http://www.geeks3d.com/20100819/gpu-...ion-benchmark/
OpenGL and works in XP.
Like Unigine Heaven, TessMark allows to select the level tessellation. The small difference is that TessMark proposes four differents levels (see the screenshots at the end of the post):
moderate
normal
extreme
insane
Moderate and normal levels are levels we’ll find in real world applications like games. Extreme and insane levels are reserved for GPUs with much tessellation processing power and for the required touch of madness that a graphics benchmark must have
TessMark is an OpenGL 4 benchmark. That means you can play with GPU tessellation under Windows XP, Vista and Seven. Of course, you need a GeForce GTX 400 series or a Radeon HD 5000 Series. No GPU tessellation with previous generation of graphics cards!
