making custom water blocks
okay
i have an ASUS P5E3 mobo
and i want to OC this new machine when i get it up and running
and im very cautious that the chipset heatsinks will not be able to handle my................. quite possibly over zealous attempt at OCing
so i want to build a custom one piece block for the chipset
so i need your help
how thick is the overall height of the blocks?
i want to use a plexiglass top so that you can see inside and see the coolant
any suggestions on how to 'glue' them together, what would you stay away from and what would you suggest?
any design tips?
i want to use 10mm compression fittings on said block
what is the dia. of the hole that i need to make in the plexi for the threads to get a grip and to seal correctly?
how do i make sure that the block will be low enough to allow the GPU to seat correctly?
i do have some ideas and drawings
but its all just a proto and a top view
if i have left anything else out then let me know
thanks for any help guys
- You may not post replies
- You may not edit your posts
Forum Rules
