Here I will compare the performance of ASUS GTX 465 and ASUS GTX 285 TOP
My system
CPU Core i7 Extreme 965 @ 3.6GHz
Mainboard ASUS Rampage II Gene
RAM 3x2GB DDR3
VGA ASUS GTX 465, ASUS GTX 285 TOP
Windows 7 Ultimate 64bit RTM
Driver NVIDIA 257.15 beta 64bit
Crysis Warhead. 1680*1050, NoAA, Enthusiast DX10, ambush map
ASUS GTX 285 TOP
ASUS GTX 465
Call of Juarez DX10. 1680*1050, AA=4X Multi_sampling, Max Settings
ASUS GTX 285 TOP
ASUS GTX 465
S.T.A.L.K.E.R Call of Pripyat DX11. 1680*1050, AA=4X, Max Settings
ASUS GTX 285 TOP No Tessellation
ASUS GTX 465 Tessellation=ON
You see, the GTX465 is not entirely weaker than GTX285 TOP, just remember that this is the GTX285 TOP, core/shader/ memory 670/1550/1300 (default clock of the GTX285 is only 648/1476/1242)
Do you say that GTX465 is a less powerful than GTX275 ?
I have checked with stock fan, GTX465 activity was stable at core/memory 650/840. Room temp 30oC, fan set 87%
I use furmark to test the temperature of GTX465@650/840. Furmark run 20'
Temp Max 77oC
Source : http://forum.amtech.com.vn/overclock...gtx-465-a.html
------To be continued
