Page 1 of 7 1234 ... LastLast
Results 1 to 25 of 152
Thread: ASUS Crosshair Formula IV OC Discussion
    Aug 2006
    Heres what ive been up to with this combo.Cpu on water.
    Wondering what your north bridge temps are on air.Im at 50c idel,low 60c load accoding to pc probe.
    Board has some unusal voltage readings.
    Volts set in bios turbo v picture below.
    Fluke 87 meter was used to obtain readings on motherboard via probeit.Load line enabled.
    cpu 1.534v
    vddnb1 1.325v
    sb 1.216v
    ht 1.318v
    mb 1.320v
    dram1 1.671v
    cpu pll 2.581v
    cpu1 1.53v
    Apr 2007
    California
    Do you leave the LLC on or off?
    Intel® Core™ i7 920@200x21=4.2Ghz w/1.312v HT on
    Asus P6TD Deluxe
    H2O by Petra's Tech CoolKit Elite Rev.2 w/D-TEK FuZion V2
    EVGA GTX 580
    OCZ3P1600LV6GK 7-7-7-24-1T 6GB
    OCZ Vertex 2 50Gb in Raid-0
    Super Talent UltraDriveGX 128Gb
    WD VelociRaptor 300
    Corsair HX850W
    Windows 7 Professional 64
    AMD Phenom™ II X6 1090T BE @ 4131Mhz(243x17)
    Asus Crosshair IV Formula
    Apr 2007
    California
    By the way, have you installed the Asus PCProbe II? It installs fine, but I keep getting memory access error.
    Asus P6TD Deluxe
    EVGA GTX 580
    WD VelociRaptor 300
    Corsair HX850W
    Aug 2006
    LLC=Enabled at that time.
    PC Probe working ok for me in win7 64bit.Its a little slow to load.
    "New" bios at asus Beta Version 0701
    http://www.asus.com/product.aspx?P_I...sXG&templete=2
    Xtreme Mentor
    Nov 2005
    Devon
    PCProbe loads fine for me.
    If you will leave voltages in BIOS at auto then CF IV will adjust them for you and overvolt everything!!!!
    I've set them manually and all is in line now. CPU-Z and PC-Probe voltage readings are quite accurate.
    Obviously it's quite important to remember that Voltages set in BIOS as offset will increase vCore for example above CPUvid value. So setting in BIOS offset +0.1V results in 1.4V in case of my Phenom 1090T with Turbo enabled this brings total to 1.575V on poorly threaded loads. Asus TurboV will still show only 1.4V but CPU-Z and PC-Probe will reflect close to real value.
    I'm on a 0707 BIOS BTW.
    RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
    RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
    SmartPhone Samsung Galaxy S7 EDGE
    XBONE paired with 55'' Samsung LED 3D TV
    Apr 2007
    California
    Quote Originally Posted by Forsaken1 View Post
    There was already 0707 available. Search this forum for a download link.
    Asus P6TD Deluxe
    EVGA GTX 580
    WD VelociRaptor 300
    Corsair HX850W
    Jan 2010
    I always try to avoid the crapware that you get on cd's, but is the asus turbov alright to use?
    555x2 @ 4.2 / h50
    Crosshair 3 formula
    2x2g ripjaws
    5970, hx1000
    Aug 2006
    Quote Originally Posted by Dyn0miteMat View Post
    Runs well.
    Nov 2002
    Houston
    Quote Originally Posted by Lightman View Post
    The Thubans work a little differently than the other AMD processors. Yes, using offset with Turbo mode enabled will create a situation where the voltages will increase above the offset limit. The reason for this is that even with C1E/CnQ disabled, the first CPU core still implements power saving features which will also explain why you will see the multiplier and voltages reduced in certain situations even with the PM features disabled.
    It causes a few weird situations as you might imagine so having LLC enabled and setting CPU VID and CPU/NB Vid manually is the preferred solution. In regards to CPUZ and other utilities we are working with the authors to ensure each core is recognized properly in regards to voltages and multipliers. We are still working with AMD on some additional tuning and power management features as the latest AGESA code has some additional changes in it.
    Hopefully I will be able to start an official thread on this board shortly and will be able to list this stuff and provide official support. We should have another BIOS release shortly and Auto settings will tighten up the voltages applied in these type of situations. At this point the voltages might seem a little high but it is to ensure stability on Core 1.
    Oct 2005
    Melbourne, Australia
    http://i126.photobucket.com/albums/p...hotos/44pi.png
    You should try tweaking your NB & memory timings more (higher memory frequency doesn't usually have as much effect as lower timings. Also, with low NB clocks the higher memory bandwidth is probably not even utilized anyway)
    I got this on a 965 with water:
    http://sites.google.com/site/apokali...perpi44312.PNG
    My board is pretty poor for overclocking (M4A79XTD EVO).
    BIOS has a limit of 1.7V, and it also has a vdroop of about ~0.04V.
    Won't POST at HTT speeds much higher than I used either (even with lower memory divider, higher HTT volts).
    So I will probably replace it with a Crosshair IV sometime after I get a 1090T.
    Apr 2007
    California
    This really pisses me off. The first CH IV I got had northbridge chipset overheating issue because of the heatsink making poor contact with the chipset. I've got the second one, and it still has the same issue. The first board went over 90C within 5 minutes in the bios hardware monitoring screen. The second one was a bit better, but it went upto 83C within 5 minutes.
    Asus P6TD Deluxe
    EVGA GTX 580
    WD VelociRaptor 300
    Corsair HX850W
    Oct 2005
    Usually when I get a new motherboard I replace the thermal pads/paste
    Dec 2002
    Quote Originally Posted by mngdew View Post
    2 in a row? I dont know how that could happen....thats pretty weird.
    AMD 1090T@4.0ghz
    Enzotech sapphire/Mo-Ra extreme rad
    ht 2400mhz / nb 2400mhz
    12gb Gskill 1300mhz
    HIS HD5970
    Enermax Evo Galaxy 1250
    case: XCLIO A380PLUS-BK
    4.61ghz water
    4.5ghz superpi 1M 15.585
    http://i271.photobucket.com/albums/j...rpi4500mhz.jpg
    25,396 06 Phenom 965@ 4.4ghz HIS 5970@960/1260
    21,893 Vantage, Phenom 965 4.2ghz HIS 5970 @960/1260
    Phenom 2 125w 965 test results
    http://futuremark.yougamers.com/foru...d.php?t=117414
    Phenom 2 140w 965 test results
    http://futuremark.yougamers.com/foru...d.php?t=109214
    Phenom 2 AM2+ 940 cold air results
    http://futuremark.yougamers.com/foru...ad.php?t=97430
    If I dont get every single drop out of my cpu I feel like someone is stealing from me
    Xtreme Cruncher
    Nov 2002
    Belgium
    I'm really looking forward to a new bios which has better support for turbo CORE . (running 0707 now)
    That's the only thing which is lacking for me at the moment , for the rest this board is near perfect .
    Main rig 1: Corsair Carbide 400R 4x120mm Papst 4412GL - 1x120mm Noctua NF-12P -!- PC Power&Cooling Silencer MK III 750W Semi-Passive PSU -!- Gigabyte Z97X-UD5H -!- Intel i7 4790K -!- Swiftech H220 pull 2x Papst 4412 F/2GP -!- 4x4gb Crucial Ballistix Tactical 1866Mhz CAS9 1.5V (D9PFJ) -!- 1Tb Samsung 840 EVO SSD -!- AMD RX 480 to come -!- Windows 10 pro x64 -!- Samsung S27A850D 27" + Samsung 2443BW 24" -!- Sennheiser HD590 -!- Logitech G19 -!- Microsoft Sidewinder Mouse -!- Fragpedal -!- Eaton Ellipse MAX 1500 UPS .
    D-m.o.s.t
    Jul 2005
    The Netherlands
    Anybody with some pi 32m skills who tried the ch4 on that.....?
    Xtreme Mentor
    Nov 2005
    Devon
    Quote Originally Posted by bingo13 View Post
    That's great news Bingo13!
    I'm looking forward to your thread on this forum as well as new BIOS release.
    It took me only few hours to work out how the board behaves regarding voltages and multis. and since then I'm pretty much on top of my setup.
    Really good board and great BIOS for tweaking.
    One question though.
    I'm hearing crack every time singular sound is played and then after few minutes of silence I hear another quieter crack in my speakers (discharging capacitors). It sounds like you would plug in jack in the connector every time sound is played. After the crack sound is fine and as long as music is played it's ok till you stop it and try to play again after few minutes.
    Is it just my motherboard or every one is having this issue?
    BTW it's not my speaker set from Creative because I've used it with 3-4 onboard sound cards as well as SB Live! and it was perfectly fine.
    Thanks for any hints
    Jan 2009
    I don't have any screenies (I'll get some... someday), but I'm really liking this board. So far in my tweeking I've taken my CPU to 4.15 GHz (about 150 mhz higher than my MSI could go) and I've been running 2H prime95 stable at 4.0 GHz. The HT went to 345 before I couldn't boot (which makes me happy; I'll probably pick up at 1055T in the future), and I was able to take my RAM (which wouldn't do rated settings on my MSI) to 1750 MHz, and can probably go higher. Haven't messed with the CPU-NB frequencies yet, but I'll be getting around to that soon. I'm using an old C2 965, but I'm still very impressed.
    As for NB heat issues, I've had none. Mine stays under 40C most of the time.
    ASUS Maximus VI Impact | Intel Core i7 4770k | Sapphire HD 5870 | 2x8GB Corsair Vengeance 1866 | Corsair 760AX
  18. #18
    Aug 2006
    Quote Originally Posted by Apokalipse View Post
    Looks goood.
    That ss was done on 3rd boot.
    Little to warm here lately to lean on it.
    Removed the heat pipe on mobo.
    No thermal paste from factory.All pads.Had poor contact on voltage reg and nb.
    Idled at low 50's c on nb before replacing thermal pads.Now 39-40c according to pc probe.
  19. #19
    Xtreme Mentor
    Dec 2007
    State of Confusion, USA
    Me too! It's nice to have Bingo13 around to help work out the little quirks...
    Your the Man... I've had mine longer than you and I'm still trying to get my head around all the options... It's coming along and I really haven't seen any hateful problems but I still can't say I'm on top of the settup..
    FWIW, I haven't had those problems Lightman, in fact the audio from this board has been very impressive! My connection is SPDIF and it's been beautiful! Are you using the analog outs?
    AMD FX-8350 (1237 PGN) | Asus Crosshair V Formula (bios 1703) | G.Skill 2133 CL9 @ 2230 9-11-10 | Sapphire HD 6870 | Samsung 830 128Gb SSD / 2 WD 1Tb Black SATA3 storage | Corsair TX750 PSU
    Watercooled ST 120.3 & TC 120.1 / MCP35X XSPC Top / Apogee HD Block | WIN7 64 Bit HP | Corsair 800D Obsidian Case
    First Computer: Commodore Vic 20 (circa 1981).
  20. #20
    Apr 2007
    California
    Finally, the third one has the heatsink making full contact with the chipset.
    Asus P6TD Deluxe
    EVGA GTX 580
    WD VelociRaptor 300
    Corsair HX850W
  21. #21
    Jan 2005
    Hamilton Scotland
    Thought I'd give this thread a deserved bump & share my stuff so far with the Crosshair IV
    Asus Crosshair IV Formula Living Review
    • i7 920
    • DFI DK X58-T3eH6
    • G.SKILL PI Black DDR3 PC 12800 CL8 6GB kit (F3-12800CL8T-6GBPI-B)
    • Crossfire 2x ATI HD4670 GPU 785 Ram 1060
    • Thermaltake Toughpower 1200w
    • Cooling: Water - EK Supreme
    • Lian Li V2000B+
    24/7 OC 4Ghz 20x200 x8 1600Mhz 8-8-8-21
    Official Gigabyte X48T-DQ6 Info Thread
    DFI DK X58-T3eH6 on Test
  22. #22
    May 2004
    Aland Islands, Finland
    Quote Originally Posted by Supershanks View Post
    Cheers
    Very good overview of the board
    Asus Crosshair IV Extreme
    AMD FX-8350
    AMD ref. HD 6950 2Gb x 2
    4x4Gb HyperX T1
    Corsair AX1200
    3 x Alphacool triple, 2 x Alphacool ATXP 6970/50, EK D5 dual top, EK Supreme HF
  23. #23
    Jan 2005
    Hamilton Scotland
    Quote Originally Posted by wez
    Cheers
    Thanks wez, it's a very decent board
    • i7 920
    • DFI DK X58-T3eH6
    • Lian Li V2000B+
  24. #24
    Aug 2006
    Always enjoyed clunks overviews.
    Question on crosfire with physx card.
    Pcie16 slots 1 and 2(ATI) and phsx in pcie16 4?
    Mobo manual states crossfire in pcie 16 slots 1 and 3.No room for physx card then.
  25. #25
    Jan 2005
    Hamilton Scotland
    I'm not running crossfire this time round. I would think though it's down to the pci-e configuratioms of the 32 dedicated graphics lanes:-
    Crossfire with 2 cards = 2x16 (slots 1 & 3 as you say)
    1 & 3 are each x16 width.
    Crossfire with three cards = 1x16 (Slot 1) with 2x 8, so it doesn't really matter which slots you use as 2nd card & physx card./ 3rd card, will be both x8 as slot 3 will be running the same speed as slot 2 x8. (Maxing out the 32 lanes as 16+8+8)
    four cards would each pull x8 lanes. (32=+8,+8,+8,+8)
    • i7 920
    • DFI DK X58-T3eH6
    • Lian Li V2000B+
Tags for this Thread
