Results 1 to 3 of 3
Thread: [Just4Review] Noctua NF-S12B FLX
Hybrid View
    Jul 2009
    Noctua NF-S12B FLX
    Just4Review
    Sistema de Testes:
    AMD x4 945 3GHz
    Gigabyte MA790X UD4
    Gainward 4870 512MB Golden Sample
    OCZ DDR2 800MHz PC6400
    WD 500GB
    Thermalright ToughPower 750W
    HomeMade BenchTower
    Thermalright Venomous-X
    The Just4Review behind you now already known the Noctua NF-S12B.
    The Noctua fan is behind us in a box with the usual colors of the brand. Inside we have the fan, an adapter to connect to a Molex, and two adapters that allow us to use this to 900rpm or 600rpm fan (Standard = 1200rpm). We also have four rubber anti-vibration and four screws.
    Tests :
    LinX (10 Run’s) / All Stock
    The tests were performed with the thermal mass Noctua NT-H1, and the ambient temperature fluctuated between 15 º and 17 º C.
    1200 rpm (x2) Idle = 21º| Full = 42º
    1200 rpm Idle = 23º | Full = 44º
    900 rpm (x2) Idle = 24º | Full = 45º
    900 rpm Idle = 26º | Full = 47º
    600 rpm (x2) Idle = 26º | Full = 50º
    600 rpm = Idle = 27º | Full = 57º
    As we can see in the chart above, the performance of these fans is very dependent on the rotation that we use.
    With 1200rpm (even if only with a fan) the results are great and the noise is almost nil.
    Conclusion:
    Pros:
    - Design
    - Silence
    - Robustness
    - Accessories
    Cons:
    - Price
    The performance of these fans and very good. They are perfect for use on a daily basis, because its noise is almost nil.
    The only "but" is that its price of around € 18 in Portugal.
    Xtreme X.I.P.
    Nov 2002
    Shipai
    nice review
    but how noisy are these fans at their respective rpms?
    can you at least mention how noisy they are in relation to another popular fan to get a rough idea?
    a short youtube vid would be enough, first one fan, then another, so we can hear what it sounds like
    Jul 2009
    At the moment I don't have here with me no other fans "known."
    But today i will make videos to see the noise of the fans (600/900/1200rpm)
