Results 1 to 25 of 26
Thread: Linux not using 100% CPU usage
Threaded View
    Xtreme Cruncher
    Oct 2007
    Well last night I installed Debian 5 on a rig, I plan to set up many Linux machines for WCG crunchers. I ran into my first odd issue, CPU usage is bouncing around alot and not using 100%. I remembered Jcool had these issues with unbuntru so I just went and checked his thread (http://www.xtremesystems.org/forums/...d.php?t=252766 see post #9 and #11) In Jcool's case his problem just magically worked itself out And yeah, boinc is set up to use all cores at %100. I feel this is caused by other task taking prority over boinc and causing these issues. Its not just a fault system monitor also, my kill-a-watt also shows the wattage bouncing around equally confirming the problem.
    Heres my screenshot of the issue:
    Also, I installed Debian because it's suppose to be very stable and boinc is suppose to work on it and I think I can do a basic net install (to keep it unbloated.) But the latest version of Boinc in the apt-get was 6.2.xx!!! Quite old; id be happy with anything in the 6.10.xx range
    Also, this system was running stable with a windows HD, now Linux is in 20 or 30 min (I'm guessing Linux needs a bump in Vcore vs win7 ) Off to a rocky Linux crunching start so far
    Anyways; anyone got any clue why I can't get a solid 100% CPU usage with boinc?
    XTREMESupercomputer: Phase 2
    Live up to your name - November 1 - 8
