hI, can i sli with the latest drivers?with the hack of course, can i?
cheers
cheers
SLI Certification 987134512781Genuine NVIDIA Certified SLI Ready Motherboard for ASUS RAMPAGE II EXT 3287-Copyright 2008 NVIDIA Corporation All Rights Reserved-765289891023(R)
everest says its ok
thx anyway
EDIT: i did this but there is no need when we use the patch, i used the SLI String installer v.2.0
Intel E5-2660 (ES) @ 2.4 Ghz x2-----AMD Opteron 6172
Asus Z9PE-D8 WS---------------------ASUS KGPE-D16
Corsair Vengence 48GB DDR3-1600-Crucial 16 GB DDR3-1333
EVGA GTX 690 ------------------------HIS HD 6970 x2
Samsung EcoGreen 2TB x4
Corsair 32GB SSD
Creative Soundblaster Z................ASUS Xonar Essence
Xigmatek Elysium
Razer Mamba
Silverstone 1500W PSU
hi dr.noob
i wish to see some of your SLi result
Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
[history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
Hi,
something's wrong with a Forceware 258.xx and SLIMod and it always results in black screen. You got a thread about it on guru3d forum, here: http://forums.guru3d.com/showthread.php?t=325188
We reported this to the SLIMod developers but they claim that the problem isn't in their mod. http://forums.techpowerup.com/showth...60844&page=134
It looks like some kind of Forceware bug so they are all waiting for a new drivers.
AMD FX-8320@4600MHz/Corsair H70/Asus Crosshair V Formula/4X4GB Kingston Predator HyperX DDR3@1912MHz CAS9/2X Asus GTX660 DCII SLI/NEC Multisync 2470WVX/
intel x25-v 40GB +intel 510 250GB +2TB Seagate SV35 HDD/LG DVD-RW/Corsair TX850W/Silverstone Raven RV02 + Scythe Kazemaster Ace
wow dr.noob you don't use sli bridge ?
does it effect on sli performance?
OK, my limited testing using a modded 257.15 driver installation for SLI GTX 460 is quite encouraging and definitely more stable than using the 258.xx drivers (except for that missing OpenCL tick in GPU-Z - any actual significance?).
Go try it out.
Google and download FW 257.15, replace the original with my modded inf file before installing, YMMV.
http://www.ziddu.com/download/10753108/nv_disp.rar.html
Please post feedback here, thx.
black screen shows sometimes, i press esc, alt tab, and ctrl alt delete and its gone.
drivers 258.96
stock 675/1350/3600
800/1600/4000
same as guru3d clocks for comparison
http://www.guru3d.com/article/geforc...-sli-review/14
10min furmark
fan only goes from 40 to 70% in msi afterburner 1.6.1.
