Hi mate
Here's some
Can i just use it with out IHS *direct contact to the HEAT PIPES*
Can it make any diff ?
Hi mate
Here's some
removed with 4 blades at the same time?
any damaged parts...
are you testing without ihs?
Nice work pr@$r1g![]()
Yes, as long as the heatsink still makes good contactCan i just use it with out IHS *direct contact to the HEAT PIPES*
Sandy Bridge 2500k @ 4.5ghz 1.28v | MSI p67a-gd65 B3 Mobo | Samsung ddr3 8gb |
Swiftech apogee drive II | Coolgate 120| GTX660ti w/heat killer gpu x| Seasonic x650 PSU
QX9650 @ 4ghz | P5K-E/WIFI-AP Mobo | Hyperx ddr2 1066 4gb | EVGA GTX560ti 448 core FTW @ 900mhz | OCZ 700w Modular PSU |
DD MC-TDX CPU block | DD Maze5 GPU block | Black Ice Xtreme II 240 Rad | Laing D5 Pump
BTTB - Gigabyte Z87X-OC - WCed I7 4770k - 2x8gb Ballistix 1600mhz - Zotac GTX 780
Asus Xonar Pheobus - OS -> Toshiba Q 256gb - Games -> 2x Agility 4 256gb Raid0
Corsair HX850 - Tecnofront HWD BenchTable - Asus VE278Q 5760x1080
Serveur - Asus Z77m PRO - 2500K - NH-C12P - 4x4gb G.Skill Ares 1600mhz
Agility 4 128gb - Corsair CX430M - 1TB Black - 2TB green - 2TB Red
KatPat - Gigabyte 990FXA-UD3 - FX-8320 - PH-TC14CS - 2x4gb Viper 1600mhz - GTS 450
Samsung Evo 120gb - Corsair HX750 - Bitfenix Survivor White - Asus VE247H
The problem is contact area.
I really do not think its good idea to remove IHS on GPUs unless you are putting 3rd party cooling / waterblock on it.
In case of GTX 470, assuming its a reference cooler, only 2 are 3 (that too partially) heatpipes out of 5 will make contact with the core with IHS removed. I really wont already toasty chip like GF100 running like that. It would be different story if you get something like VF3000 or shaman or put it on water.
Primary Rig
Intel Xeon W3520 @4200Mhz 24x7, 1.200v load (3845A935)
Gigabyte X58A-UD7
Patriot Viper II DDR3 2000 CL8
Tagan BZ1300
DeepCool Gamer Storm with 2x120mm DeepCool fans.
MSI GTX 470 Twin Frozr II
Zotac GTX 470 AMP edition.
GPU collection : http://www.xtremesystems.org/forums/...5&postcount=64
Rig2
Phenom II x4 965
MSI 790GX-GD65
2GBx2 Corsair DDR3 1333
Tagan tg500-u37
Arctic Cooling Freezer 7 Pro Rev.2
XFX 9600GT
+1 for water on removed IHS
No 4 blades this time
Applied heat on top of the IHS at the same time removing the IHS with a screw driver ... it just poped up
Thanks, but can i know anyone(Any link to a particular website/forum) who has done this before.
yap i tested it without IHS noticed that there was no contact between the GPU & heat pipes (Stock Cooler)
Its taking so much time for the VF3000F to come to retail
Me too ,But i don't have any kind of water cooling setup![]()
I've delidded my 480 some time ago. No need for the heat you just slice around two corners and twist the blade, popped right off. I didn't really get better temps (w/c) but it handles higher juice way better allowing me to bench at 970Mhz core with 1.27V or so. Could prolly go higher but i'm on gpu-only block and the stock front plate can't handle the VRM's at 1.3V+...
2600k @ 5.0Ghz 1.54V, Giga Z68, Zotac GTX680 AMP!, Patriot 1066Mhz 8GB RAM, Custom water, Silverstone 1000W, HAF932
That is exactly the same problem i had, my wb didn't make good contact with the naked die so i applied a fresh blob of tim and glued back the IHS but i was getting really crappy temps do to pretty crappy contact. Had to use a copper shim in the end.
^ u r right man ,temps are really bad ,used to be 48 at idle now at 50 idle
I bought this second one for sli ,so i have to rma ... fuk myself
Yeah because like i said, the IHS that i glued back didn't seem to make a good contact. The shim i'm using now came with some crappy Scythe Setsugen cooler by the way. All i need to do is sand down the stock plate around the core just a little bit and i'll be running direct die again.
If you have a full cover block you won't need to mod anything, just slap the cooler and you're good to go. It's worth it if your water block fits.
Thats crazy
No it's not
i will try lapping it at the base will see if any diff![]()
I only did hw mods when performance or stability goin to be rised.
Up to you guys
MY mods that i did..
Athlon xp1600+ home mod up to Athlon xp2200+ soldering on cpu jumpers using microscop
Some gf6600 graphics, voltage rise
mainboard asus x-600 voltage drop gained stability and speed
^ o wow man u r a free upgrader ,Im thinking the same "Can i make my 470 have 480SP's"![]()
yea why not. if may will work, why not.
Sometime ago my dad got ati x800 and with enabling pipelines on inside gpu will make x850 graphics, i fail do do anything it didnt support enableing pipelines but some did with rivatuner some with reflashing flash-bios and some with hw mod using jumpers.
What i do, is wait and grab whats best for money, and before i buy one specific product i go check internet and check if any bad coments being written on products. Then i check what i can do after all... :-D
