Set Up:
Ultrasonic2 Dual 50mm Direct Die TEC Block
2 x Custom Thermoelectric TEC's : 226 Couples 331wQmax 17amp 31.5v @ 23v. PSU: Mean Well 600w 24v 25 amp. Cooling: 4 x Black Ice GTX 240 Rads, 16 x High Speed yates Push/Pull, Iwaki RD 30 24v Pump.
Ambient:
Base Shot:
Cheapo Laser Thermo doesn't go any lower :P Thermocouples will be added later to the hot and cold plates.
Prime Blend 1 Hour Hyper Threading Enabled.
i7 920 D0 @ 4.2 1.2Vcore 6 Gigs Gskill Trident Classified 759.
Prime Blend 1Hour Hyper Threading Disabled.
Test Rig:
