Here's TPU's review:
http://www.techpowerup.com/reviews/Z...Edition/1.html
According to this review, the AMP draws 30W less power than a reference 480 despite being clocked 50MHz higher.
Also it runs 20C cooler on load. However, looks like Zotac screwed up the fan profile - there is no difference between fan noise while idle and on load
Looks like this could be the 480 to get - the only problem is that it dumps 300W of heat into your case, so you need good airflow
