We are pleased to announce the upcoming HD6970 true full cover water bock for Radeon 6900 series. The True full Cover Design solution uses all available mounting holes, and therefore prevents the PCB to bend, either during shipping, or handling. It also protects fragile components during handling/installation of the assembly.
General Design features:
GPU cooling: 0.6 x 0.6mm pin matrix
Moderate pressure drop
Liquid cooled VRM's with hard contact to block for perfect TIM
Compatible with large compression fittings
Compatible with stock HD6970 back-plate
Removable VRM copper plate
Compatible with: HD6970 and HD6950
ETA for introduction: Mid January
Intial test results are as follows:
Bench setup:
CPU: see data
CPU Cooler: Apogee XT
Radiator: MCR320 Drive, Pump @ max speed, 3 x Gentle Typhoon fans @ 12v
Loop setup: serial; quick disconnects: x 4
GPU: HD6970 engineering sample
Test results Summary:
GPU temps at 990Mhz x 1450Mhz under Furmark extreme burn 1920x1080 windowed mode : 43.19C with air ambient of 23.79C and coolant temp of 30.93C
