essence{red}
Hey all. I'm starting a new build using the hardware and water cooling parts from my old build. Most of the hardware will be the same, but I'm going to change some of the water cooling parts. I'll try to update as often as I can. The color scheme is going to be black, white and red. The tubes will be red, while case its self will be black and white.
Hardware:
- [Case] ~Lian Li~ PC-P50
- [MoBo] ~EVGA~ X58 3-Way Classified SLI
- [CPU] ~Intel~ Core i7 980X
- [GPU] ~XFX~ ATI 5970 (Crossfire x2)
- [RAM] ~Corsair~ Dominator GTX2 (2GB x3: 6GB)
- [SSD] ~Intel~ X25-M 160GB
- [HDD] ~WD~ 1TB
- [PSU] ~Silverstone~ ST1200 1200W
Water Cooling
- [Rad] ~Feser~ XChanger (120mm x3)
- [Rad2] ~Koolance~ Dual (140mm x2)
- [CPU] ~EK~ Supreme LT
- [MoBo] ~Mips~ EVGA X58 Classified Mosfet and Triplechip COOLER POM Black
- [GPU] ~EK~ Radeon 5970
- [Res] ~EK~ MultiOption 4 Port
- [Pump] ~Swiftech~ MCP655 (x2 w/ EK-D5 Dual Top)
- [Tube] ~Tygon~ 3603 (1/2” ID : 3/4” OD)
- [Fluid] ~Feser~ Feser One UV Red
- [Fittings] Bitspower
Other
- [Sleeving] ~MDPC~ Sleeving
