Results 1 to 13 of 13
Thread: [Review] Thermalright Spitfire and GTX480 [56K Warning]
    Jun 2008
    Italy
    Hello Guys,
    today i am here for show you what happen if we use a Thermalright Spitfire with a new nvidia Card... Many thanks to MSI and Thermalright, for the Card and the Heat sink.
    First of all some pics
    For the test i used this setup (sorry if some word in the tabs are in Italian.. if you don t understand you can ask it to me )
    I made 2 different test.. one for see how better is the Spitfire then the Stock Heatsink, and the second one for see if using Spitfire is possible have an higher overclock limit.
    In the first test i will use the same configuration, but one time VGA will be at default, while in the second time of the test i overclocked the VGA at 800 MHz / 1600 MHz for core and cuda cores, and 1000 MHz for the memory... i used also 1,04V, an higher vgpu core than the reference value for increase the stress for the Heatsink
    With the Spitfire i used a Sharkon 140mm PK-2 fan.
    First stage: Temperature
    Here you will see the temperature that i saw with the nvidia heatsink:
    Default (Not overclocked)
    Overclocked Card (core @ 800 MHz, Cuda Core @ 1600 MHz, memory @ 1000 MHz, VGPU core @ 1,04V)
    Now i will show you the temp that i logged with the Thermalright Spitfire:
    in these 2 graphics you can see easily how much is the difference between the nvidia heatsink and the Thermalright Heatsink
    Idle
    Full
    Second stage: Overclock Limit
    Here i will show you how the Spitfire can improve the performance and not only the temperature and the noise level
    Nvidia Reference Heatsink(sorry for the memory.. i made a mistake with afterburner :S.. anyway can work easily at 1090 / 1095 MHz
    In conclusion i think Thermalright Spitfire is a very good heatsink, and can work without problem also with the new nvidia Card. Mounting is easy, and performance are good. Noise level is very lower than with the nvidia Heat Sink, and this is good for the long session of PC use..
    Is good see also that the core Overclock limit is about 30 MHz higher then with the after market Heat sink.
    maybe the really problem are the dimension, because you can t use it inside a little case.
    If you want read all the review you can go here: http://www.pcbrain.it/index.php/arti...ia-gtx480.html
    Thx and if you need something you can ask it to me.. i will reply soon
    Bye Bye
    2012? Time will tell
    MOA 2011 Italy #1 | MOA 2011 EU finals #7
    GOOC 2010 Italy #4
    Excuse me for my English...
    Jan 2010
    USA
    very nice review ... anyway to get a couple more pics of the spitfire attached? or actually installed?
    Intel I7 920 @ 4.3 // ASUS Rampage III Extreme// 3x2GB Mushkin// Antec TPQ 1200w // Water Cooled
    Dec 2009
    Salem, Oregon
    great review! perfect with HQ pics and tests! good job!
    CPU Intel i7 930 OC 4.0ghz 1.4v
    MEM Corsair XMS3 2GB x3 7-7-7-20
    MB EVGA Classified E760
    GPU EVGA GTX580 SC
    PSU Enermax Revolution 85+ 1050w
    CPU Cooler Corsair H50 w/dual Enermax 12cm Magma push/pull (Shrouded)
    Case Lian Li PC-A7010 Black
    Monitor Samsung 23"
    Audio
    H/K AVR 254
    Paradigm Monitor7 v5
    Velodyne CHTSBV Center/Rear
    Velodyne CT100 Sub
    May 2009
    Nice review but the cooler is pretty disappointing 90 load with an overclocked card is by no means a good temperature and 75 at stock is pretty poor also.
    Did you ever measure vrm temp? because with a load like that those small sinks which would have no airflow thanks to the mounting of the spitfire would of been well over 100C i imagine.
    Feb 2010
    great job w/ the review/testing!
    May 2010
    Great review, it is very informative and interesting! I wish I had this in my gaming pc!
    Jun 2008
    Italy
    Soory for the long time.. i wasn' t at home
    Quote Originally Posted by The Duke View Post
    I am sorry but i can t do other pics, because right now i havent the GTX480 here... i used it only for 4 day
    Quote Originally Posted by xann27 View Post
    thx a lot.
    Quote Originally Posted by Onoff312 View Post
    sorry but the heat sink performance are very great... you should not see the final temperature, but the difference between Nvidia heat sink and the Thermalright Spitfire..
    For example nvidia overclocked Card in full load @ 104°C, while spitfire @85°C... 20°C Lower are a lot.
    same thing for the card without Overclock, because with reference heat sink i logged 90°C while Spitfire can take stable the 75°C
    Also the Idle temperature are very good, because are 15° lower than the reference heat sink.
    Yes i logged the VRM temps, and it was max at 81°C... i was without a fan there.. so i think if you will mount that little heat sink in a case with in front a fan for the Hard Disk, you will have better temps
    Anyway for the moment Spitfire is not official compatible with GTX480... and i think when will be compatible Thermalright will launch also a Better VRM cooler like the VRM R4.
    Quote Originally Posted by imersa View Post
    thx :-)
    Quote Originally Posted by ComputerGuru114 View Post
    i wish you the same, is a very good cooler
    GOOC 2010 Italy #4
    World Champion - IRONMODS
    Sep 2007
    Northern Japan
    Good stuff mate thanks
    Quote Originally Posted by Massman
    My definition of 'efficient' is 'it does not suck monkeyballs'. Yes, I set bars low.
    [CENTER]The post counter is not an intelligence meter!
    MAX11L - "It's like a console...with the suck turned down and the awesome turned up" -tet5uo
    Heat Team IRONMODS
    Nov 2004
    Finland
    Great review....
    Jun 2007
    Temps seem kinda high when the youtube vids showed a max of 66c with furmark. Do you know if the new VRM coolers for gtx480 will be included in the kit or if it will be separate?
    MSI P67 GD65 B3
    2500k 4.8
    GTX480 835/1650/2000
    8gb ram
    Win7
    Jun 2008
    Italy
    i don t know if the VRM cooler will in the bundle or not :S
    sorry
    For the temps... yes are a little higher than the Thermalright video, but the fault could be various... higher ambient temp, in Italy now is really hot, maybe a better thermal grease, maybe a better fan..
    I dont know
    GOOC 2010 Italy #4
    Jul 2009
    I wonder why you haven't posted any pictures with the card inside a case. My guess is because this won't fit along side a tower cooler.
    This is probably design wise the worst cooling product ever. Messes up the entire inside of a build and barely beats the stock. I would like to see how this performs against a similar product like the Prolimatech MK-12 or Accelero extreme and not the crappy stock pos.
    Congrats on the effort but this is a half baked test made to put the product in a better light than this actually is. TR should be happy.
    Mar 2009
    great results. 25% lower temperature AND a small fraction of the fan noise AND guaranteed overclock to 850+mhz is an accomplishment perhaps unmatched by any gtx 480 cooler. incredible performance, really.
    needless to say, ignore the ignoramuses.
