Results 1 to 12 of 12
Thread: Zotac GTX 480 Amp! Edition Review
    Mar 2006
    Hastings, England
    Introduction:
    ZOTAC International is one of the largest producers of NVIDIA VGA and motherboard solutions worldwide.
    ZOTAC International (MCO) Limited was established in 2006 with a mission to deliver superb, high quality NVIDIA graphic solutions to the industry. It has strong backing from its parent group, PC Partner Ltd. - with headquarters in Hong Kong, factories in mainland China and regional sales offices in North America, Europe, and the Asia Pacific region. The scale of support ZOTAC provides is currently unrivaled in the world. With 40 surface mount technology (SMT) manufacturing lines, 6,000 workers and a production facility with over 9,000,000 square feet, ZOTAC employs a full array of state-of-the-art technologies and skilled personnel in order to meet your hardware needs. In addition, ZOTAC has over 130 research & development professionals in Hong Kong and mainland China, working to bring you the best from the cutting edge of the industry. ZOTAC's international bases of operation work together to enable effective and efficient global as well as localized sales and marketing support.
    ZOTAC doesn't just mean top tier quality, it is also synonymous with high performance, absolute reliability and unparalleled value. With a range of products featuring overclocked performance, excellent cooling properties, and unique packaging ZOTAC products routinely meet - and exceed - users’ expectations.
    ZOTAC's unwavering commitment to our users is to bring the latest products quickly to the market with the best value. Needless to say ZOTAC is the right choice for those who demand the highest quality graphics solutions.
    OK we have all seen and heard about Nvidia's new GTX480. What makes this one different ? Lets take a look ....
    Spec:
    Model ZT-40102-10P
    Cooler Active (with fan)
    Core Clock 756MHz
    Core Processors 480 Stream Processors
    Dimensions 13.26“ X 10.23“ X 2.67“
    DirectX DirectX 11
    Dual-Link DVI Supported Yes
    DVI 2 (DVI-I)
    GPU GeForce® GTX 480
    HDCP Ready Yes
    HDMI 1 (Mini HDMI 1.3a)
    Interface PCI Express 2.0 x16 (Compatible with 1.1)
    Max Resolution 2560 x 1600
    Memory Clock 3800MHz
    Memory Size 1536MB
    Memory Interface 384-bit
    Memory Type GDDR5
    Package Contents ZT-40102-10P
    Driver Disk
    ZOTAC Technology Demos Disk
    User Manual
    Mini-HDMI-to-HDMI adapter
    DVI-to-VGA adapter
    Dual 6-pin to 8-pin PCIe power cable
    Dual MOLEX to 6-pin PCIe power cable
    RAMDAC 400 MHz
    SLI Supported Yes
    Weight 2.0000 lb
    Unboxing:
    Front of the box
    Back of the box
    Its open ...
    Cables and driver cd's
    Front of card and hdmi/Dvi inputs
    Rear of card
    Power connectors
    Back of card
    Now lets look at the Zalman V3000 cooler and fans..
    If you are really extreme, you never let informed facts or the scientific method hold you back from your journey to the wrong answer
    Mar 2006
    Hastings, England
    Overclocking
    The card comes with a stock clock of 756Mhz on the core shadders at 1512 and the memory at 950Mhz. As this review was done with the card in a case I wanted to keep fan speed low and didnt want to adjust voltage atall. This is the system used and how i got on ...
    Code:
    Intel Core i7 920 @ 190x19 3.8Ghz Gigabyte X58-UD5 APOGΣΣ DDR3 2000 6GB @ 1900 Cas 9 Corsair TX950
    Zotac has its own tool for the user to overclock the card. Thou not as feature packed as MSI afterburner the Zotac Firestorm does the job. Thou slightly backwards with the Memory slider changing the core frequency and the shadder slider adjusting the ram .. :rollyeyes:
    anyway the oc i got to and was happy with is 880 Core, 1759 Shadder and 1055 Memory. All test were run with the fan on Auto and no adjustments to the core voltage.
    The benchmarks I used are Futuremark 3DMark 03,05,06 & Vantage. I also used Farcry benchmark tool and Battlefield Bad Company 2. I also ran Unigine which you will see below. I ran these benchmark with a Nvidia 260 216 before running them with the Zotac Gtx 480 Amp! Edition so to have a comparison. I ran the tests at stock and then at the oc I was happy with. I used Msi tool to monitor the temps,volts, fan speed and clocks. These test were run on a absolutely non tweaked os. I didnt even change the resolution from 1920 -1080.
    Results
    3DMark 03
    3DMark 05
    3DMark 06
    3DMark Vantage
    As you can see 3Dmark 05 and 06 didnt really gain alot from the card being oc'd. This makes me think the cpu needs to be a bit faster to really enjoy the overclock on the card. Thou 03 and Vantage show nice gains over the stock results.
    The card leaves the Nvidia 260 216 for dust as expected. Also please note 3Dmark Vantage was run with Physx off
    Mar 2006
    Hastings, England
    Far Cry 2
    I ran the benchmark tool with a custom test from Hardware Canucks.
    All settings on Highest setting @ 1920-1080
    Here are the results with the card oc'd and with AA enabled.
    I used frapps to test performance in Battlefeild Bad Company 2.
    I used the same save file each time and loaded the cold War level.
    All settings on highest settings at 1920-1080
    and here are the results with AA Enabled
    The card never went over 71c even with a 20 min session.
    and finally my Unigine Heaven score with the card overclocked
    Conclusion
    Well all I can say is wow. This card performed amazingly. All I had heard about the Nvidia GTX 480 is that they are hot and the fans are loud. Well Zotac have answered both these issues with the AMP! Edition. With the fan under 55% I couldn't hear it over my system fans atall. As you can see from the results the fan only went higher than 48% during the furmark test which really doesn't represent real gaming or benching. The testing was done over the last few days with a room temp of 23-24c and I has very happy with the temps the card was producing.
    All in all a quility graphics card.
    Great Work Zotac
    Dec 2009
    Southern California
    Awesome review, really very well done.
    Thanks for the post!
    Cory.
    What if the hokey pokey really is what it is all about?
    I am Xtreme Ket's Avatar
    Apr 2004
    United Kingdom
    At least Zotac got the name of their OC software right for that blast furnace "firestorm"
    "Prowler"
    X570 Tomahawk | R7 3700X | 2x16GB Klevv BoltX @ 3600MHz CL18 | Powercolor 6800XT Red Devil | Xonar DX 7.1 | 2TB Barracuda | 256GB & 512GB Asgard NVMe drives | 2x DVD & Blu-Ray opticals | EVGA Supernova 1000w G2
    Cooling:
    6x 140mm LED fans, 1x 200mm LED fan | Modified CoolerMaster Masterliquid 240
    Asrock Z77 thread! | Asrock Z77 Extreme6 Review | Asrock P67 Extreme4 Review | Asrock P67 Extreme4/6 Pro3 thread | Asrock Z68 Extreme4 thread | Asrock Z68 Extreme4 Review | Asrock Z68 Gen3 Thread | 8GB G-Skill review | TK 2.ZERO homepage | P5Q series mBIOS thread
    Modded X570 Aorus UEFIs
    Feb 2009
    thank you
    are you dont have more overclocking for the card
    Mar 2003
    The Netherlands
    Nice review, good stuff man!
    I have the VF3000 on my ATi (sorry for offtopic) and @ 5v I have amazing temps and silence
    lol... This forum requires that you wait 70 seconds between posts. Please try again in 8 seconds.
    *phone rings*
    Friend: Do you have a spare PSU lying around?
    Me: No why?
    Friend: My PSU just blew up, I think the second 8800GTX might have been too much for it to handle
    Me: what PSU was that again?
    Friend: Antec 480w
    Me:........
    Jun 2005
    3-slot cooling solution I presume? If so, it limits the SLI capability to a few motherboards.
    Xtreme Guru
    Jun 2010
    In the Land down -under-
    Nice card, seems like ZOTAC got their cooling down pat... Might save me the hassle of watercooling the 2x 480's im soon to get..
    Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
    Oct 2002
    London
    Nice review.
    What is the default VGPU on that card please ?
    Feb 2005
    Can you give measurements on how far it goes into the third slot without the shroud? I am wondering if I can manage to place 2 12mm slipstreams on it for a PC-Q08 build.
    You can see that there is some room under the 2 slots but I'm not entirely sure if it can fit with everything stock.
    Aug 2010
    Russia, SPb
    Quote Originally Posted by next-jin View Post
    I have an ati 5850 in my pc-q08 and it about 5-6 cm distance between ati and chill fan
    Some photo
