Results 1 to 14 of 14
Thread: MSI R5870 Lightning
    ODOC
    Aug 2006
    Copenhagen - Denmark
    MSI R5870 Lightning
    Let’s have a initial look at the MSI R5870 Lightning, equipped with the fresh Twin Frozr II cooler with a total of 5 heatpipes.
    Let's start out with a look at the new Twin Frozr II;
    The Twin Frozr II is quite impressive, both temp and noise wise, especially strong for 24/7 usage.
    MSI R5870 Lightning retail package with following protection;
    1. Plastic top protection cover.
    2. Custom cut foam to surround and support the card.
    3. Anti-Static bag for ESD protection.
    4. Light blue hoods attached to PCI-E / CF connectors and DVI-I x2 for protection.
    MSI R5870 Lightning with Twin Frozr II
    Close up @ one of the 80mm FANS
    Close up @ the 5 heatpipes, two of them is based upon SuperPipe (8mm thickness)
    MSI R5870 Lightning PCB
    MSI R5870 Lightning PCB - Negative
    The ATI Cypress XT GPU @ our MSI R5870 Lightning
    3DMark Vantage - Performance Preset
    1000/1300 MHz - Fans @ 80%
    V-Check Points;
    Vcore 1.162 V Vmem 1.61 V VDDCI 1.175 V
    Crunch-Fu Adept
    Sep 2005
    Czech Rep.
    LIGHTNING!
    Sometimes a good slap in the face is all you need
    Bios my arss.....
    I can fix this problem with a hardware mod....
    Hipro5
    "Overclock till death. Overclocking is life." Hipro5
    Mar 2010
    nice temps full load
    Nov 2007
    did the pcb change from rev1 - rev2 or just the cooling?
    [SIGPIC][/SIGPIC]
    I am Xtreme Ket's Avatar
    Apr 2004
    United Kingdom
    Damn the name is gay but by god is that Twin Frozr cooler sexy as hell and effective. I wish MSIs GTX460 Cyclone wasn't so expensive
    "Prowler"
    X570 Tomahawk | R7 3700X | 2x16GB Klevv BoltX @ 3600MHz CL18 | Powercolor 6800XT Red Devil | Xonar DX 7.1 | 2TB Barracuda | 256GB & 512GB Asgard NVMe drives | 2x DVD & Blu-Ray opticals | EVGA Supernova 1000w G2
    Cooling:
    6x 140mm LED fans, 1x 200mm LED fan | Modified CoolerMaster Masterliquid 240
    Asrock Z77 thread! | Asrock Z77 Extreme6 Review | Asrock P67 Extreme4 Review | Asrock P67 Extreme4/6 Pro3 thread | Asrock Z68 Extreme4 thread | Asrock Z68 Extreme4 Review | Asrock Z68 Gen3 Thread | 8GB G-Skill review | TK 2.ZERO homepage | P5Q series mBIOS thread
    Modded X570 Aorus UEFIs
    ODOC
    Aug 2006
    Quote Originally Posted by geoffsthaboss View Post
    PCB is the same, the Twin Frozr II got upgraded with an extra heatpipe and 15 fins, allowing for a more silent operation and or more headroom for overclocking .
    Nov 2008
    how many slots does the cooler on this card take? because im thinking crossfiring two of these and i dont think they will fit close to each other.
    ODOC
    Aug 2006
    Quote Originally Posted by Salsoolo View Post
    dual slot
    Nov 2008
    so it wont work
    Xtreme Guru
    Jun 2010
    In the Land down -under-
    20k score pretty nice! love the cooler on this card looks god dam sexy!
    Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
    May 2009
    Greece
    Seems that the new cooler does a better job...
    And cmon dude, freeze that baby...
    24/7 Rig: AMD Athlon II 450 - MSI 760GM E51- 8GB 1600MHz Gskill RipjawsX- Nvidia GTX260 - OCZ Vertex2 60GB - Seagate 640GB - Antec Quattro 1200W - Samsung T220
    Bench Rig: Intel Core i7 3770K - Asus Maximus IV Extreme - 4GB 2000MHz Corsair Dominator GT - 2x Nvidia GTX260 - Intel Postville 40GB - WD VelociRaptor 36GB - Antec Quattro 1200W
    Mar 2008
    Minnesota
    so it wont work
    Unless I'm missing something completely, I think he meant "dual slot" as in the card is dual slot, so it will work just fine. All other Twin Frozr (wtf @ the name, Engrish ftw) cards play happily in Crossfire. Most boards arent spaced that closely anyway anymore, unless you are going 3 or 4 cards.
    i5 2500K @ 4.9GHz+ 8GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 6 Asus P8P67 Pro CrossFire 6970's @ 950/1450
    Xeon X5677 @ 4.5Ghz 6GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 7 Gigabyte EX58-UD5 4870x2
    i7-880 @ 4.2Ghz+ (still playing) 4GB G-Skill RipJaws DDR3-2000 @2300Mhz CAS 9 Asus Maximus III Formula MSI Hawk 5770
    ODOC
    Aug 2006
    Quote Originally Posted by geobot24 View Post
    We havent pushed 5870 alot before, but this particular GPU, scales alot better with cold than the other 5870 We played with.
    It does 1100 MHz with default Vgpu , cooled with ln2
    Nov 2008
    Quote Originally Posted by tool_462 View Post
    yes you're missing something , you're missing the heat problems all over the internet with cf setups due to almost zero space between cards.
