LSI MegaRAID 9260 new firmware 12.6.0-0017(APP-2.60.03-0829)
LSI Corp. MegaRAID Firmware Release
Release date: 05/05/10
Supported Controllers:
MegaRAID SAS 9260-4i
MegaRAID SAS 9260-8i
MegaRAID SAS 9260DE-8i
MegaRAID SAS 9261-8i
MegaRAID SAS 9280-4i4e
MegaRAID SAS 9280-8e
MegaRAID SAS 9280DE-8e
Component:
SAS MegaRAID Firmware Release for MegaRAID Controllers
Version Numbers:
Current Firmware Package: 12.6.0-0017
Current Package Details: APP-2.60.03-0829_BB-2.02.00.00-0000_BIOS-3.13.00_WEBBIOS-6.0-9-e_5-Rel_PCLI-04.04-00100008_BOOT-01.250.04.219_NVDATA-2.03.0056_2010_03_23
Previous Firmware Package: 12.3.0-0022
Previous Package Details:
APP-2.30.03-0775_BB-2.02.00.00-0000_BIOS-3.09.00_WEBBIOS-5.0-8-e_0-Rel_PCLI-04.02-00400008_BOOT-01.250.04.219_NVDATA-2.03.0044
Bug Fixes and Enhancements:
Enhancements:
Add support for Advanced Software Options from LSI including:
• LSI™ MegaRAID® CacheCade™
• LSI™ MegaRAID® FastPath™
• LSI™ MegaRAID® Recovery
• LSI™ MegaRAID SafeStore™
Other firmware enhancements:
LSIP200036035 AEN for CacheCade size change
LSIP200036030 SAS Firmware to store the TTY log into Flash ROM and allow OEM tools to capture it.
LSIP200011688 CacheCade Configuration Management
LSIP200008528 Add the structure in the HWR FW to store the Tape device information.
Firmware bug fixes:
LSIP200044702 10M03 FW goes to megamon when powering on/off 2nd enclosure
LSIP200044921 10M03 FW fails to set mfc value TREAT R1E AS R10
LSIP200053959 After migrating from R6 to R5 the VD IO policy canges from DIO to CIO.
LSIP200018573 CacheCade wording
LSIP200018810 After double rebuild on R6/R60 in a single span with 254 medium errors, one of the rebuilt pds is fa
LSIP200043202 Drives missing show zero capacity during post on Wasat and FW 12.3.0-0022
LSIP200043817 FW goes into Montask when trying to import an invalid Foreign configuration
LSIP200043859 CacheCade properties can be changed using MSM
LSIP200043881 Configurations containg 3 VD's can be imported on Low cost iMR controller with out issues during auto-import.
LSIP200044127 CacheCade is cached for a Secure VD
LSIP200044178 VPD is not working with vendorId/deviceId 1000/0079, SubOem 1,subVendorId/subDeviceId 1000/9280
LSIP200044289 Running io program on 63VD and 1CacheCade caused OCR
LSIP200044342 spinup parameters are hard coded & not used from nvdata
LSIP200044467 Data miscompares reported on 256K optimal R6 VD with special IO
LSIP200044615 Too many unexpected sense events for powered down SATA drives
LSIP200044647 Fix missing changes from 09M11
http://www.lsi.com/storage_home/prod...-8i/index.html
http://www.lsi.com/DistributionSyste...60.03-0829.zip
- You may not post replies
- You may not edit your posts
Forum Rules
