here's mine:
mcw50-t on the 9800Pro and a mcw50-t on the NF7(it doesn't need it anymore.. stock cooler is enough)
here's mine:
Stangman... NICE SETUP THATS A LOT OF WATERBLOCKS!
Sandman.... Thanks. But dont you have a phase change rig? Why dont you post it?
20026 01 <-- 9500 NP (on air) CPU TEC Cooled.
With detail settings maxed, full PS and VS support, and highest resolution available, my life runs at 60FPS solid.Originally posted by FUGGER
Just the live video sex chat girls come to mind, not that I know anything about that![]()
Lol, no.
Still on water, waiting for some cash to get my TEC rig.
You can give me yours if you want
My setup will be this: Maze3-1->chevette->Maze4-1gpu->thermochill 120.1->via aqua 1300
then, I'm planning to get a quiet one 600 and go two seperate loops.
just be sure to post it when ya get it. We TEC boys are a rare breed. it's hard being the middle man between air/water and phase change![]()
No kidding.........
lol, thanks man. it's a big PITA, i can't stand it anymore hahaOriginally posted by Slickthellama
Stangman... NICE SETUP THATS A LOT OF WATERBLOCKS!![]()
Stang_Man, mate! Great piccies and fantastic job you did there.
Ellaborate clamping systems you are employing there, my young Paduan. I see with you Force is, hmmm
*chuckle*, *LOL*
Great job, again.
I see you volt modded your raddy, what volts on what are you running now?
2V gpu, 3V ramOriginally posted by Jabo
*chuckle*, *LOL*
Great job, again.
thanks![]()
My setup will be online soon (1x172w on GPU and 1x80w on NB)
I'll keep u posted![]()
Pifast:
Socket 754 3700+ Clawhammer action:
39.64sec 11*285 2.5-3-3-7
Now Pifast @ 3306MHZ !!! 37.72sec World record!
Now SuperPi 1M @ 3306mhz 26.922sec World record!
Ministry of Overclocking Contests
Bloody H311, am I missing something here? Your vid ram runs quite high volts yet I am either blind or there is no additional cooling to vid mem chips! (aren't they suppose to be running 2.5 volts at stock???)Originally posted by Stang_Man
2V gpu, 3V ram
thanks![]()
How do power you pelts?
Im thinking of getting a whole heap of second hand pelts and turning my waterchiller into a pelt system tooo.
Finally after some serious miss hap, I have set-up my first Pelt system.
Configs:
Intel P4 2.4C MO @ 3.0Ghz, Cooling>> LR Cascade
Asus P4P800 VDimm Mod
2 x Twinmos Twisters DDR500@ CL2.5-4-4-8
Memory Ratio: 1:1
Sapphire Radeon 9800 Pro, Cooling>> Swiftech MCW50-T
Gpu and Memory Mod@ 1.8v/2.8v Core/Memory
Thermochill 120.3 Rad with Eheim 1250 pump
Antec TP 480W
Overall Rig Pic:
98 Pro Front and Back
3DMark Score:
If I up my Gpu/Memory to 1.875v/2.875v I think I can squeeze a bit more.I also have not tested my TwinMos RAMs to it's max. That will be another story.
What vcore are you running?
As in CPU Vcore? 1.56v.Originally posted by sandman
man, give it some more voltage.
I think you'll see 3.4+ with 1.65-1.7V
Im doing the same thing, but only on the GPU. The CPU will be a normal(BUDGET!).Originally posted by kommando
And im doing the same loop as htkm1.
htkm1: why between your CPU and GPU block you have some orings???
I think they are to keep the tubing fron kinking.
Ok, thats wath i was thinking.
THX![]()
That with a 156W. Should be getting it back up within the next month with 226W and beefier cooling, in a new case.
AXP1700+ JIUHB 0302 @ 2400MHz - TEC-Watercooled in The Skyscraper
ABIT NF7-S, Sapphire Radeon 9500 Pro, 1.5GB XMS3200C2
XS IRC channel: irc.quakenet.net #xtremesystems
www.ocfaq.com
KnightElite -> blue goo, is it liquid electrical tape?
Which Swiffy block is that you modded?
htkm1 -> great pictures (size wise too) and very nice setup producing respectable overclocks. What are your water temps? Do you have CPU TECed too?
Sorry but their is no sensor for water temp. and no, don't have a Cpu TEC. I have been eyeing to get a Cpu TEC but seems Swiftech only has TEC for Intel. I have both AMD and Intel so I wanna try both. Seems DD is the only that has TEC for both Cpu's. Or should I say has Adaptors for AMD ans Intel. Any recommendation?Originally posted by Jabo
The blue goo is RTV Silicone Gasket Maker.Originally posted by Jabo
The block is an MCW462-UH with the TEC conversion kit, with a 156W TEC. I have since gotten a 226W TEC for it.
www.ocfaq.com
Knight -> how big is your temp difference between 156 and 226? Have you tried it yet?
hktm1 ->DD seems to be the choice for TEC AMD assy, it's a pity they don't do one for AMDs at Swiftech.... Maybe there's a way of modding straight water AMD block to TEC block?
Haven't tried it yet. Once I get this new case up and running, then I will get it tried, but there will be other variables affecting it as well.
www.ocfaq.com
ok this is my system maze4-1 226w tec
