Results 1 to 8 of 8
Thread: MCW80 on SLI GTX460 + MCW30 on PhysX GTS450
    Mar 2009
    Yesterday i tested the MCW30 on the GTS450 and saw it work very nicelly. Today i received the 2 MCW80 i ordered. Found that the GT200 plate is a perfect fit for a GTX460 with only 2 more hole ( or 4 if you want to be perfect ... )
    Everything was pretty straight foward, only the Clamp on the Bloc scared me cause they are very close to the next card but its OK, everything have a decent clearence and nothe to short with is near BTW !
    I dont have temp result yet since im Leak testing ( writing on my laptop ... ). Im only missing the Heatsink for the memory .. suposed to knock at the door soon.
    Pics Final result tomorow !
    BTTB - Gigabyte Z87X-OC - WCed I7 4770k - 2x8gb Ballistix 1600mhz - Zotac GTX 780
    Asus Xonar Pheobus - OS -> Toshiba Q 256gb - Games -> 2x Agility 4 256gb Raid0
    Corsair HX850 - Tecnofront HWD BenchTable - Asus VE278Q 5760x1080
    Serveur - Asus Z77m PRO - 2500K - NH-C12P - 4x4gb G.Skill Ares 1600mhz
    Agility 4 128gb - Corsair CX430M - 1TB Black - 2TB green - 2TB Red
    KatPat - Gigabyte 990FXA-UD3 - FX-8320 - PH-TC14CS - 2x4gb Viper 1600mhz - GTS 450
    Samsung Evo 120gb - Corsair HX750 - Bitfenix Survivor White - Asus VE247H
    Aug 2007
    Brasilia - DF - Brazil
    Nice! I would try two rotaries on the MCW30, it will help a lot with tubing route
    My Lian Li G70
    Asus P6X58D-E * i7-930 * Saphire 7970 * 6GB Corsair XMS3 1600 C7 * Crucial M4 256GB SSD * Lian Li G70W Powdercoated
    Watercooled by single loop Coolgate Quad 120 + Swiftech MCR220 with San Aces H1011 * EK Supreme HF * Koolance VID-AR797 * EK Asus X58 full set * DDC 3.25 with EK Dual Top/Res
    Mar 2009
    yeah, i know, but i dont have any in hand. With antikink, nothing is kinking !
    Temp are really nice. Played Mafia 2 and the hotest GPU was ~45°c with a 30°c room and the GTS460 clocked at 905mhz with 1.145 volts.
    Apr 2008
    Montreal
    Nice, I like the chipset block recycling. I have a mcw30 laying around in a box, could be a good idea.
    I like your rack, it's pretty loaded...
    [SIGPIC][/SIGPIC]
    i3 530 @ 4.2 ghz, evga FTW, 4 gig gskill trident @ 1600 6-8-6-24, XFX 4870 1gb, corsair 620hx, 2 x kinston 64gig ssd raid0, 300 gig Velociraptor, 2Tb WD green,
    Tagan black pearl (lian-li v2000)
    Water: mcp655, mcr320 with ultra kazes, GTZ, mcr60, micro-res,
    black primochill, bitspower comp. fittings
    Quote Originally Posted by Afghan Mac View Post
    We'll spend a few hundred bucks because the color isn't quite right. We have no qualms voiding warranties on a thousand dollar item the day we get it.
    Mar 2009
    yeah, its now pretty heavy !!!!
    I could have used 90° rotary for a cleaner tubing work but im "fonction over fashion".
    Jan 2006
    Indonesia
    Pardon for my silly questions
    1. GT200 plate in the MCW80 package is no need to drilling? Out of the box will
    be fit in GTX460 card mounting? A reference pcb GTX460, isn't it?
    2. I saw 4 long screws on your GTX460, is it the same 4 long screws in GT200
    mounting package in MCW80? Except you have not used 4 black plastic
    standoffs? What about the thumbnuts? Are you using the same GT200'
    thumbnuts mounting package?
    Thx for the reply. I have one MCW80 and GTX460 reference card lying and thinking the same methods you already done. It is a perfect combination for wc'ing GTX460 without looking a full cover wb
    Aug 2010
    Norway
    Quote Originally Posted by Sadhana View Post
    No, like he said in his original post, he had to drill 2 holes in the plate.
    Mar 2009
    For perfect centered mount you can drill 4 hole, but 2 is enough. The hole are correct from left to right, but not from top to bottom on the GT200 plate.
    GT200 is scare, GTX460 is rectangle.
    Currently idling at 27°c on all 3 cards. Playing mafia2 for hours and im at 40°c on the hotter GPU.
