Gold fittings.. i wonder how that would look in a case >_<
http://www.bitspower.com.hk/catalog/...---------.html
Apple MacBook Air
Apple IPad 2
Those arn't _that_ new, are they? I for one have seen their gold and silver fittings. They look awesome tho. Probably gonna use those gold fittings on my next build.
Project Echo | Fractal-Design Array Rev2 | i5 750 | DFI LANPARTY MI P55-T36 | 2x2GB A-Data | Fractal SFF 300w MDPC-X sleeved orange and black | HD5870 | Kingston V-Series 64GB SSD | 2TB HDD | EK Supreme HF | EK-DCP 4.0 | EK Multioption 250 RES | EK-CoolStream-RAD XT 240 | EK-CoolStream-RAD XT 120 | EK-PSC Fitting 12mm - G1/4 Black | 5870 fullcover block |
Theory | By Hannes ~ A Lian Li sculpture | Lian Li PC-8NB | AMD Phenom II x6 1090T BE | Asus Crosshair IV Formula | Cooler Master V8 | 2x Laing D5 + Bitspower TOP + MOD-kit | Bitspower 250 + 150 RES | EK-CoolStream-RAD XT 240 | 19mm 1/4G Bitspower Shiny Silver + Matte black Fittings, rotaries, fillports, plugs etc etc. | MDPC-X Color -X, Black and White Sleeve.
Sponsors: Lian Li, ASUS, Bitspower, Cooler Master, EkWaterblocks, Misco.se, Fractal-Design, PCB Distribution AB, Coolingstuff.se, Enermax.
New to me.. searched XS.. couldnt find it so i thought i share it here..
If you do use them in your next build.. post pics please![]()
Apple MacBook Air
Apple IPad 2
Ahhhh i will prefer Gold fitting!!!
Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
[history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
Could have been that they are new. And I just gone ahead of myself. I've had some contact with bitspower recently and I dug pretty deep into their inventory. Non the less bro. It's a great find and they do look awesome.
Just image those gold fittings on white acetal.. Mmm![]()
the last new fittings from BP are red
Abit Aw9D Max - Intel E6600 - 2gb Cellshock DDR2 800 4-4-4-12 - BFG 8800GTS - 2x WD Raptor 150gb
Zippy PSL-6850p G1 - Pioneer DVR-S15J - LiteOn DH-20A4P
Cooling by: Loop 1 Ybris A.C.S. - Danger Den Maze4 - HWLabsGTX360 - Laing D5 - EK RES 150
Loop 2 DTek Fuzion gfx - Aircube X2 360 -Laing D5 - Case Custom
Crap. I want those gold & black fillport caps badly![]()
Apple MacBook Air
Apple IPad 2
seriously they look photoshopped :P
where is the best place to buy bitspower gear? (UK based)
i seam to be able to get about 1/10th of them from loads of different shops, mostly ebay.
is there a site that sells the entire collection? or a bitspower shop would be nice.
Define R3 Hydr0 -- Bulldozer, MSI 990FXA, HD 6870, 16gb Crucial Ballistic, Define R3 Black Pearl - Completed -
GIGABYTE Acrylic -- Piledriver, ASRock 990FX, HD 7850, 16gb Crucial Ballistic, GIGABYTE Acyrlic Show Casel - Under Construction -
performance-pcs probably has the best selection, then Frozencpu.
CPUID http://valid.canardpc.com/show_oc.php?id=484051
http://valid.canardpc.com/show_oc.php?id=554982
New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
Desk Build
FX8120 @ 4.6Ghz 24/7 / Asus Crosshair V /HD7970/ 8Gb (4x2Gb) Gskill 2133Mhz / Intel 320 160Gb OS Drive, WD 256GB Game Storage
W/C System
(CPU) Swiftech HD (GPU) EK HD7970 with backplate (RAM) MIPS Ram block (Rad/Pump) 3 x Thermochill 120.3 triple rads and Dual MCP355's with Heatkiller dual top and Cyberdruid Prism res / B*P/Koolance Compression Fittings and Quick Disconnects.
cheers man ill take a look.
im using 8mm ID tubes for my build (looks neater i think and why use 1/2" tubes when the fittings are only 1/4" big, just bottleneck on all the fittings.)
and unfortunetly that hinders my fittings selection.
best ive got so far is 7 90 degree rotary compressions from overclockers.
gah they are all USA sitesi know u have the entire collection there but it will cost me about £30 just to get it into the UK.
Anyone know of any decent UK suppliers of 8mm ID bitspower compressions (preff Black Sparkle)
Edit: sorry i work metric and bitspower is all in old english.
1/4" bitspower fittings is what im after :P
Spazloy: caseking.de is also in Europe and carries Very broad BP fitting selection.
All the shops have patchy stock here unfortunately. As previously mentioned caseking (and highflow.nl too maybe?) could be your best bet.
Try these though:
www.specialtech.co.uk
www.scan.co.uk
www.candccentral.co.uk
www.thewatercoolingshop.co.uk
www.tekheads.co.uk
www.watercoolinguk.co.uk
www.overclockers.co.uk
www.overclock.co.uk
www.ebuyer.com
www.thecoolingshop.com
www.amazon.co.uk (some bits and pieces on there at times)
Thats all I can remember off the top of my head that stock bitspower over here. More than I thought I knew anyway. Specialtech are my favorite - if you contact them they can usually order stuff in for you (may have to pay in advance).
yuh i use specialtech atm, didnt know they did orders tho, ill look into that if i need and specialist pieces.
alsocheers for the euro stockists, if i save up and buy in bulk that will save me some money.
always a helping hand at XS
Waiting for gold colored dye now haha
Signatures make my posts look huge... but I'm not humble enough to completely remove my signature, so I kept this note explaining it.
Scott, just poke Mayhem, he's probably able to mix something that looks a whole lot like gold liquid.
“Little expense had been spared to create the impression that no expense had been spared.” - Hitchhiker's GuideMondays:It's better to ask dumb questions now, than to look stupid later
Ah, you reminded me that I need to poke him again to send me one of his dyes to test... he always forgets because he's busy, but I like free things.
If I had a gold fittings and gold liquid.. lets just say LAN parties would be off limits, people would be tempted.
Lol, either that or you could bring a baseball bat with you![]()
lol my pc is clocked so high that it melts gold :P
