Page 1 of 3 123 LastLast
Results 1 to 25 of 65
Thread: Gigabyte's P67A-UD4 Sandy Bridge Motherboard Preview
    Administrator
    Nov 2007
    Stockton, CA
    Early next January these boards and the rest of the new line will be released, most likely at CES.
    I recieved today a sample from Gigabyte to run through it's paces and give it a good testing.
    So let's start of with the unboxing of this new board.
    The front and back of the package.
    Opening the box we find the usual assortment of parts & manuals.
    Included in the bundle is:
    Motherboard
    Driver CD
    User manual
    Quick installation guide
    Four SATA cables
    I/O shield
    2-way SLI connector
    Gigabyte's P67A-UD4 Features
    Industry’s leading 12 phase power design for maximum power delivery.
    Onboard SuperSpeed USB 3.0 and SATA 6Gbps to deliver impeccable data transfer speeds.
    GIGABYTE Ultra Durable™ 3 design with 2x Copper PCB to provide the stability, reliability and longevity essential to meet the power needs of high-end processors and other components running today’s most demanding applications and games.
    Unique GIGABYTE 3x USB Power design with On/Off Charge USB ports to offer faster battery charging for iPhone, iPad and iPod devices.
    New Matte Black color PCB offering a stylish new outlook that blends itself to decoration and case mods.
    CrossFireX™ and Nvidia® SLI™ support for ultimate graphics performance
    GIGABYTE patented DualBIOS™ technology delivering the highest level of failure protection.
    Motherboard Pictures
    For additional pictures please go >Here<
    Now about heat sinks.
    It would have been nice if Intel had decided to not come up with a new heat sink mounting hole pattern but it's not the case. How ever heat sinks like the Mega Shadow and a little fugging around will fit as you can see by these photos. The bad news is others that have a more rigid mounting system will not, like Corsairs H70 which I tried to fit, but it would not. So for the most part I think we will need to wait for adapter kits.
    And as you can see here there is plenty of space to mount two fans on the Mega Shadow.
    Some addition pictures of the test setup.
    You can also see that there is plenty of space between a graphic card and the heat sink for added sound cards if wanted.
    Special thanks to Gigabyte for sending this sample !
    Aug 2007
    Arlington VA
    WTF is with the position of those ram slots.
    AMD Phenom II BE, ASUS Crosshair II formula, 8gb ddr2 800, 470 SLI, PC P&C 750, arcera RAID, 4x OCZ Vertex2, 2x samsung 7200 1tb, HT Omega Clario +
    Feb 2009
    Lima, Peru
    I wonder how funny it will look if that "Ati Crossfire X" logo(below pci-e slot) change to you know what.
    I like the box art.
    Athlon II X4 620 2.6Ghz @1.1125v | Foxconn A7DA-S (790GX) | 2x2GB OCZ Platinum DDR2 1066
    | Gigabyte HD4770 | Seagate 7200.12 3x1TB | Samsung F4 HD204UI 2x2TB | LG H10N | OCZ StealthXStream 500w| Coolermaster Hyper 212+ | Compaq MV740 17"
    Stock HSF: 18°C idle / 37°C load (15°C ambient)
    Hyper 212+: 16°C idle / 29°C load (15°C ambient)
    Why AMD Radeon rumors/leaks "are not always accurate"
    Reality check
    Xtreme Guru
    Jun 2010
    In the Land down -under-
    Using push/pull looks like your gonna lose out on 2x dimm slots, Thanks for the post havent seen the UD4 as of now
    Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
    I am Xtreme
    Jan 2006
    Australia! :)
    the cooling on the mobo is so..minimal.. just one heatsink & a rather obscure one at that! (oh ok, & the mosfets blahblahblah)
    & yeah, the ram slots need to be pushed away from the cpu a lil maybe
    DNA = Design Not Accident
    DNA = Darwin Not Accurate
    heatware / ebay
    HARDWARE I only own Xeons, Extreme Editions & Lian Li's
    https://prism-break.org/
    Feb 2007
    perfect cooling, just the way I like it.
    Administrator
    Nov 2007
    Stockton, CA
    The RAM slots are no different than many motherboards. When you go to two fans on these large heat sinks this often happens. You can drop the second fan for max load out, or get larger capacity DIM's.
    Either way I don't think dropping the second fan will make a super lot of difference.
    Administrator
    Nov 2007
    Stockton, CA
    Yeah looks like I have those DIM's in incorrect.
    I have been running to many AMD setups lately LOL
    They go Slots 1,2,3,4
    If 2 sticks are used they go in Slot 1,3 or 2,4
    It's running now in 3,4 tho LOL
    May 2009
    São Paulo, Brazil
    Any idea on launch prices?
    Jan 2005
    Slovenia
    Double post...sorry
    i7 2600K /TRUE Black|Gigabyte P67A-UD4|4GB G.Skill ECO 1600MHz CL7|Gigabyte GTX460 768MB OC SLI|Crucial RealSSD C300 64GB RAID0|Cooler Master Cosmos S|Enermax Revo85+ 850W
    Jan 2005
    Slovenia
    Here is the weird thing about the P67A-UD4: all its memory sockets are black. If you have two memory modules, you will have to install the first module in the first memory socket and the second module in the third socket in order to enable dual-channel architecture. Since all sockets are black, users may think that they can install memory modules in any two sockets, which is not the case. This is a serious mistake coming from a tier 1 manufacturer. Hardwaresecrets
    Price for P67A-UD4 170-180€ in EU...
    Xtreme Cruncher
    Jan 2008
    Finland
    Quote Originally Posted by Buckeye View Post
    did they fit? it looks very tight :/
    Intel i7 2600k, Asus p8p67 EVO, Thermalright Archon, G.Skill RipjawsX 8GB, Asus EAH6970 DCII, Corsair AX850W, Asus xonar essence ST, Coolermaster HAF 932,
    Crucial C300 128GB, WD Caviar Black 1 TB, Samsung F3 1TB.
    The world needs your support.
    Join The XS WCG team and help cure Cancer, AIDS, and other diseases.
    Xtreme Mentor
    Feb 2009
    Bangkok,Thailand (DamHot)
    NO FUN FOR RAM Overclocker ???? Only max 2133Mhz @ BCLK100Mhz
    BCLK Suck!!!
    Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
    EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
    Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
    Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
    [history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
    Mar 2009
    Quote Originally Posted by jurc_podgurc View Post
    for most of history the slots were the same color. it doesn't matter because you can install memory wherever you want and the real world performance doesn't change.
    you have been tricked by marketing designed to sell you more low density memory sticks.
    Mar 2009
    Quote Originally Posted by tiro_uspsss View Post
    think it matters? no. ALL fancy cooling is just for looks. it is like a magazine cover they are trying to sell more product to anyone they can trick.
    have a look at a much better, much higher power motherboard: http://www.newegg.com/Product/Produc...82E16813182174
    p67 probably doesn't need two thimbles of aluminum for its heatsinks.
    V3 Xeons coming soon!
    Nov 2005
    New Hampshire
    Nice review and as usual GB has a good looking board..
    The XS WCG team needs your support.
    A good project with good goals.
    Come join us,get that warm fuzzy feeling that you've done something good for mankind.
    Quote Originally Posted by Frisch View Post
    If you have lost faith in humanity, then hold a newborn in your hands.
    Administrator
    Nov 2007
    Stockton, CA
    Marketing slide info for your enjoyment.
  18. #18
    I am Xtreme
    Dec 2008
    France
    Not sure how I missed this... Lots of slides, some good info here. Thanks, my friend, and well done!
    Nice looking board, by the way. Not as good as UD7, seems to pack a lot of tech goodies being a budget board. Good colour scheme, too.
    Donate to XS forums
  19. #19
    Administrator
    Nov 2007
    Stockton, CA
    Quote Originally Posted by zalbard View Post
    You didn't miss this Zal buddy. I just put it up
  20. #20
    Dec 2007
    Hungary (EU)
    Driver Mosfer.... MSI have been using DrMOS for years. Good morning dear Gigabyte.
    The other "new" feature is the Gigabyte Auto Dual Power Switching which is the copy of MSI's Active Phase Switching.
    So, are these Gigabyte's innovations?
  21. #21
    I am Xtreme
    Dec 2004
    France
    Quote Originally Posted by Oliverda View Post
    Wrong Gigabyte has been using DrMOS for many many years, and they use a better brand than MSI, they do not post this publicly. Driver Mosfets are on all of their x58 boards, and have been on many other boards. MSI just advertises it, Gigabyte does not.
    Active phase switching has been around the same period of time, gigabyte uses better components, and MSI(1+MHz switching)MOSFET equal to 4 mosfets of other companies???? Gigabyte's outputs teh same power but uses 8-24 phases, MSi uses 8 or 6 some small number. Gigabyte advertises in a different way.
    Gigabyte has two types of phase switching, MSi is not innovator.
  22. #22
    Dec 2007
    Hungary (EU)
    Quote Originally Posted by sin0822 View Post
    Orly? Which was Gigabyte's fist DrMOS equipped mobo?
    Similar question. Which was Gigabyte's fist active phase switching supported mobo? And please tell me about that "better components" and that 24 phases (marketing) PWM. I'm all ears...I mean eyes.
  23. #23
    I am Xtreme
    Dec 2004
    France
    The count on the Driver MOSFETs, I am unsure of which was their first, but all X58 board have Driver Mosfets which is DrMOS. It has to do with the output on the driver MOSFETs. Gigabyte uses a seperate iTE chip for phase gearing and switching. What were the first MSI boards? DrMOS was used instead of old fashioned highside and lowside mosfets with a separate driver.
    The PWM is just the controller for the phases, the VRm is the phase design, so the MOSFETs are part of the VRM, not PWM. Rensas is what MSI uses on their newest board, Gigabyte Vishay made MOSFETs output the same amperage, and on top of that you can actually go and multiply single MOSFET output by number of MOSFETs. MSIs 6 phase +1 is one MOSFET per channel, Gigabyte uses 4 MOSFETs per channel, but each of gigabyte's mosfets are equal to MSI's in output, so in reality if MSi can multiply their phases by 4 than gigabyte can too.
    That is all I am going to say, FYI gigabyte makes their own boards as well, which almost no OEMs do anymore. Foxconn and ECS are their makers now, You want more info read my review ont he X58A-UD5 or P67A-UD7 skip to VRM design on both boards, you will learn a lot.
  24. #24
    I am Xtreme
    Aug 2008
    buckeye
    checkout the thermalright archon....do you think it will let ram fit?
  25. #25
    Dec 2007
    Hungary (EU)
    Sorry but you're wrong.
    UD7
    I can't see DrMOS on the above X58 mobo. If I'm not mistaken then the first and only (so far) Gigabyte mobo which uses DrMOS is the UD9.
    "Having said that, Unlocked Power is not solely about phases. Gigabyte have replaced their traditional motherboard power design and are now using more modern integrated Driver-MOSFET chips, which differ from standard MOSFETs in that they feature a 3-in-1 design with the Driver IC, top MOSFET, and bottom MOSFET all in one package. Among other things these new MOSFETs have faster transient response, provide more stable the power to the CPU, and more efficient."
    source
    MSI uses DrMOS (and APS) since the mid of 2008. MSI's first DrMOS equipped mobo was the P45 Diamond. Check this short presentation.
