Page 1 of 6 1234 ... LastLast
Results 1 to 25 of 145
Thread: First build (PROJECT CARBON) 800D
    Jun 2010
    Hamburg Pa USA
    Uploaded with ImageShack.us
    This is my first build and yes i know its agressive but GO BIG OR GO HOME
    seriously In a retired/legaly blind old car guy who needed a project and thought this would be cool. I spent the last 8 months studying the forums and coming up with ideas. SO here it is.
    CASE
    CORSAIR 800D BLACK
    Blank back door for front to be modded
    Mountain MODS
    Tripple 120 panel 9x24 blank panel 18x24 blank panel
    Back plate & I/O Insert both Anodized Black
    MNPCTECH
    360 degree 3x120 2x120 (2) 120 anodized black fan grills
    Anodized black Vandal Switch Panel
    Anodized black custom plate for Aqua Computer Filter X2
    Anodized black custom plate for Crystal Fontz LCD with project name.
    Anodized 3 1/2 bay cover
    Bill and I are still working on ideas for front door
    ODDS & ENDS
    3M DI-NOC CARBON FIBER film Black
    Black Acustical pad
    Black 1/16 round hole Modders Mesh
    CONTROL
    Aquario 4.0 with power adjust with black face plate
    Aquacomputer Power adjust 2 (X3) with Black face plate
    SYSTEM
    EVGA X58 SLI LE BOARD
    Proccsor undecided
    RAM Corsair Dominator GT 12G of something
    Storage SSD undecided
    GPU Either 465X2 or 470x2
    LOOP1
    Swifttech MPC350 12v ( x2)
    XSPC Dual Top
    XSPC RX360 Rad
    XSPC RASA CPU Cooler Black
    Primochill 7/16 X5/8 Tubing clear
    Aqua Filter
    Aqua Flow Sensor
    Aqua Ram Plex (X2)
    Aqua nickel plated res with Black 5 1/2 bay Panel
    M.I.P.S. Mother board Blocks Black/ Nickel
    Bitspower Fittings
    LOOP2
    Swifttech MPC350 12v (X2)
    XSPC Dual Top
    XSPC RX240 rad
    Aqua Filter
    Aqua Flow Sensor
    Aqua Twin Plex
    Aqua 465/470 nickel GPU Blocks (x2) back plates If I can find ones to fit
    Danger Den RES
    Primochill 7/16 X 5/8 Tubing Clear
    Extra Stuff
    MDPC SLEEVE BlacK & Purple for wires
    Black 5/8 sleeve for tubing
    Srews Snap Caps Rivets Clamps Tools
    Some purple LED's for mood lighting in pump tops and res
    IF I missed anything it wont fit
    THE ABOVE IS SUBJECT TO CHANGE WITHOUT NOTICE
    Jun 2010
    Hamburg Pa USA
    Jun 2010
    Hamburg Pa USA
    If something looks off your correct. I cut down the hotswap bays to two. this allowed for a shelf for one set of pumps
    Jun 2010
    Hamburg Pa USA
    Jun 2010
    Hamburg Pa USA
    Oct 2007
    I'll be watching this as I am in the middle of a 700D build. Looks like you stripped the powdercoat from the case. how did you approach the removal of it?
    Corsair 700D
    Intel i7 920 @ 4.20|Asus P6T6 Revolution|G.Skill 6gb DDR3 1600|Zotac GTX480|Intel x-25-M 80GB x 2 / Raid0
    H2O
    |Perfecting the Obsidian series case. Build log to follow soon...|
    Jun 2010
    Hamburg Pa USA
    I used a portable media blaster with 80 grit. I got mine at harbor Freight real cheap.
    You can use 80 grit sand paper and rough it up real good. this will work also I'm just bit anal about painting.
    Jun 2010
    Hamburg Pa USA
    I got the back door covered with carbon fiber sheet. I think it came out well better then I thought.
    Oct 2007
    doors look great. any plans to use a better camera?
    Corsair 700D
    H2O
    Jun 2010
    Hamburg Pa USA
    working on a new camera but i'm not sure how much difference it will make since i'm legaly blind hey we will try
    Thats BLIND not BLOND
    Feb 2010
    Wisconsin
    This looks promising! Is this your first build or just your first watercooled build?
    Signatures make my posts look huge... but I'm not humble enough to completely remove my signature, so I kept this note explaining it.
    Jun 2010
    Hamburg Pa USA
    The only thing I put together was an 800D with EVGA X58 LE, H50. i-7 920 & gtx260. no mods Its what I use as my every day desktop. I had help with that from my son and got hooked.
    Jun 2010
    Hamburg Pa USA
    Received picture of my new plate for Aqua filter. Looks real good now needs anodized black Great job Bill
    Aug 2009
    Columbus, OH
    Much better than what I did with my 800D
    Good Luck!
    Jun 2010
    Hamburg Pa USA
    thanks for the feedback. I;m sure your systen is great also.
    Jun 2010
    Hamburg Pa USA
    I removed the front switch panel and moved a blank up to clean up the front
    I moved the switches inside the hot swap door since I removed two bays
    Jun 2010
    Hamburg Pa USA
    I installed the 9x24 triple 120 with grill and filter
  18. #18
    Jun 2010
    Hamburg Pa USA
    covered motherboard tray today. Now i need to cut cable slots
  19. #19
    Jun 2010
    Hamburg Pa USA
    new camera better pictures
  20. #20
    Moderator
    Aug 2007
    Back and forth between Florida and Maine
    Good start - looking forward to following your project.
  21. #21
    Jun 2010
    Hamburg Pa USA
    mother board is getting there slowly
  22. #22
    Feb 2010
    Wisconsin
    I'm a bit conerned about the wiring for the 8-pin CPU connector ... you gotta get around that tubing *eek*
    Otherwise, this looks to be a nice build, great block choice!
  23. #23
    Jun 2010
    Hamburg Pa USA
    Are you saying I can not go through it Thanks for the comments I picked blocks I thought would go good with my build but some what differnt then everyone else. The MIPS block and the aqua Ram plex look good together and the Rasa block had good reveiws and had black mounting bolts a plus for me
  24. #24
    Feb 2010
    Wisconsin
    I wasn't saying it was impossible, I was just noting EVGA's decision to mount it there.
  25. #25
    Jun 2010
    Hamburg Pa USA
    More wizardry from Bill owens of MNPCTECH I tell him what I want and zap "THERE IT IS"
    LCD PLATE for front bezel
