21. #21
    Nov 2008
    Nottingham, UK
    Only difference I can see is that the ASUS has Integrated bluetooth, and 1x Intel LAN + 1x Realtek LAN whereas the Asrock has 2x Realtek.
    Personally I went with the P8P67 Pro as it was the cheapest board with Intel LAN, and the ASrock Extreme6 cost slightly more than the P67 Pro here, but if the ASRock was less I probably would've gone with that.
    Don't worry guys, i'm s**t at games but I have 500fps!
    Intel 4670K @ testing
    Corsair H100i
    MSI Z87-G43
    8GB Corsair 1866 CL9
    XFX 7950
    Samsung 830 256GB SSD
    Corsair Vengeance C70 Case
    Tagan 480w PSU
  22. #22
    Jul 2008
    Germany, Stuttgart
    thx mate
    Do you have the BIOS?
  23. #23
    Jan 2011
    Isn't there going to be a problem to use a LGA775 backplate on this motherboard due to the existing backplate that is mounted on all LGA 1155 motherboards? If you look at this picture, it doesn't look that good: http://i837.photobucket.com/albums/z...BrackerMod.jpg
    Maybe it's a better idea to get a LGA1155 hold-down plate and backplate for the cooler you're using and to make sure the cooler sits better. What do you guys think?
  24. #24
    Jul 2007
    Sofia, Bulgaria
    I was thinking of Getting Asrock Extreme4 or Extreme6, but from the reviews I read the max vcore from UEFI is 1.52v which is not enough for 5000+ benches.
    24/7 Asrock P67 Extreme4|2500K @ 4600 @ 1.38v|2x2GB A-data value|XpertVision 8500GT 600/450|WD 6400AAKS|CM 690 + 3 x 140mm + 2 x 120mm|Zalman CPNS-10X Performa|Chieftec 750-14C|Zalman MFC1 Plus
  25. #25
    I am Xtreme
    Dec 2008
    France
    Quote Originally Posted by overcrash View Post
    I bet this will be fixed soon.
    Donate to XS forums
