Model: G.SKILL Ripjaws F3-12800CL7D-8GBRH (2 x 4GB)
Brand: G.SKILL
Series: Ripjaws Series
Model: F3-12800CL7D-8GBRH
Type: 240-Pin DDR3 SDRAM
Capacity: 8GB (2 x 4GB)
Speed: DDR3 1600 (PC3 12800)
Cas Latency: 7
Timing: 7-8-7-24
Voltage: 1.6V
Multi-channel Kit: Dual Channel Kit
Heat Spreader: Yes
Features: Compatible Chipset: Intel P55
Manufacturer Warranty
Parts: Lifetime limited
Labor: Lifetime limited
YOUNGPRO Tests
http://www.xtremesystems.org/forums/...1&postcount=27
http://www.xtremesystems.org/forums/...6&postcount=52
http://www.xtremesystems.org/forums/...2&postcount=53
CHEW Tests AMD
http://www.xtremesystems.org/forums/...0&postcount=24
http://www.xtremesystems.org/forums/...2&postcount=26
http://www.xtremesystems.org/forums/...6&postcount=43
http://www.xtremesystems.org/forums/...2&postcount=74
Pt1t Tests
http://www.xtremesystems.org/forums/...3&postcount=20
Hiwa Tests
http://www.xtremesystems.org/forums/...82&postcount=2
http://www.xtremesystems.org/forums/...50&postcount=9
http://www.xtremesystems.org/forums/...0&postcount=18
http://www.xtremesystems.org/forums/...6&postcount=29
http://www.xtremesystems.org/forums/...0&postcount=30
http://www.xtremesystems.org/forums/...1&postcount=46
TinTin Tests
http://www.xtremesystems.org/forums/...2&postcount=38
Kentaro Tests
http://www.xtremesystems.org/forums/...5&postcount=36
Afrokalle Tests
http://www.xtremesystems.org/forums/...5&postcount=45
http://www.xtremesystems.org/forums/...5&postcount=76
Reviews
http://www.3dgameman.com/reviews/118...nel-8gb-memory
http://aphnetworks.com/reviews/g_ski...8gbrh_2x4gb/10
http://www.xtremesystems.org/forums/...9&postcount=60
