I’m about done testing the 1055 under the chilled water. I kinda want to run a few tests using dice to see if the colder temp will give a little more HTT clock at the x14 multi? If I don’t kill the 1055 I’m going to build a gaming rig around it.
I already have a new Cooler Master HAF932 case sitting here waiting. I’m working on a good water cooling system for the case in the mean time until I can get a good cool dry day to test the 1055 under dice.
I probably should do a complete fresh OS install and reflash the bios before the dice tests as they both are trashed.
At the x10 multi the HTT maxed out about the same for both the 1055 and 1090’s.
Anyway here are a few of the 1055T tests I’ve ran so far. I ran some at the x14 multi with the HTT between 328-335 but I’ll post those up later.
System spec.
1055T ASUS CH4F bios 801
4GB Corsair GT 2000 CL8
Asus 5970, or 5970+5870 or 5970+2x5870's
windows 7 64-bit
chilled water CPU cooling
![Send a message via AIM to [XC] Synthetickiller](images/misc/im_aim.gif)
![Send a message via MSN to [XC] Synthetickiller](images/misc/im_msn.gif)
![Send a message via Yahoo to [XC] Synthetickiller](images/misc/im_yahoo.gif)
![Send a message via Skype™ to [XC] Synthetickiller](images/misc/im_skype.gif)
