Results 1 to 7 of 7
Thread: GTX580 voltage mod succeeded
    Oct 2010
    South Korea
    I just flash ASUS ENGTX580 bios to EVGA card and succeeded.
    (using NVFlash 5.100 in DOS, TechPowerUp's ASUS 580 bios)
    Pure EVGA bios provides 1.1375V and ASUS bios offers 1.2125V.
    Default core clock is also up by 10MHz and I guess its memory voltage is also increased though mem clock remains unchanged - the reason why I guess so is that, when OCing memory, EVGA@ASUS provides "much more" headroom than pure EVGA.
    Pure EVGA: mem clock is bounded around 1045MHz (4180 effective)
    EVGA@ASUS: mem clock is bdd around 1225MHz (4900 effective)
ID:	110101   Click image for larger version.
    My Blog: http://udteam.tistory.com
    CPU: AMD FX-8150P
    Cooler: Antec KÜHLER H2O 920
    M/B: ASUS CROSSHAIR V FORMULA
    RAM: Samsung DDR3 PC3-10600 4GB x 2
    VGA: HIS & Sapphire Radeon HD 6990 4GB x 2
    Storage: Intel SSD 510 Series 120GB + Seagate Barracuda Green 2TB
    PSU: Antec True Power Quattro 1200
    Case: Lian Li PC-X500FX
    O/S: Microsoft Windows 7 Enterprise 64-bit
    Mar 2004
    Any chance of a step by step guide, or link to instructions?
    RAIDer
    Jul 2005
    Norway
    Quote Originally Posted by ORVILLE View Post
    Yes we need indeed
    Mar 2009
    Brazil
    1 - Format an USB drive as boot. Don't know??? Learn here: http://www.bay-wolf.com/usbmemstick.htm
    2 - Download NVflash plus Asus bios plus original NVidia bios from here: http://www.mediafire.com/?655mo5l5p6a067f
    3 - Extract all the files (files only, not the folder) in to the USB drive
    4 - Boot from USB drive
    5 - In DOS mode, use the command: nvflash -4 -5 -6 asus.rom
    6 - ctrl + alt + del for reboot
    7 - reinstall video driver if necessary
    PS: if you use more than one vga (SLI or tri-SLI), use the commands:
    nvflash -i0 -4 -5 -6 asus.rom ...... this for the first vga (-i "zero")
    nvflash -i1 -4 -5 -6 asus.rom ...... this for the second
    nvflash -i2 -4 -5 -6 asus.rom ...... this for the third
    Sorry for my english.
    i7 3930k + Koolance CPU-370 + MCP35X + Black Ice GTX360 + Hailea HC-500A + Alphacool VPP655 || Asus Rampage IV Black Edition + EK-FB Asus R4BE || 4 x4GB Corsair Dominator Platinum 2400C9 || 4x Sapphire HD 7970 OC + Koolance VID-AR797 + RP-452X2 + 2x MCP655-B + 2x Black Ice GTX360 || SSD OCZ Vertex 3 240GB + Agility 3 60GB + WD Caviar Black 2TB + WD VelociRaptor 300GB + 2x Seagate 1.5TB 32MB + Seagate 3TB || 2x Corsair AX1200W || Logitech Z-5500 + G13 + G500s + G930 || Mountain Mods Extended Ascension || Dell U2711 27"
    Mar 2006
    Sydney , Australia
    Does nvflash work within Windows ? Or safest via DOS boot disk?
    Edit: jeez i know I have done this before but not in a long time .... now I use the Hp tool and the three main files dont appear on the usb stick yet when I try to copy them over windows says they are already there and do I want to overwrite, I tried yes and no yet they still are not visible, also the pc wont boot from the usb as it doesnt appear to see the three dos os files .... wtf .... is this due to Win7? Or because the stick is fat32?
    Bencher/Gamer(1) 4930K - Asus R4E - 2x R9 290x - G.skill Pi 2200c7 or Team 2400LV 4x4GB - EK Supreme HF - SR1-420 - Qnix 2560x1440
    Netbox AMD 5600K - Gigabyte mitx - Aten DVI/USB/120Hz KVM
    PB 1xTitan=16453(3D11), 1xGTX680=13343(3D11), 1x GTX580=8733(3D11)38000(3D06) 1x7970=12059(3D11)40000(vantage)395k(AM3) Folding for team 24
    AUSTRALIAN DRAG RACING http://www.youtube.com/watch?v=OFsbfEIy3Yw
    Jun 2007
    Bay Area
    @aussie-revhead: assuming you did everything correctly, then it's just your usb stick being stupid (doesn't matter win7, you could try format to FAT instead, useful for smaller usb sticks like 512MB or less). i've had a few usb sticks that refused to work correctly for some unknown reason (mostly the newer hp ones). sandisk ones always worked well for me. use nvflash in dos mode only. otherwise you would use winflash or something like that. but i dont trust it, so i always do it in dos mode.
    1. INTEL E5200 M0 (200x12.5 @1.175), Abit IP-35Pro, 2x2GB DDR2-1000, GT240
    2. INTEL i7-920 C0 (200x19 @1.275), Gigabyte EX58-UD4P, 4x4GB DDR3-1333, GTX680 FTW+ 4GB
    heat
    Mar 2006
    Sydney , Australia
    I tried another stick and it did the same thing ... weird.... is it the 64bit environment? Will a 32bit install fix this problem or do I need to dig up an old pc?
