Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Thread: test BIOS HD6870 1.45v
    Feb 2007
    Denmark
    Get it here,the bios whit 1.45v
    SAPPHIRE ATI HD6870 TEST BIOS 1.45v
    MSIafterburner /GPU-Z read it to 1.445v
    THIS bios is not from SAPPHIRE
    http://www.octeamdenmark.com/forums/...870-1-45v.html
    plz report back
    Aug 2004
    Brasil, S.P.
    latest atiflash I could find don't work...
    any hint?
    990FXA-UD3 | FX8350@4.7Ghz | Asus HD7870 | 2x 4GB Crucial Ballistix Tracer 2050Mhz 8-8-8-22 | AX850W |SSD Vertex3 Max IOPS 120GB | Auzentech Forte + TAPCO-S5
    EK Supreme Full-Gold | XSPC RX240 + EX120 | MCP35x | 3x Koolance Blue Led @PWM | Tygon Black 1/2 | Bitspower Compression | @ FM CM690 I
    Feb 2007
    Denmark
    dos to HD6870
    you can not use winflash,you ned to dos flash.
    ATIFLASH -p -f 0 6870.rom
    http://www.octeamdenmark.com/downloa...6870flash.html
    you can take the 2 files here and overwrite with your own, then it would like to work
    Aug 2004
    Brasil, S.P.
    Quote Originally Posted by Martin.v.r View Post
    i know about it, but atiflash 3.79 doesn't flash 6870s
    Feb 2007
    Denmark
    I use a old 3.5X ATIflash an edit this 2 fill ,to ATIFLASH ? an I can flash
    ATIflash/bios,Do not be in some folder
    you must swap the 2 fill, in addition to the org / or overwrite them
    if the files are in a folder, you can not flash
    Attached Images Attached Images
    Feb 2008
    Belanda
    Download the xfx6850bios, inside is also atiflash v3.83, use that for the bios mentioned above.
    http://www.hardwarecanucks.com/news/...dle-fan-speed/
    i7 2600K Batch L039B470.
    Asus Maximus IV-Gene-Z
    Single Stage
    RipJawsX 4gb 2133 7-9-7-27-1T
    H2O 6970
    _______________________________________
    Xtreme X.I.P.
    Nov 2002
    Shipai
    geez, 1.45v?
    come on guys, post some numbers! keep smelling the rig every now and then tho to make sure you dont burn anything
    Feb 2007
    Denmark
    max test here on air is 1.525v whit 6870
    Mar 2009
    Sunny South Florida
    Geez... I was waiting for a cold front in South FLorida to test 1.40... how safe is 1.45 on a 6870 on air????
    Intel System
    CPU: Intel i7 990x ES @ 4.2GHz 24/7 still kicking!
    Mobo: Foxconn BloodRage X58 P11 Bios
    Ram: Corsair Dominator 12GB DDR3
    Water Cooling: Apogee XT, MCP655-B pump, MCR220 radiator, XSPC 5.25" Bay reservoir
    Videocard: EVGA Nvidia FTW+ GTX 1060 6GB
    OS HDD: Samsung 950 Pro 512 MB M.2
    Strorage HDD: W.D. VelociRaptor 300GB
    Storage HDD: W.D. 500GB
    PSU: Enermax Evo Galaxy 1250 Watt
    Case: Cooler Master Cosmos S
    Roms: Lite On DVD Burner
    Roms: Asus Bluray Burner
    OS: Windows 7 Ultimate 64-bit
    Feb 2007
    Denmark
    you can flash whit the bios,an use MSI afterburner to set it to 1.4v I use org aír cooling on the 6870
    Aug 2004
    Brasil, S.P.
    Quote Originally Posted by Bullu$ View Post
    You did hardmodded yours right? any difference between hard and software mod?
    Oct 2010
    香港 , Hong Kong
    1.45V
    Very hot on air ?
    Burn Card ?
    Mar 2009
    Sunny South Florida
    I won't flash the bios. I can just use Afterburner to go past 1.40v with AB 2.1 beta 4 .
    I am going to wait till I get my 980x/990x though. Hopefully tomorrow I will have it and in by Sunday.
    Intel System
    Aug 2004
    Brasil, S.P.
    Quote Originally Posted by CobraXP View Post
    link for download?
    This bios has higher CCC Overclocking limits also?
    I tried theis afterburner version and it maxxed out at 1.30v here...
    Feb 2008
    Belanda
    Quote Originally Posted by Barr3l Rid3r View Post
    Nope.
    Single Stage
    H2O 6970
    Mar 2009
    Sunny South Florida
    link for download?
    It is not exactly AB but a tool used for with AB that lets you change the voltage limit. It has been out for awhile.
    http://www.overclock.net/ati/861293-...-unlocker.html
    Intel System
    Feb 2007
    Denmark
    UNLOCK msi afterburner,but 1.525v is max on air here rum temp 22c max load temp 74c
    1.45v bios is ok,whit air cooling
  18. #18
    Mar 2009
    Sunny South Florida
    It was 14c in my room this morning. I got to 1080/1190 with room at 18c and 1.35v before. I will give it a shot this weekend IF I get my new 980x/990x.
    Intel System
  19. #19
    Aug 2004
    Brasil, S.P.
    can you guys post a link for this unlocker utility? the official link was removed.
  20. #20
    Mar 2009
    Sunny South Florida
    I don't have a link. I grabbed it before it was removed. There might be a link by someone else in that thread. I don't want to upset anyone or get someone in trouble but it is out there. The is no "official link" and it is not an official tool for AB or anything having to do with AB's creator or MSI.
    Intel System
  21. #21
    Feb 2007
    Denmark
    use the bios
  22. #22
    Aug 2004
    Brasil, S.P.
    i got all i need, just missing patience and colder temps.
  23. #23
    Mar 2009
    Sunny South Florida
    use the bios
    I would be easier to raise the voltage instead of lowing the voltage right? I have done a few cards flashing them but only reason was couldn't change the voltage and needed a diff bios. I would rather not if I don't need to for warranty reasons.
    Intel System
  24. #24
  25. #25
    Mar 2009
    Sunny South Florida
    Has anyone tried 1.45v on a HD 6870 yet?
    Intel System
