Results 1 to 23 of 23
Thread: Safe, conservative max temperatures for the long-term?
    Aug 2009
    Nelson, New Zealand
    What are good, safe, conservative maximum temperatures for Xeon 1366-family systems that are running WCG 24x7 (not just CPU, but VREGs, etc, too)? I'm using an air-cooled SR-2 / X5650 (no OC yet, due to cooling issues).
    Seems like a simple enough question, but looking around on the web, the opinions seem to vary widely. Short-term peaks are one thing; constant and long-term is another.
    Also, what's the benefit of moving to water cooling, in terms of achievable throughput and effect on system life?
    Xtreme Legend
    Dec 2003
    Northern California
    I have two hexa-core systems, both air-cooled and both overclocked. They do nothing but run WCG. CPU temps range from low 50's (C) on cool days to mid 60's on hot days.
    I have yet to have a CPU die from running WCG at 100% load 24/7. I have a dual Xeon machine that's been crunching non-stop for three years.
    Audentes fortuna iuvat
    "Fortune favors the bold"
    Xtremely Hot Sauce
    Sep 2007
    New York
    70C would be the max I'm comfortable running at. Even so, target temperature would be closer to 40C.
    My toys:
    Asus Sabertooth X58 | Core i7-950 (D0) | CM Hyper 212+ | G.Skill Sniper LV 12GB DDR3-1600 CL9 | GeForce GTX 670-2048MB | OCZ Agility 4 512GB, WD Raptor 150GB x 3 (RAID0), WD Black 1TB x 2 (RAID0) | XFX 650W CAH9 | Lian-Li PC-9F | Win 7 Pro x86-64
    Gigabyte EX58-UD3R | Core i7-920 (D0) | Stock HSF | G.Skill Sniper LV 4GB DDR3-1600 CL9 | Radeon HD 2600 Pro 512MB | WD Caviar 80GB IDE, 4TB x 2 (RAID5) | Corsair TX750 | XClio 188AF | Win 7 Pro x86-64
    Dell Dimension 8400 | Pentium 4 530 HT (E0) | Stock HSF | 1.5GB DDR2-400 CL3 | GeForce 8800 GT 256MB | WD Caviar 160GB SATA | Stock PSU | (Broken) Stock Case | Win Vista HP x86
    Little Dot DAC_I | Little Dot MK IV | Beyerdynamic DT-880 Premium (600 Ω) | TEAC AG-H300 MkIII | Polk Audio Monitor 5 Series 2's
    Xtreme Cruncher
    Oct 2007
    Low 70's C is fine for me, they can last many many years like that which is longer than I want to run a rig.
    XTREMESupercomputer: Phase 2
    Live up to your name - November 1 - 8
    c[_]
    Nov 2002
    Alberta, Canada
    70c or so. 80 is where I start to change things if its not already planned to be done on a long term setup.
    All along the watchtower the watchmen watch the eternal return.
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    Hmm you guys are a little more lax than I am. If the CPU is hitting 60C consistently I look into improving cooling as that is too warm for me. It used to be for some CPUs at least. Maybe I'm paranoid.
    I let my GTX260 get in the 70's doing F@H, but 80C is getting too warm for 24/7 IMO on it.
    The Cardboard Master
    Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
    Xtreme Cruncher
    Feb 2009
    Iowa, USA
    i used to freak if my cpus got over 60, but with the i7s i've always been comfortable with 80 or less. but i still aim for under 70.
    Main: i7-930 @ 2.8GHz HT on; 1x GIGABYTE GTX 660 Ti OC 100% GPUGrid
    2nd: i7-920 @ 2.66GHz HT off; 1x EVGA GTX 650 Ti SSC 100% GPUGrid
    3rd: i7-3770k @ 3.6GHz HT on, 3 threads GPUGrid CPU; 2x GIGABYTE GTX 660 Ti OC 100% GPUGrid
    Part-time: FX-4100 @ 3.6GHz, 2 threads GPUGrid CPU; 1x EVGA GTX 650 100% GPUGrid
    Xtreme Cruncher
    Dec 2008
    Texas
    Wow... you guys are conservative. I've been running my 920 at high 80C to low 90C for almost a full year now (24/7). So far all is good.
    I run it like that fully realizing I'll shorten it's lifespan, but I figure I can run it like that for 2 years, clock it back to stock and give it away to my brother or a friend. (free - not going to sell a chip I knowingly may have damaged)
    The key thing to keep in mind is that every 5C in temp above a certain threshold (which I actually don't remember off the top of my head... want to say 45C) will cut it's life by a certain percentage (also don't remember). The question is how long are you really going to use that chip. If you want to be on the safe side I'd say stay low 70s or below and it will be way outdated before you damage it. Remember, most CPUs 70s are not safe, but i7s are rated to 105C, so that is perfectly acceptable.
    Hope that helps.
    24 hour prime stable? Please, I'm 24/7/365 WCG stable!
    So you can do Furmark, Can you Grid???
    OVERCLOCKAHOLICS
    Jul 2010
    Hawaii
    Here are my temps while crunching, what do you all think?
    Xtreme Legend
    Dec 2003
    Northern California
    @OC Maximus
    Temperatures are very good.
    High voltage is more likely to kill a chip than high temps. The hexa-cores seem a little more fragile than the Bloomfields. I would not run QPI voltage higher than 1.35V on a hexa-core. 1.3V is pretty safe.
    Aug 2009
    Nelson, New Zealand
    Quote Originally Posted by OC Maximus View Post
    What's TMPIN2? 128C?
    c[_]
    Nov 2002
    Alberta, Canada
    Quote Originally Posted by Otis11 View Post
    Hope that helps.
    I've never seen a CPU that wasnt safe at 70c? In fact all PC parts should be "hot box" tested at 50c ambient in theory.. that gives 5-10c above the average peak "ambient" temperature during the summer in some areas of lee-way.
    Dont forget that a linear rise in ambient temperatures usually gives a linear rise of cpu/gpu/etc temperatures (heatpipes can change this slightly but for solid heatsinks and water cooled parts this is what happens).
    edit
    I'd be afraid of using a macbook pro outside on a 45c day lol!
    Xtreme Cruncher
    Apr 2007
    Western Canada
    +01
    Quote Originally Posted by werdwerdus View Post
    i used to freak if my cpus got over 60, but with the i7s i've always been comfortable with 80 or less. But i still aim for under 70.
    Jul 2009
    Quote Originally Posted by sierra_bound View Post
    Whats the max QPI volts you would run a bloomfield at 24/7?
    OVERCLOCKAHOLICS
    Jul 2010
    Hawaii
    Quote Originally Posted by AceNZ View Post
    Just a HWMonitor glitch with my board. Its always there, I'm sure nothing is running that hot in my machine.
    Jun 2010
    Bournemouth (UK)
    My 920 @ 3.88 sits around 72 - 74c on just a slim 360. Not ideal I know but a quad socket is more important than a quad rad.
    On a side note here are my temps for my Sossaman. It has a single 120 screwed into the heatsinks and has been on the grid for about twelve hours.
    They seem a little high (bottom right) Are these temps alright?
    Nymph - Xeon 5675 @ 4.1 w/ x2 680
    Ikaros - i7 920 w/ 275 - Build In Progress
    Long live LGA1366
    Back from the Dead
    Oct 2007
    Stuttgart, Germany
    On the SR-2, watch Vreg 0 temps. Mine is all watercooled and it shows 60C loaded with the Dual X5680's @ 4.3Ghz running BOINC.
    Those are rated to 135C if I'm not mistaken, so I'd say 70-75 coretemp for CPUs and 80-90C Vreg max. My CPU temps are below 50, but then again, I am running on chilled water.
    As people have said, the issue isn't the temperatures as much as the voltages. I would not go past 1,4V Vcore / 1,35V VTT for long term use, even with good cooling (obviously I could run 1,5V on the CPUs easy, but that would probably kill them after a while).
    World Community Grid - come join a great team and help us fight for a better tomorrow![size=1]
  18. #18
    Jul 2010
    Birmingham, United Kingdom
    For the AMD peeps
    62c seems to be the real limit on most processors.When you start getting near it with the newer processors they start acting funky and throw up all sorts of problems
  19. #19
    Xtreme Mentor
    Jan 2009
    Oslo - Norway
    X56xx like other 32nm runs really cool. The vCore may vary depending on your CPU, but normal 24/7 voltages shouldn't make any problem on air.
    These CPUs can handle ~75'C, easily for 24/7. Here is mine under prime-load, and it still got 20'C to hit the max-temp , on air.
    2 x X5650 @3.8GHz (200x19) 1.16v VVT=1.33/1.34v, 15 min Prime
    ASUS P8P67 Deluxe (BIOS 1305)
    2600K @4.5GHz 1.27v , 1 hour Prime
    Silver Arrow , push/pull
    2x2GB Crucial 1066MHz CL7 ECC @1600MHz CL9 1.51v
    GTX560 GB OC @910/2400 0.987v
    Crucial C300 v006 64GB OS-disk + F3 1TB + 400MB RAMDisk
    CM Storm Scout + Corsair HX 1000W
    EVGA SR-2 , A50
    2 x Xeon X5650 @3.86GHz(203x19) 1.20v
    Megahalem + Silver Arrow , push/pull
    3x2GB Corsair XMS3 1600 CL7 + 3x4GB G.SKILL Trident 1600 CL7 = 18GB @1624 7-8-7-20 1.65v
    XFX GTX 295 @650/1200/1402
    Crucial C300 v006 64GB OS-disk + F3 1TB + 2GB RAMDisk
    SilverStone Fortress FT01 + Corsair AX 1200W
  20. #20
    Xtreme Legend
    Dec 2003
    Northern California
    Quote Originally Posted by SuperPhrank View Post
    I would probably do no more than 1.35V for 24/7 use, especially if you are running low BCLK speed.
  21. #21
    Xtreme Cruncher
    Dec 2008
    Texas
    Quote Originally Posted by STEvil View Post
    edit
    This is what I was talking about:
    AMD Athlon Series
    AMD Athlon (socket) up to 1Ghz 90°C
    AMD Athlon (slot) all speeds 70°C
    AMD Athlon Thunderbird 1.1Ghz+ 95°C
    AMD Athlon MP 1.33Ghz+ 95°C
    AMD Athlon XP 1.33Ghz+ 90°C
    AMD Athlon XP T-Bred upto 2100+ 90°C
    AMD Athlon XP T-Bred over 2100+ 85°C
    AMD Athlon XP Barton 85°C
    AMD Athlon 64 70°C
    AMD Athlon 64 (Socket 939, 1.4 volts) 65°C
    AMD Athlon 64 FX (sledgehammer) 70°C
    AMD Athlon FX (San Diego + Toledo + Windsor) 63°C
    AMD Athlon X2 (Manchester + Toledo) 65°C
    AMD Athlon X2 (Windsor) 70°C-72°C (1.35v - 1.25v)
    AMD Athlon X2 (Brisbane) 78°C (1.25v)
    AMD Phenom
    AMD Phenom 70°C
    AMD Phenom X3 70°C
    AMD Phenom X4 (9100, 9750, 9850) 61°C
    AMD Phenom X4 (9550, 9650) 70°C
    AMD Sempron
    AMD Sempron (T-bred/Barton core) 90°C
    AMD Sempron (Paris core) 70°C
    AMD Sempron (Manila) 69°C/78°C Model dependant
    AMD Mobile Sempron 95°C
    Intel Pentium D
    Pentium D (Smithfield 805, 820) 63°C
    Pentium D (Smithfield 830, 840) 69.8°C
    Pentium D (Presler 915, 920, 930, 945, 960) 63.4°C
    Pentium D (Presler 940, 950) 68.6°C
    Intel Celeron Series
    Celeron D (Prescott) 67°C
    Celeron D (Cedar Mill) 69.2°C
    Mobile Celeron 100°C
    Intel Core 2 Duo
    Intel core 2 Duo (Conroe E4300, E4400, E6300, E6400) 61.4°C
    Intel Core 2 Duo (Conroe E4500, E4600, E4700) 73.3°C
    Intel Core 2 Duo (Conroe E6320, E6420, E6540, E6550, E6600, E6700, E6750, E6850) 60.1°C
    Intel Core 2 Duo (Wolfdale) 72.4°C
    Mobile Core 2 Duo 100°C
    Intel Core 2 Extreme
    Intel Core 2 Extreme (Conroe) 60.4°C
    Intel Core 2 Extreme (Kentsfield Q6700) 71°C
    Intel Core 2 Extreme (Kentsfield Q6600) 62.2°C
    Intel Core 2 Extreme (Kentsfield QX6700, QX6850) 64.5°C
    Intel Core 2 Extreme (Kentsfield QX6800) 54.8°C
    Intel Core 2 Extreme (Yorkfiled Q9300, Q9450, Q9550) 71.4°C
    Intel Core 2 Extreme (Yorkfield QX9650) 64.5°C
    Intel Core 2 Extreme (Yorkfield QX9770) 55.5°C
    Intel Core 2 Extreme (Hypertown QX9775) 63°C
    Intel Itanium 2
    Intel Itanium 2 below 1Ghz 66°C
    Intel Itanium 2 1Ghz - 1.6Ghz 83°C
    (Sorry about the formatting)
  22. #22
    Fanboy of Good Products
    Oct 2008
    FL
    amen to that. mine is the hottest computer in the house and that's with manually cranking up the fan. sitting here typing this in a fairly cool room it's sitting at 48C. rendering video i've seen it hit 88C!!
    Cruncher #1: EVGA Z68 FTW | i7-2600k @ 4.5 | 6GB Ram
    Cruncher #2: Supermicro Dual-Socket | 2 x 6-core Opterons | 4GB Ram
    Cruncher #3: 8-core Xserve 1,1
    T400 for non-crunching
    "But don't think you'll run me over - It's, ah, planting season here in Texas... and the farm is growing..." -Otis11 on crunching WCG
  23. #23
    V3 Xeons coming soon!
    Nov 2005
    New Hampshire
    Agreed.. 1.35VTT is generally accepted as the max long term safe number.
    Been learning some and finding out that more on VTT isn't always the answer.
    More vcore and less VTT many times will get you more.
    My E5640's were at 1.35vcore and 1.35vtt, dropped the VTT to 1.3v and picked up 400mhz at lower temps..
    The XS WCG team needs your support.
    A good project with good goals.
    Come join us,get that warm fuzzy feeling that you've done something good for mankind.
    Quote Originally Posted by Frisch View Post
    If you have lost faith in humanity, then hold a newborn in your hands.
