http://www.nordichardware.com/news/7...-revealed.html"Early information has claimed a surface area of 366mm^2 with GF104, which is confirmed by these pictures. You can compare this to the 334mm^2 of Cypress"
FX-8350(1249PGT) @ 4.7ghz 1.452v, Swiftech H220x
Asus Crosshair Formula 5 Am3+ bios v1703
G.skill Trident X (2x4gb) ~1200mhz @ 10-12-12-31-46-2T @ 1.66v
MSI 7950 TwinFrozr *1100/1500* Cat.14.9
OCZ ZX 850w psu
Lian-Li Lancool K62
Samsung 830 128g
2 x 1TB Samsung SpinpointF3, 2T Samsung
Win7 Home 64bit
My Rig
i wonder if it still works....
If they had taped it off: yes.
Since they didnt..... i'm gonna say 60% possibility yes.
All along the watchtower the watchmen watch the eternal return.
Charlie was right yet again!![]()
So, would a full enabled GF104 consuming at load the exact same power of an HD5870 be a better performer or a worse performer???
Are we there yet?
Fast computers breed slow, lazy programmers
The price of reliability is the pursuit of the utmost simplicity. It is a price which the very rich find most hard to pay.
http://www.lighterra.com/papers/modernmicroprocessors/
Modern Ram, makes an old overclocker miss BH-5 and the fun it was
My rig the Kill-Jacker
CPU: AMD Phenom II 1055T 3.82GHz
Mobo: ASUS Crosshair IV Extreme
Game GPU: EVGA GTX580
Secondary GPU 2: EVGA GTX470
Memory: Mushkin DDR3 1600 Ridgeback 8GB
PSU: Silverstone SST-ST1000-P
HDD: WD 250GB Blue 7200RPM
HDD2: WD 1TB Blue 7200RPM
CPU Cooler: TRUE120 Rev. B Pull
Case: Antec 1200
FAH Tracker V2 Project Site
So I guess just confirms again ATIs architectural lead in Perf/mm2 over Nvidia. With that being said, a fully enabled GF104 with good cooling and high clocks should be able to get within spitting distance of HD5870.
Also brings the question on how much money Nvidia is really making on GF104. My guess would be not very much, and that GF104 is positioned to capture/hold market share from ATI so Nvidia can make more money in the future.
Things are going to get interesting for Nvidia really soon, with southern Islands on the way soon, and good integrated-in-the-cpu graphics coming from both AMD and Intel. If worst comes to worst, Nvidia will lose the ability to compete in the high-end and the low-end, while their mid-range might make very little money due to the perf/mm2 disadvantage over ATI. They still have the professional market nicely (for the most part) to themselves though.
hmmm thats bigger than i thought... and what a weird shape huh?
seems to be about the size of amds first a64 chips and later dualcore chips?
This shape is a sign of things to come.
Next up, the U-shaped silicon, it is built with watercooling in mind and comes with a pre-built block that works as an IHS as well! You read it here first! :P
Just wait until we start hitting the cool shapes like octagon or enneadecagon!
This is a picture posted two days ago here on Nvidia section. Nordic hardaware doesn't say anything about height and width, which are essentials.
From this picture if we calculate 13.7*24.2= 331.54mm2 which is a thiny smaller than Cypress which is 334mm2.
So don't rush with wrong presumptions. I think that is truths let say that GF104 is equal to Cypress otherwise i don't think Nvidia would have such low prices for GTX 460 and such good temperatures and power consumption.
i5 2500K@ 4.5Ghz
Asrock P67 PRO3![]()
P55 PRO & i5 750
http://valid.canardpc.com/show_oc.php?id=966385
239 BCKL validation on cold air
http://valid.canardpc.com/show_oc.php?id=966536
Almost 5hgz , air.
gee its huge!
Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
It's a rectangle![]()
Keep in mind that ATI makes more 'dense' chips than nVidia, they're able to put more transistors in the same space.
GF100: 3.0b transistors in 529 mm^2: 5.7m transistors / mm^2
Cypress: 2.15b transistors in 334 mm^2: 6.4m transistorts / mm^2
With the GF100's density in mind, you'd say it would be 344 mm^2 (this is probably how Charlie got his estimate), which is bigger than Cypress. That said, I guess 331 mm^2 still makes more sense than 366 mm^2.
As for why it's a rectangle - Perhaps that way nVidia could engineer it more easily? From the die shot we know that in GF100 there's four square-ish blocks that house the shaders, since GF104 has probably has two of those with more shaders each, it might not have been worth the trouble making it a perfect square again.
If i calculate by this numbers 1.95b/5.7=342mm, and count that GF 104 has less L3 cache and Polymorf units than GF 100.GF100: 3.0b transistors in 529 mm^2: 5.7m transistors / mm^2
And also i think that because of larger SM units, 48SP instead of 32SP some space is also gain due the lower numbers of SM modules, so lower numbers of SM "walls" modules if you understand.
So my opinion is that GF104 is = Cypress = 334mm2 and point. All other speculation are useless.
i5 2500K@ 4.5Ghz
P55 PRO & i5 750
Almost 5hgz , air.
Wrong... the original article I saw in Chinese was trying to hide the real die size. B3D worked out the math and found out the length and width on the picture is wrong.
Pad limited. Rectangle is usually the best way to fit the most I/O.
Charlie basically confirmed that he has some sort of access to an x-ray inspection measurement device, see link.
http://forum.beyond3d.com/showpost.p...postcount=6394
I said it quite awhile ago. GF104 is larger than Cypress, larger than G92 and I was guessing around 350mm2. Turned out it was even larger.
Originally Posted by motown_steve
Every genocide that was committed during the 20th century has been preceded by the disarmament of the target population. Once the government outlaws your guns your life becomes a luxury afforded to you by the state. You become a tool to benefit the state. Should you cease to benefit the state or even worse become an annoyance or even a hindrance to the state then your life becomes more trouble than it is worth.
Once the government outlaws your guns your life is forfeit. You're already dead, it's just a question of when they are going to get around to you.
I still don't buy what Charlie says or others fans off......
This guy totally proved that is against Nvidia.
See this also...
http://forum.beyond3d.com/showpost.p...postcount=6381
i5 2500K@ 4.5Ghz
P55 PRO & i5 750
Almost 5hgz , air.
