For quite some time i want to play a little with a hot vga card and a cpu cooler. The right time has come, GF100 time.
I choose my convex lapped True Copper (details here, from post 26), PK-1 thermal paste, and here it is:
Hehe ghetto zip-tie mod.
Signatures make my posts look huge... but I'm not humble enough to completely remove my signature, so I kept this note explaining it.
ambient temp?
20oC
I think the San Ace on the True Copper is too small. /sarcasm
Wow, maybe I should use my TRUE Copper now instead collecting dust.
Intel i5-2500K @4.2GHZ
Gigabyte Z68-UD4-B3
Custom Loop
Case Labs TH10
GTX 260 Black Edition
G. Skill DDR3-1600
Sweet
I was thinking cable thighs won't do the job...
I am going to have HR-02 same way. Passive cooling solution.
I'm having a hard time deciphering the graphs.. is that 28C under load??
out it curiousity, what are the san ace fan specs?
DNA = Design Not Accident
DNA = Darwin Not Accurate
heatware / ebay
HARDWARE I only own Xeons, Extreme Editions & Lian Li's
https://prism-break.org/
have you used any backplate?
Very interesting way to cool it downy have an ultra 120A i think i will give it a try
No backplate, pressure is not good.
Temps ~40c max on stock and ~45c max at 1138mV/Fur xtreme burning mode
Loving this mod. We need some way to do backplates....
Go custom. Shouldn't be too hard IF you have the proper tools.
You must [not] advance.
Current Rig: i7 4790k @ stock (**** TIM!) , Zotac GTX 1080 WC'd 2214mhz core / 5528mhz Mem, Asus z-97 Deluxe
Heatware
@ [XC] Synthetickiller
Unfortunately all I have for metalworking is hammer and a can opener XD
The thing I was thinking about... i wanted to make proper metal mount before i saw this.
http://www.thermalright.com/products...at_id=30&id=93
GF-100 Bolt-Thru-Kit is my solution, if you rather pay than get on with tools.
simply...wow
Rig 1 Asus ROG Strix B550-F WiFi, R7 5800x, 64GB Vengeance LPX 4*16GB, Zotac GTX 1070Ti, X-Fi Titanium, Enermax Revolution D.F. 850w, SSDs 768GB, HDD 3TB, CM 912HAF, NH D-15 Black.cr
Rig 2 Asus Maximus VI Hero, i7 4770K@4000, 32GB Ballistix VLP 4*8GB, Gigabyte GTX 970, eVGA G3 850, SSD 512GB, HDD 2TB, TT Element-T, NH D-14.
Grats mate!
Damn, I love that ghetto coolingGet yourself a pair o deltas - and off you go for some serious air-benching
@ poparamiro
Did you removed plate from GPU?
@ Ccaution - delta's are toys for babies, if you want the real thing try 300CFM counter rotating fan from Sun Ace.
@ DomagojX - hehehehe, sick temps
@ dienicy - GF100 ihs is not removed
HMM. When you think about it, this might work even better in a case: get one of those full towers that have provision for both top and bottom PSU mount. Then mount the PSU up top. On the bottom provide a stand to support the top of the heatsink to keep it from pulling on the vidcard. Might work, and then you'd never have to worry about gpu temps again.
Hotrod: Core i7 860 22x182 4GHz Vcore 1.3125v | Noctua NH-D14 w/ P14 + 2 x AP-14's
Gigabyte P55A-UD3P f13 | 4GB Ripjaws DDR3-2000 @1820MHz | Gigabyte HD 4670 1GB
Kingston V+ 64GB SSD + Barracuda 1TB 7200.12 | NZXT Beta Evo | Seasonic X-650
what a dangerous procedure this must have been with all those tie wraps. luckily the g100 is fine on its own and using a true for the GPU HSF is nuts and placing a san ace. i would never thought it would fit
Awesome![]()
