Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 104
Thread: flashing a AsRock 890GX Extreme3 BIOS on a 880G Extreme3 motherboard
    Nov 2006
    Vienna
    Question flashing a AsRock 890GX Extreme3 BIOS on a 880G Extreme3 motherboard
    would that be possible? I mean I've heard of a guy who flashed M3A780GXH -> M3A790GXH. It worked.
    Now you see the 890GX and the 880G have 1:1 the same layout. Nothing's different. Except that the VGA operates at a lower speed. So nothing interesting at all.
    I guess it would be possible, but don't really know. Did anyone try?
    And for those who ask themselves: why the heck?!:
    It's because the "new" 2.42B BIOS for the 890GX has the Add VDoop Adjust feature like LLC feature. 880G is still at version L1.71B with the changelog "Chassis fan react on CPU temp. And if you want this feature, please connect your 4-pin chassis fan on Cha_Fan1 header" ... fail
    I am Xtreme Ket's Avatar
    Apr 2004
    United Kingdom
    You can probably use MMTOOL to extract the image information module from a 880G board and replace the module in a 880GX BIOS. Not tested, but it would probably work.
    "Prowler"
    X570 Tomahawk | R7 3700X | 2x16GB Klevv BoltX @ 3600MHz CL18 | Powercolor 6800XT Red Devil | Xonar DX 7.1 | 2TB Barracuda | 256GB & 512GB Asgard NVMe drives | 2x DVD & Blu-Ray opticals | EVGA Supernova 1000w G2
    Cooling:
    6x 140mm LED fans, 1x 200mm LED fan | Modified CoolerMaster Masterliquid 240
    Asrock Z77 thread! | Asrock Z77 Extreme6 Review | Asrock P67 Extreme4 Review | Asrock P67 Extreme4/6 Pro3 thread | Asrock Z68 Extreme4 thread | Asrock Z68 Extreme4 Review | Asrock Z68 Gen3 Thread | 8GB G-Skill review | TK 2.ZERO homepage | P5Q series mBIOS thread
    Modded X570 Aorus UEFIs
    May 2007
    Romania
    Well if you can do that for us whom don't know how to use that exacty...We would be very greatful
    Apr 2004
    United Kingdom
    I'll whip something up. For now the best I can offer is the 890GX Extreme3 BIOS 2.4 as thats the latest version currently available you can get at the rom file.
    WARNING: This modified 890GX BIOS is intended ONLY for the 880G Extreme3. I do NOT own neither a 890GX or 880G mainboard and thus this BIOS is UNTESTED. This BIOS is being provided only as requested. I STRONGLY advise before attempting to flash this BIOS you have a backup BIOS chip handy with a original copy of a 880G BIOS on it.
    How to flash
    1. Make a bootable USB/CD
    2. After USB/CD has loaded in pure DOS type; AFUDOS.EXE /i880GEM.ROM /PBNC /N
    Changes:
    - Attempt replacing Image Information module [to hopefully make it work]
    - Replace P6 table
    Notes:
    You will likely need to perform a full CMOS reset (set CMOS jumper to "clear", remove power cord and battery, then leave for a few mins) after the flash process before knowing if this modded BIOS works.
    DL Link: Click
    "Prowler"
    Cooling:
    Nov 2006
    Vienna
    So what is that file on megaupload now? A modified BIOS?
    I am Xtreme
    Sep 2006
    no it's a biscuit to eat...
    Question : Why do some overclockers switch into d*ckmode when money is involved
    Remark : They call me Pro Asus Saaya yupp, I agree
    Jan 2008
    Quote Originally Posted by Ket View Post
    How to flash
    Changes:
    - Replace P6 table
    Notes:
    DL Link: Click
    What's the differences in this mod bios vs the actual 880g 1.70?
    Apr 2004
    United Kingdom
    If the mod BIOS works, you will get all of the goodness of the 890GX BIOS.
    "Prowler"
    Cooling:
    Nov 2006
    Vienna
    Worked fine the way I did it (I used the 2.42B and the AsRock flash tool for windows). It's still recognized as a 880G Chip though in CPU-Z, but not in Everest. The HD4250 is still the same it didn't get no BIOS Update.
    Mar 2010
    Angeles/ HK/ Shenzen
    ^ cool!
    any instability issues?
    Nov 2006
    Vienna
    No, no instability. Works fine so far!
    Sep 2006
    Romania
    Quote Originally Posted by Peter Burg View Post
    AFUWIN, what settings you used to, ALL Blocks or just Main BIOS Image.
    I tried just Main BIOS and in bios the board is seen as 890GX Extreme3
    AMD FX 8520@????GHz, Asus M5A99X EVO R2.0, Thermalright HR-02 Macho Rev. A (BW), Sapphire HD7850 Dual-X 1GB , Kingston 16 GB DDR3 2133MHz, WD-640GB SATA-II 7200RPM 16MB AAKS,WD 2TB SATA-II 64MB Caviar Green, Logitech G9, Xigmatek NRP 650W,Creative AUDIGY SE 7.1, CM Storm Scout, Logitech X-530-5.1 /70W-RMS, Samsung 24''-2443BW
    Nov 2006
    Vienna
    I checked "Program All Blocks", "destroy CMOS Checksum" and "do not check ROM ID"
    Mar 2010
    ....just checked out the price of these mobo's & with only a $12 difference, i guess i'll get the 890GX Ex instead & be on the safer side of flashing
    Nov 2006
    Vienna
    It is not about the price, it is about the possibility. And also for the people who have a 880G like me and want the features of the 890GX BIOS.
    so long
    May 2007
    Romania
    Done it too with no problems.Question is how to set those things for v-droop right?
    Also latest bios found 2.43 does not have these v-droop options included
    Latest bios though works better with my memory,allowing it to CAS 7 at 1600,although 2.42 won't post at all at cas 7,only 8,so Asrock bios team should do something about these damn memory problems.Same memory worked flawlesly in Asus 785G evo mobo with cas 6@ 1600...go figure...
    Nov 2006
    Vienna
  18. #18
    May 2007
    Romania
    i apreciate all this info but i am interested only in the part related to bios settings on this asrock mobo
    Droop Adjust - 1/4, 1/2, disable
    OVP - 250mV , 450mV , 650mV , 850mV
    PSI_EN - Disable , Enabled
    PSI_A - Single Phase , Two Phase
    DPM Setting - Disable , 20% , 25 , 30% , 35%
    VCore Offset - Disable , 0.05V , 0.10V , 0.15V , 0.20V , 0.25V , 0.30V , 0.35V
    I am curios to know what each one of these options change...,and what could be the best combination for stability
  19. #19
    Apr 2004
    United Kingdom
    The modded BIOS worked huh? Cool. Hope you guys have fun
    "Prowler"
    Cooling:
  20. #20
    X. I. P.
    Jul 2002
    Sioux Falls, SD U.S.A.
    Ket, I'm reading the posts as Peter Burg & Alex-Ro have flashed the factory stock 890G BIOS directly onto the 880G, not your modded BIOS. Am I wrong, guys?
    The plural of "anecdote" is not "data."
  21. #21
    Nov 2006
    Vienna
    sjohnson you are right. I used the L2.42B Beta BIOS from AsRock. not the BIOS provided by Ket.
  22. #22
    May 2007
    Romania
    +1 It list my board as 890GX extreme3 with 880G chipset.Wondering if an extreme4 bios would work,since this adds NB voltage option
  23. #23
    Apr 2004
    United Kingdom
    Seriously, I wouldn't keep jacking with different BIOSes until you have a way to recover from a bad flash. Its only a few quid to buy a spare ROM chip.
    "Prowler"
    Cooling:
  24. #24
    Nov 2006
    Vienna
    There is a way - a new BIOS Chip for 12€.
    @ Alex
    What NB voltage option?
  25. #25
    May 2007
    Romania
    NB voltage,not CPU-NB,NB solely Also in new bios on extreme4 they added loadline calibration(enabled/disabled) so things would be extraordinary if a 880G would work flashed into 890GX extreme4.But now i saw that extreme4 has different audio chip,that sucks
