Ok this is my first attempt at case modding, water cooling and writing a worklog.So first things first i would like to say a BIG thank you to everyone on the XS forums, have learnt a lot from this site
Hardware List
Cosmos S case
Coolermaster 1000W Modular Power Supply
Asus Striker 2 Extreme MB
Intel Core 2 Duo E8500
OCZ DDR3 Reaper Memory 4Gb
2x BFG GTX275 Graphics
GT240 for PhysX
Creative X-Fi Titanium Fatality
Western Digital 1Tb And 500Gb Hard Drives
LG Blue Ray Disk Drive
2x Enermax Magma 120mm fans (Side Window)
2x Enermax Vegas Apollish 120mm fans (Front Intake)
Water Cooling Parts
Ek 360mm Radiator
Ek HF cpu Block
Ek Multioption 250mm Advanced Reservoir
Ek compresion fittings
Ek DCP 4 Pump
Primoflex Tubes 3/8
3x Coolermaster 120mm Excaliber fans (Radiator)
Ok i know some of the hardware is a little dated, cant afford a major upgrade at the momentso have decided to do a bit of modding to improve the looks and water cooling so i can overclock the system a bit
Front Shot of my case before i started any work More pics to follow.
