Planned Specs:
-Mountain Mods Ascension case
-i7 920 D0 (looking to OC to at or around 4.5GHz)
-ASUS Rampage III Extreme
-Mushkin Enhanced Ridgeback 3 x 2GB DDR3 1600MHz (6-8-6-24-1T)
-(3)MSI GTX 480 in 3-Way SLI
-Samsung Spinpoint F3 500GB (for now, looking at SSD possibilities)
-Windows 7 Home Premium 64
-Dual HX1000 PSUs on separate circuits
-(3)ASUS VW266H 25.5" 1920 x 1200 monitors in Nvidia Surround
Water cooling setup (two separate loops):
-CPU/Mobo Loop:
-EK Supreme HF (Plate #1)
-EK-FB-RE3 full cover block
-Swiftech Microres revision 2
-MCP 655 B (vario)
-EK-D5 X-TOP revision 2
-XSPC RX360 radiator
-3-Way SLI Loop:
-(3)Koolance VID-NX480 GPU water blocks (bling bling blue LEDs, baby!)
-MCP 655 B (vario)
-(2)XSPC RX360 radiators
Other water cooling components/bling:
-Feser UV Caribbean Blue 1/2" ID tubing
-Bitspower silver compression fittings
-MX-2 thermal paste (spreads easy with a plastic card, etc)
-(24)Yate Loon Blue LED 120mm High Speed fans, (3)Yate Loon Blue LED 140mm High Speed fans
-Lamptron FC-2 Fan Controller
-(6)Tecnofront Airbox 360 shrouds
-(2)Dual UV Bright Cold Cathode kits
Here's a little teaser for now:
Update: 7/24/2010: 6:45PM Central Time, USA:
Finished cutting and sanding the front panel. Currently looking for hole placements to pass the front fan wires through.
. Definetly subbing this one.
