Page 1 of 2 12 LastLast
Results 1 to 25 of 45
Thread: Asus m4a89TD pro testing
    Jun 2005
    NYC
    System setup
    ASUS M4A89TD PRO
    AMD X6 1090T CPU
    Ln2 pot by ln2cooling.com
    CORSAIR H50
    ADATA DDR3 2200
    COOLMAX 1200W PSU
    ATI 5870 GPU
    WD 150 GIG RAPTOR
    Uploaded with ImageShack.us
    im going to be testin out this board shortly run some 3d
    Amd Nvidia/Ati -3dmark06 scorebord revisted
    asus L1N64-ws or /b depending on bios chip
    4x1gig 8500 gkill bpk
    2x opteron 8224 @ 3.8ghz
    http://www.xtremesystems.org/forums/...&postcount=236
    vga= 8800gt
    winxp pro
    custom chiller -31 water
    2x dtek fuzions
    bix3-with x3panaflo hi output
    antec 850 quattro
    heat under msimax abitmax and dfimax
    I am Xtreme
    Sep 2006
    Looking forward to some scores again from you and Brian aka the AMDIwantToBlowYaSocksOff crew...
    Question : Why do some overclockers switch into d*ckmode when money is involved
    Remark : They call me Pro Asus Saaya yupp, I agree
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Double trouble.
    We have both already used this board on ln2. IIRC we ran it through at least 15 cold cycles and it's still working fine but we noted some issues. Hopefully these issues can be addressed for the cold guys.
    We hit this in pretesting on ln2.
    Things to note. There seemed to be some form of OVP/OCP kicking in with most chips trying to boot over 4000 NB and 1.725 vcore/1.50NB vid. ASUS afaik is already working on it.
    Meanwhile I'm gonna join msimax and do some testing with more common cooling.
    First complaint is with an average user cooler my GTX/GTX2 ram spreaders interfere height wise with my xiga 1284, that means both my megahalems when oriented in this direction and my TRUE 120 will also interfere.
    Due to having my megahalems on a another system testing currently I will just use some OCZ BE 1600 c7 ram for air testing which have plenty of clearance.
    Side note......I find the fact that this has IDE to be freaking awsome as the CH4 formula renders my IDE drives useless ( which i have quite a few of ) unless using a sata to IDE converter.
    heatware chew*
    I've got no strings to hold me down.
    To make me fret, or make me frown.
    I had strings but now I'm free.
    There are no strings on me
    Xtreme 3D Team
    Jan 2009
    Ohio
    Very nice. Looking forward to your guys' results!
    Smile
    Jun 2005
    NYC
    3dmark06 run
    vga= 8800gt
    winxp pro
    2x dtek fuzions
    antec 850 quattro
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Air testing
    1090T
    ASUS M4a89TD Pro 890FX
    OCZ BE 1600 c7
    PC P&C 1200
    xigamatek 1284 cpu cooler.
    Forgot to patch so clocks are bouncing all over the place. Real speed 217X19.5 = 4231
    C&Q kicking in even though disabled is sort of annoying. I like the clocks to run full blast all the time when I want them to.
    All benches run in the same boot no reboots/reruns to boost score. Just looking for baseline stability.
    Prime 95 next.
    heatware chew*
    Jun 2004
    China
    Hi, chew*, what's your OCZ Black Edition's maximum ram clock/timings on this board?
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Umm.....screenshots above are very informative?
    heatware chew*
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Ok running prime 95 is certainly a chore. Atm I am pinning it on voltage regulation. This board reminds me of my m4a79_T ddr II board alot. It's not a droop isssue a mod can fix because even with LLC enabled which I usually don't use there is still quite a bit of fluctuation.
    I will break out the probe later and get some measure points and "real" voltage readings in a little bit but i'm preety sure what i am going to find is voltage all over the place.
    1.50 vcore no llc = less than 1.45 under load.
    1.450 vcore with llc enabled = 1.50vcore.
    Keep in mind until confirmed those are just software readings.
    So far the best combo for me for stability is CPU_Vcore LLC on, CPU_NB LLC off.
    Also when pushed hard, system seems to hang on post FFDO after bios setting chenges sometimes which on most port 80's works out to D0 = cpu initial, a simple reset keeps settings and boots.
    heatware chew*
    I am Xtreme FlanK3r's Avatar
    May 2008
    Czech republic
    whats your batch Chew? Run with normal ambients?! Hm, your setings for M4A89TD with LCC will the same as with Crosshair IV? Tomorow il build my system and for long time is my "comeback" to ASUS board
    ROG Power PCs - Intel and AMD
    Apr 2006
    Bulgaria
    Sad to see the same problems like on my M4A89GTD... HT fluctuation is killing me, I can't disable C'n'Q, the same thing with the combination "LLC vCore on/LLC CPU-NB off" and the voltages when LLC is on/off.
    There's one strange thing - sometimes C'n'Q get disabled somehow, and it stays disabled before I reset the system.
    Many times when a general change is made in bios the system doesn't post, even if I've set everything back without OC, reset solves it...
    BTW, sorry to ask in this thread, since it's for another board, yet very similar, regardless the different chipset...does anyone know where are the voltage measure points on the board, I'm not very deep in that matter?
    Quote Originally Posted by chew* View Post
    Infrared I will see if I can get correct read points for both boards later today.
    Thank you very much, I appreciate the help .
    X6 1090T (1010MPMW) @ 4267MHz 1.44V NB@3229MHz 1.33V | Asus Crosshair IV Formula | 2x2GB Corsair Dominator GTX2 @ 1845MHz 6-6-5-17-22 1T | Asus HD4890 @ 1050/4800 | Corsair HX850W | HAF 932
    EK Supreme HF | EK-FC4890LT | MCP655 + Koolance D5 Top | ThermoChill PA120.3 + 3x Enermax Magma | XSPC Bay res | Masterkleer 1/2" UV Red
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    I'm using week 15 retails that I binned on ln2.......take that for what it is, this chip is one of the lesser chips that I kept, the best chips don't get hammered on air/water.
    CH4 is a totally diff board so settings will be diff.
    Normal ambients room is about 75F atm.
    Binned on ln2 does not mean great on air/water, in fact it usually means worse but ln2 is all that matters to me.
    Ditching prime 95 until some of this is sorted. Chip is good for 4.1 prime 95 and 4.0 is a struggle currently.
    heatware chew*
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    Nice job guys. Nice chip there, 4.6 on air.
    Formerly XIP, now just P.
    May 2008
    Czech republic
    my is to week 15, ans SN only 00153...
    Champion
    Aug 2009
    Hong Kong
    Another week15 1090T with strong IMC
    A budget board can do pretty well on air
    As Chew* said, there're problems with NB over 4xxx under extreme cooling
    Dun no if the 1455 bios can overcome
    A qualified amateur has been poisoned by LN2 & soon be killed
    May 2008
    Czech republic
    MAD:which exactly batch? I have 1015DPMW....
    Champion
    Aug 2009
    Hong Kong
    Same as yours, Bro.
    Quote Originally Posted by FlanK3r View Post
  18. #18
    Jul 2008
    Czech Republic
    I sent this motherboard back to ASUS today...my experiences are very very good and with my Athlon II X3 425 wasn't problem to do 400MHz+ Bus Speed on airI think, it's great board and it's very good choice in non-highend segment
  19. #19
    XIP
    Nov 2004
    NYC
    Any new bios for this board?
  20. #20
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    I'm never at liberty to leak bios's. Rules are rules. Sure there are others that aren't under the obligations that I am however.
    heatware chew*
  21. #21
    XIP
    Nov 2004
    NYC
    No problem
    Just want to know if NB <4K fixed with the new bios
  22. #22
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Quote Originally Posted by Dumo View Post
    No problem
    I have a board all prepped for ln2 but I will wait till they fix the voltage issues that i just reported, no sense in wasting ln2 atm.
    heatware chew*
  23. #23
    XIP
    Nov 2004
    NYC
    Aren't we all
  24. #24
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Aren't we all
    I actually had a couple chips booting at 4200 on this board but for the most part 4000 was the wall. Workaround is to treat it like an OCP/OVP issue, Shut PSU off till power light goes out, then reboot and it will boot into windows fine, it's just annoying.
    heatware chew*
  25. #25
    Xtreme 3D Team
    Jan 2009
    Ohio
    That sounds way too familiar with me...not to mention I've had to do that a good 5 times lately.
    Couldn't you guys boot at a low HT Ref. and NB multi and OC it via AOD?
    Smile
