Results 1 to 6 of 6
Thread: Sandy Bridge bios fixes for multiplier wall (HWbot link)
    Jan 2005
    http://hwbot.org/forum/showthread.php?t=15952
    Seems to fix the multiplier wall for people of 44-48x or so random, leaving you to OC to the chip's limit.
    Boards with updated BIOS in the link:
    GIGABYTE
    - P67A-UD4 (F6x)
    - P67A-UD5 (F5x)
    - P67A-UD7 (F6x)
    ASUS
    - P8P67 Deluxe (1053)
    - P8P67 Pro (1053)
    - Maximus IV Extreme (0653)
    INTEL
    - DP67BG (1780)
    Jan 2008
    5.5 on air! Wow!
    2600k @ 4.6 GHz
    Noctua NH-D14 cooler
    P8Z68-V PRO
    16 GB RAM
    Corsair TX-850
    Two Gigabyte 670 GTX Windforce's in SLI at +60 core/+400 memory (3DMark11 15000P)
    Antec P182
    Crucial M4 SSD
    Win7 x64
    Dell 3007WFP-HC
    Logitech G15 Keyboard & G7 Mouse
    ErgoHuman Chair
    Jul 2005
    Toronto :D
    Is anyone else with an Asus board getting the same problems that I am with newer BIOs? I have a P8P67 Pro.
    0804:For some reason, when I flash to 0804 and start up, it's fine. But when I change anything to my desired settings (overclocking), the computer doesn't actually do it and instead uses OC Tuner as it turns off and on until the result is always 103 x 34. That's all that BIOs does for me.
    new 1053 BIOs: This doesn't even work...the computer will boot with stock settings (nothing changed in BIOs) but if I change anything in BIOs to overclock with, the computer won't boot. It goes into a continuous loop at start up. All I see on the board are the LEDs flashing in the sequence and ending. The red LEDs go from graphics->RAM-> CPU ->graphics -> RAM -> CPU and crashes when it reaches CPU a second time. It then turns off and turns on -> repeat the loop. Nothing ever comes up on screen. It's frustrating to have to clear CMOs every time to boot trying to diagnose the problem. Is there any setting in BIOs that could be triggering this problem?
    Jan 2005
    Quote Originally Posted by deathelement View Post
    Hey just wondering if you ever solved this? I just ordered my 2600K + Asus P8P67 Pro + Civ 5 bundle...
    Xtreme Mentor
    Feb 2009
    Bangkok,Thailand (DamHot)
    I glad to see
    Firstly i think those are CPU Limit
    Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
    EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
    Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
    Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
    [history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
    Oct 2006
    Deathelement, it might have something to do with the way you are flashing it. These boards use EFI and not bios now so maybe something is going wrong with your flashing program?
    Rig 1:
    ASUS P8Z77-V
    Intel i5 3570K @ 4.75GHz
    16GB of Team Xtreme DDR-2666 RAM (11-13-13-35-2T)
    Nvidia GTX 670 4GB SLI
    Rig 2:
    Asus Sabertooth 990FX
    AMD FX-8350 @ 5.6GHz
    16GB of Mushkin DDR-1866 RAM (8-9-8-26-1T)
    AMD 6950 with 6970 bios flash
    Yamakasi Catleap 2B overclocked to 120Hz refresh rate
    Audio-GD FUN DAC unit w/ AD797BRZ opamps
    Sennheiser PC350 headset w/ hero mod
