http://www.techpowerup.com/132662/Ye...hics-Card.html
Now that AMD seems to have given the 40 nm Juniper GPU (on which are based the Radeon HD 5700 series models) a new lease of life, manufacturers can continue to get innovative with the Radeon HD 5770 GPU. One such board partner, Yeston, designed a Radeon HD 5770 X2 graphics card, which simply put, is a dual-GPU graphics accelerator that makes use of two Radeon HD 5770 GPUs, each with its own 1 GB of GDDR5 memory, that share the PCI-Express interface using a PLX-made bridge chip (perhaps the same one used on the Radeon HD 5970).
bit crazy thingbut be aware that some sources says that this will have lucid hydra instead plx bridge (in witch i dont belive).
This will offer extreme bang-for-buck/bang-for-power.
but it should do 6!
