The Corsair CX430 has finally been reviewed. It is a 300W power supply. Not a 380W as previously believed. A 300W.
That's the gist of it. If you'd like to hear my more eloquent explanation, the 4:30 talk is to be found here:
http://www.mediafire.com/?9aauds6y2l3raw4
Correction: When it sounds like I say "Samsung" capacitor, I'm actually trying to say "SamXon" but messing up. SamXon is a cheap Chinese brand, not the absolute worst but not very good. Cheap primary side capacitors lead to lower efficiency, higher AC ripple, and worse hold-up times.
Corsair is not getting a single recommendation from me as long as this product is available. Certainly not for the CX series. The TX, VX, and HX PSUs will be low on my recommendation list. And if you want an AX series power supply, tell Corsair to go stuff it and buy the same thing from SeaSonic.
Corsair,
I am disappoint.
