BIG Azz socket though
UPDATED a bit
UPDATED
UPDATE 8/18
HSF is the same with 1366, +/-8cm distance between mount hole
Still a :banana::banana::banana::banana:
UPDATED a bit
UPDATED
UPDATE 8/18
===N/A===
Picture isn't working.
You must [not] advance.
Current Rig: i7 4790k @ stock (**** TIM!) , Zotac GTX 1080 WC'd 2214mhz core / 5528mhz Mem, Asus z-97 Deluxe
Heatware
its working, just heavily edited
This image or video has been moved or deleted.
Xtreme SUPERCOMPUTER
Nov 1 - Nov 8 Join Now!
Athlon64 3700+ KACAE 0605APAW @ 3455MHz 314x11 1.92v/Vapochill || Core 2 Duo E8500 Q807 @ 6060MHz 638x9.5 1.95v LN2 @ -120'c || Athlon64 FX-55 CABCE 0516WPMW @ 3916MHz 261x15 1.802v/LN2 @ -40c || DFI LP UT CFX3200-DR || DFI LP UT NF4 SLI-DR || DFI LP UT NF4 Ultra D || Sapphire X1950XT || 2x256MB Kingston HyperX BH-5 @ 290MHz 2-2-2-5 3.94v || 2x256MB G.Skill TCCD @ 350MHz 3-4-4-8 3.1v || 2x256MB Kingston HyperX BH-5 @ 294MHz 2-2-2-5 3.94v
JC: I just hope you have run HWiNFO32 thereIt should support it..
Come on JC...this is fairly anti-climactic............NEED PIC!!!!!
____________________________________________
More & more very expensive, quickly obsolete parts!!
Is that a dual socket board?
░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ Intel i7 3770k
░░░░░░▄▄▄▄▀▀▀▀▀▀▀▀▄▄▄▄▄▄░░░░░░░░░ ASUS GTX680
░░░░░░█░░░░▒▒▒▒▒▒▒▒▒▒▒▒░░▀▀▄░░░░░ ASUS Maximun V Gene
░░░░░█░░░▒▒▒▒▒▒░░░░░░░░▒▒▒░░█░░░░ Mushkin 8GB Blackline
░░░░█░░░░░░▄██▀▄▄░░░░░▄▄▄░░░█░░░░ Crucial M4 256GB
░░░▀▒▄▄▄▒░█▀▀▀▀▄▄█░░░██▄▄█░░░█░░░ Hitachi Deskstar 2TB x2
░░█▒█▒▄░▀▄▄▄▀░░░░░░░░█░░░▒▒▒▒▒█░░ FSP 750W Gold
░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ Fractal Arc Mini
Before you had to worry about not bending 13xx pins now you have to worry about not bending 2xxx pins that is progress![]()
Coming Soon
aaaah, so where's the HWiNFO32 screenshot??![]()
I can draw better picture in paint with the wrong hand, than this picture![]()
pleeease fix that..
photobucket = crap, move it to imageshack or somewhere else
Ryzen 9 3900X w/ NH-U14s on MSI X570 Unify
32 GB Patriot Viper Steel 3733 CL14 (1.51v)
RX 5700 XT w/ 2x 120mm fan mod (2 GHz)
Tons of NVMe & SATA SSDs
LG 27GL850 + Asus MG279Q
Meshify C white
JC strikes again !![]()
to time but only one screen of socket :-). We want a bit more ,-)
ROG Power PCs - Intel and AMD
Pic which is posted in #8 is broken too. Well I begin to doubt whether Intel had send some spies into Photobucket and has worked for a long time.![]()
LGA-2011 is meant to be 58.5 x 51 mm, per Wikipedia, and the aspect ratio from the photo looks about right for that: not square, but close.
JCornell sent you a PM awaiting a response .
Coming Soon
wow, where did u get that pic ?
Intel Q9650 @500x9MHz/1,3V
Asus Maximus II Formula @Performance Level=7
OCZ OCZ2B1200LV4GK 4x2GB @1200MHz/5-5-5-15/1,8V
OCZ SSD Vertex 3 120Gb
Seagate RAID0 2x ST1000DM003
XFX HD7970 3GB @1111MHz
Thermaltake Xaser VI BWS
Seasonic Platinum SS-1000XP
M-Audio Audiophile 192
LG W2486L
Liquid Cooling System :
ThermoChill PA120.3 + Coolgate 4x120
Swiftech Apogee XT, Swiftech MCW-NBMAX Northbridge
Watercool HeatKiller GPU-X3 79X0 Ni-Bl + HeatKiller GPU Backplate 79X0
Laing 12V DDC-1Plus with XSPC Laing DDC Reservoir Top
3x Scythe S-FLEX "F", 4x Scythe Gentle Typhoon "15", Scythe Kaze Master Ace 5,25''
Apple MacBook Pro 17` Early 2011:
CPU: Sandy Bridge Intel Core i7 2720QM
RAM: Crucial 2x4GB DDR3 1333
SSD: Samsung 840 Pro 256 GB SSD
HDD: ADATA Nobility NH13 1GB White
OS: Mac OS X Mavericks
JC is such a rogue![]()
We need some more shots!![]()
such a tease lmao
Okay so what is this, like six-channel DDR3? Nobody needs 2000+ pins...
Smile
