*Problem Solved*
I was running x8 on both cards and x16 with one card and now I don't even have the option to enable crossfire in CCC. It says that the second card is disabled. Now I can only run x8 in the bottom PCIE slot and x1 in the upper PCIE slot. I've tried uninstalling drivers with driver sweep, reinstalling drivers, swapping out crossfire bridges, updating bios, swapping cards around but nothing seems to work. Not sure when this problem actually started but I will tell you it use to run x8 in crossfire for both cards and x16 with one card.
Here are some screen shots.
If more screenshots are needed to trouble shoot please let me know and I'll post them up.
MB is an Asus M4A89GTD PRO/USB3
Thanks,
