Heya
The idea was to create a very massive container to handle the heat of Fermi.
I've worked hard in the past few weeks to get these pots done.
First result:
The hole for the probe is very close to the GPU. So temperatures should be accurate.
Diameter in the middle of the pot is 40mm. Enough space for LN2/DICE.
Because of the huge weight of 2850g i decided to change the layout of the container. So it can also be mounted on nearly all CPUs (Socket A, 939, 775, 1156, 1366, AM2(+), AM3).
And for sure polished
On XFX 790i Ultra SLI to show the size of the Pot.
2 of these containers on AMD QuadFX mainboard incl. mounting
And finally mounted on a GTX275 Lightning:
(its important to put something between mainboard and pot to support the card because of the huge weight!)
