As of the Catalst 10.9 (AHCI drivers,) AMD now officially supports TRIM,
http://www.rage3d.com/index.php?cat=75#newsid33970627
Does that add trim for the SB750 also?
Im still using the ms driver because intel ssd toolbox wouldnt work with the amd drivers iirc.
Main Rig: x6 1090T @ 4228Mhz 1.53v, 3000NB 1.32v | GA-990FXA-UD3 F3b | 4GB G.Skill Ripjaws 1333 7-8-8 | XFX6950(unlocked) 950/1450 | Corsair AX-850 | X-25m 80GB G2 | 4x Samsung 1TB F3 Raid5 w/ Perc5i | U2311H | NesteQ FanMax 8 | Dimastech Easy Dual V2.5
Watercooling: EK Supreme HF 'Gold' | EK FC-6970 | DDC 3.2 | MCR320 | MCRes Micro Rev2 | 3x GT 1850 |
Notebook: Asus UL30VT
intel ssd toolbox doesnt work for me with the trim supported drivers
also... it might support trim for sb750
Thanks for the heads up erek
But if TRIM is working ok we shoudln't need to run that intel toolbox utility then right?
What does it do for performance?
thanks
On my Q6600/Intel platform I used to get 260MB/s read speeds. Since moving to SB850 - I get about 240-250MB/s.
4960X@4.7 | Asus RIVF | 16Gb@2400 | 256Gb 840 Pro | R9 290 | AX-860W | 540Air | Custom W/C
I have 5.9 points on Windows Experience Index using the SB850 controller in AHCI mode, and 7.5 using IDE. It feels faster, it loads faster... it is faster as IDE, even on benchmarks (330MB/s vs 300MB/s).
Windows IDE drivers support TRIM, apart from maybe some benchmarks, how faster can AMD drivers be? I didn't install them before because they didn't have TRIM.
Main: Windows 10 Core i7 5820K @ 4500Mhz, Corsair H100i, 32GB DDR4-2800, eVGA GTX980 Ti, Kingston SSDNow 240GB, Crucial C300 64GB Cache + WD 1.5TB Green, Asus X99-A/USB3.1
ESXi Server 6.5 Xeon E5 2670, 64GB DDR3-1600, 1TB, Intel DX79SR, 4xIntel 1Gbps
ESXi Server 6.0 Xeon E5 2650L v3, 64GB DDR4-2400, 1TB, Asrock X99 Xtreme4, 4xIntel 1Gbps
FreeNAS 9.10 x64 Xeon X3430 , 32GB DDR3-1600, 3x(3x1TB) WD Blue, Intel S3420GPRX, 4xIntel 1Gbps
IDE drivers don't support TRIM mate - AHCI is required for TRIM.
And I wouldn't use WEI to measure SSD performance - it sucks!
Use ASSD or CrystalMark![]()
Screenies speak for themselves - slight improvement in performance using the AMD drivers. Still need to figure out if they actually support TRIM lol
Nope. AHCI is required for NCQ, not for TRIM. Microsoft AHCI and IDE drivers BOTH support TRIM.
I use HDTune and in IDE mode works faster than in AHCI mode, both using Microsoft drivers, because AMD AHCI driver didn't support TRIM. Now that it does, I guess I'll have to test it.
